Can't get even wear on rear Mastercraft Courser AXT tires
Discussion in 'Wheels & Tires' started by winkeldc, Nov 28, 2017.
  1. Nov 30, 2017 at 4:35 AM
    winkeldc
    winkeldc [OP] Well-Known Member
    2014 Reg Cab 4x4
    Thanks! I put them at a but under 29 psi yesterday and they are evenly wearing now, but I haven't had a chance to do the chalk test a second time to make sure. I'll get to that this weekend. I tested the heat with the pressure where I am at, but will do that again once I know for sure what psi to run. Appreciate all the help y'all!
  2. Nov 30, 2017 at 5:01 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    The chalk test should be done at temp, so you will need to drive a bit before you do it. Then once tires have cooled completely that will be your cold PSI which is what your looking for.
  3. Dec 9, 2017 at 11:00 AM
    winkeldc
    2014 Reg Cab 4x4
    Yep, learned that the long way! I finally noticed that on these tires, the max is 44 psi. I never looked and just assumed it was north of 50 like most. They are rated for 2250, so I am seeing now why I had that issue in the rear. Thanks for all the help all!
    TACO TX[QUOTED] likes this.
