Cant get drum off
Discussion in 'Suspension' started by RoyB, Jul 14, 2010.
  1. Jul 14, 2010 at 12:51 PM
    RoyB
    RoyB [OP] Well-Known Member
    Chicago burbs
    '09 TRD DC Sport
    Wanna check the rear brakes, but neither drum will come off. Should just be able to take the wheel off and tap the drum off, right? Brakes are not on.
  2. Jul 14, 2010 at 12:56 PM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    Usually you have to hit the drum with a hammer a few times to loosen everything up.
  3. Jul 14, 2010 at 12:59 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    get a bigger hammer
  4. Jul 14, 2010 at 1:03 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    1. Make sure your parking brake (emergency brake) isn't on.
    2. Try hitting it with a rubber mallet.
    3. There is a thumb wheel on the backside of the cover (sorry, I don't have a pic) that will mechanically back the shoe off the drum. These automatically tighten over time as the drum and shoe wears down. Therefore, a small rim forms on the outside of the drum that prevents it from simply sliding off. If you find the thumb wheel on the backside of the drum, turning it should open it and allow the drum to come off. Once you've completed your brake service, you'll need to use the brakes while driving in reverse to get the automatically adjusting brakes to tighten back up against the drum.
    Note: you may need to use a screwdriver, it's probably stuck/rusted/carroded, etc.
  5. Jul 14, 2010 at 1:08 PM
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    Good info. This is why I love this site so much!
  6. Jul 14, 2010 at 1:10 PM
    Tojo
    Tojo Well-Known Member
    Colorado/Arizona
    10 TRD Off Road 4x4
    Mobil 1 0-20W, Tacoma bed mat, tailgate anti-theft, oil filter drain hose, back seat headrest removal, a/c back seat platform, rear spring tsb, Tek.Prodigy P2 electric brake cntrl, Toyota Bed Extender
    might try spraying a little liquid wrench where the rear axle flange and the brake drum mate. let it sit a few mins and while hitting drum with a big swatter, use your other hand to pull on the rear edge of the drum to remove it??
  7. Jul 14, 2010 at 1:15 PM
    larryde09
    Larry
    Rochester, NY
    If you do this, be sure you clean/dry the drum very well before reinstalling! PB blaster and such is petroleum base and will lubricate the drum and shoe effectively making them ineffective. Brake cleaner is always a good idea before buttoning up everything too.
  8. Jul 14, 2010 at 1:19 PM
    doubletaco
    doubletaco Well-Known Member
    Magnolia
    16 Quicksand TRD O/R 4x4
    TRD FJ Wheels, LED Fog lights
    I know on the older taco's the drums were tappered and you had to use a puller, or you could run two bolts in the treaded holes to back them off.
  9. Jul 14, 2010 at 1:22 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I keep two bolts in my tool box for this purpose. They work well at getting the drum off, no pounding with a mallet the bolt just pushes the drum right off. Too bad I can't remember the thread size :rolleyes:
  10. Jul 14, 2010 at 1:35 PM
    RoyB
    Chicago burbs
    '09 TRD DC Sport
    I tried the set screw and that didn't work. Been sitting with wd40 on it. Tried a big hammer. I'll try the bolt idea.
  11. Jul 14, 2010 at 1:40 PM
    RoyB
    Chicago burbs
    '09 TRD DC Sport
    Metric or sae bolt?
  12. Jul 14, 2010 at 1:41 PM
    wcm608
    wcm608 Well-Known Member
    Pittsburgh, Pa
    08 DC LB 4x4 SR5 Impulse Red
    I believe the bolt size to buy is 8mm 1.25 pitch.
  13. Jul 14, 2010 at 1:43 PM
    larryde09
    Larry
    Rochester, NY
    That sounds like the right size for the discs...is there a bolt hole for the drums too? I didn't know that...you learn something every day!
  14. Jul 14, 2010 at 1:46 PM
    RoyB
    Chicago burbs
    '09 TRD DC Sport
    I know I have one at home. I'm at work now with all sae stuff of course
  15. Jul 14, 2010 at 1:48 PM
    wcm608
    Pittsburgh, Pa
  16. Jul 14, 2010 at 1:49 PM
    afd23a
    The Dynamo of Dixie
    Yep, there should be two holes if I remember correctly. Google turned up 8 mm x 1.25 is the right thread as someone else mentioned above.
  17. Jul 14, 2010 at 2:47 PM
    RoyB
    Chicago burbs
    '09 TRD DC Sport
    The bolts worked like a charm! Thanks guys. I tried the ones off the skid plate, but they were too tapered. I stole the ones off one of the tail gate latches and they worked great. Sure was dirty in there. Cleaned it up a bit and all was well.
