Can't get Entune to allow voice recognition to repond to a text message
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mtruck, Nov 24, 2016.
  1. Nov 24, 2016 at 2:16 PM
    Mtruck
    Mtruck [OP] Member
    Do you know if a fix has been found? I can respond to my texts using SIRI but not the entune voice activation. It tells me my IPhone 6 is not a compatable phone.
  2. Nov 24, 2016 at 4:11 PM
    DeadEyeWI
    DeadEyeWI Fight for your 2A right
    WI
    This is normal behavior. Entune does not support any SENDING/RESPONDING of TEXTS via its own voice activation using an iPhone.
    You need to use SIRI. Its lame. I've been an iPhone guy for a long time and have purchased new cars in 2013/2014/2016 and none of them play nice
    with apple. They were all from different auto makers too. I finally gave up with all of these incompatibilities and got myself a Samsung S7 active from AT&T
    and it works. It works so well its not even funny.
    Texting and even emails are displayed and you can respond/reply to/from anything.
    Everything works as it should with Android.....I keep wondering if/when car companies will really embrace Apple.
    :facepalm:
  3. Nov 24, 2016 at 4:41 PM
    walterj
    walterj Well-Known Member
    PA, USA
    Sexy Black '17 Taco 4x4 DCSB TRD Off-Road 6MT
    It's the other way around. Apple does not play well with others.
    jsinnard likes this.
  4. Nov 25, 2016 at 7:23 AM
    TacoMan2017
    TacoMan2017 Well-Known Member
    iPhoneand Entune reads my messages perfectly...but no, it won't take dictation.
  5. Dec 4, 2016 at 4:57 PM
    CementPro
    CementPro Well-Known Member
    2017 Cement Tacoma TRD Pro
    None.
    If I can ask, how did you get your iPhone to display messages? I have a 5S and I only have music and calls.
    Thanks
  6. Dec 4, 2016 at 5:38 PM
    Max74
    Max74 Well-Known Member
    CO
    On your iPhone, go to Settings --> Bluetooth
    With Bluetooth turned on, hit the circled "i" on the Toyota connection and then activate Show Notifications. Then in Entune go through the phone settings and you can activate the message feature.
  7. Dec 4, 2016 at 6:20 PM
    CementPro
    None.
    Thanks. I already did that. Further in my search I found a couple posts that suggest deleting the truck off my phone and phone off my truck, then re-pairing the two. I'll try in the morning.
  8. Dec 4, 2016 at 7:20 PM
    Lightning Taco
    Lightning Taco Member
    2017 TRD Offroad 4x4 Inferno premium tech
    There is a thread somewhere on here about this and helped me resolve this problem. Entune has a glitch so the fix I found that works well for iPhone has to do with choosing the three screen setup for home display. There is option to have four favorites programmed for quick dial. The solution is do not set up the favorites use clock or one of the other options and it should work. However as mentioned before you cannot dictate back unless you use the Siri function located on steering wheel
  9. Dec 4, 2016 at 8:00 PM
    NC_Mtn_Taco
    NC_Mtn_Taco Member
    Jordan
    2017 White Tacoma DCOR
    Car companies have been embracing Apple….it's called CarPlay. Toyota is just slow to the game.
