Can't get fog lights to turn on?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by aleriance, Jan 7, 2018.
  1. Jan 7, 2018 at 8:36 PM
    aleriance
    aleriance [OP] Well-Known Member
    Jorge
    Naples, FL
    2017 TRD Off-Road 4x4
    CMC 285/70/17
    A few months into owning my truck, I was wheeling on day and when I got home I realized my passenger side fog light had been smashed. Hard enough to where the bulb got knocked out of the housings.
    The other fog light that was untouched did not want to turn on either now. Low on funds and with other things to worry about, I went several months without fixing this. Recently decided to finally take care of it so I can use my fogs again after all this time...
    Instead of buying one replacement OEM housing for around $50, I ended up coughing up the near $200 and bought the Morimoto XB LED fogs housings. During installation I could not get the truck to power on either of the fogs... I reversed the polarity on both, nothing. Tried only one plugged in at a time, nothing. (They plug directly into the OEM plugs)
    I know the Morimotos are fine because I hooked up the leads to a drill battery and they turned on just fine and look great... I have checked in my fuse box under the hood (which I will admit has some dried up mud in there from previous adventures), unplugged the only module labeled "FOGS FR" and swapped it with another module (blue box with 4 prongs) with no luck. I have checked for voltage directly at the plugs where the housings connect to and there is no voltage. I have also sprayed the fuse box with lots of electronics cleaner with the battery disconnected. The fog indicator light DOES turn on when I flip the fogs on.
    Has anyone dealt with this before? Is there a fuse for fogs under the steering column?
    Any ideas?
  2. Jan 7, 2018 at 8:38 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Probably blew a fuse
  3. Jan 7, 2018 at 8:39 PM
    aleriance
    Jorge
    Naples, FL
    CMC 285/70/17
    What fuse though? The only thing I can find that has anything to do with fogs whatsoever is the small blue box looking fuse under the hood, which does not seem to be the issue as I swapped it with a different one from the fuse box and it still did not work.
  4. Jan 7, 2018 at 8:45 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    When the light got smashed out did it by chance break 1 of the wires?
  5. Jan 7, 2018 at 8:47 PM
    aleriance
    Jorge
    Naples, FL
    CMC 285/70/17
    Doesn't seem like it. The wires look perfectly fine to me...
    shakerhood[QUOTED] likes this.
  6. Jan 8, 2018 at 1:22 PM
    aleriance
    Jorge
    Naples, FL
    CMC 285/70/17
    BUMP... Somebody's gotta have some advice here...
  7. Jan 8, 2018 at 1:33 PM
    Mr-Paul
    Mr-Paul Well-Known Member
    Paul
    2017 Qucksand Tacoma SR5 4x4 V6 Access-Cab
    I would sequentially pull each fuse make sure one is not blown, for your first step in diagnosis. There are also fuses in the engine compartment for the hi-amp electrical components. Get a volt meter to help check the fog light output, if no fuse is blown. Use volt meter to see if your ground on the dogs are still good. Last thing I can think is to verify that the fog light relay is functioning.
  8. Jan 8, 2018 at 1:51 PM
    maine88
    maine88 New Member
    Fred
    17 Sport AC
    I blew a fuse puting LED's on the interior lights. Found the blown fuse under the steering wheel. Have you checked there?
  9. Jan 8, 2018 at 1:52 PM
    cascadetaco
    cascadetaco Toyota Addict
    central oregon
    2017 SR 4cyl 4x4 5speed
    that module is a relay. you need to check your fuse. not sure if its under dash or in engine. One or the other tho!
  10. Jan 8, 2018 at 2:20 PM
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    [​IMG] Is this the same diagram that you have? The first 15A fuse above the fog relay show FOG FR.
    shakerhood likes this.
  11. Aug 2, 2020 at 3:52 PM
    WilsonLeiva
    WilsonLeiva New Member
    Wilson
    2019 Toyota Tacoma Sport
    Was this problem ever resolved?? I’m having the exact same issue. Want to avoid taking it to the dealer but I feel like I tried everything, let me know thanks!!
  12. Mar 24, 2021 at 9:33 AM
    Indytaco17
    Indytaco17 Member
    Scott
    MGM 2017 offroad
    Id be interested too. I just installed diode dynamics ss3 and keep blowing my fuse. Then unplugged both side, replaced the fuse, turn on the fog light switch nothing plugged in and still blew it.
  13. Feb 13, 2023 at 9:11 PM
    Tyco_Taco
    Tyco_Taco Member
    RC Cowabunga
    Long Beach, California
    2012 Toyota Tacoma Prerunner TRD Offroad DCSB
    Bilstein 5100 Front Strut Coilovers (C-clip set to the lowest setting) Toytec by Eibach Springs 700lbs springs (2.75 inch Total Lift) Toytec front spacers 1/4 Top Plate Spacer on the front right side Toytec front spacer 1/2 Top Plate Spacer on the front left side (Prevent Tacoma Lean) JBA High Caster Upper Control Arms Bilstein 5100 Rear Shocks Deaver 2inch Lift Add A Leaf Suspension Extended U Bolts Rays Engineering Gramlight 57DR-X 17x8.5 -12 Goodyear Wrangler Duratracs 33x11.5x17 Motorsports Hardware 12x1.5 Extended Lug Nuts w/ wheel locks Full Interior LED light bulb swap (Map lights, Center Dome and Sunvisor Light) Lasfit LED Low/ High Beam Bulb Lasfit LED Yellow Foglight Bulb Stubby Antenna shorty replacement WellsVisors Window Visors TRD Factory Option 4WD Front Skid Plate
    Any light on this thread? Just experienced this today, no illuminated icon that appears on my cluster when I hit the switch, fogs are new.
  14. Feb 14, 2023 at 4:31 AM
    dansflhti
    dansflhti Well-Known Member
    Nova Scotia
    24 TRD Sport +.16 Mustang GT. 14 Street Glide
    Lo-beam headlights on?
  15. Feb 14, 2023 at 7:06 AM
    Travelinman301
    Travelinman301 4 x 4 Fanatic
    Florida
    2018 Blazing Blue Pearl Tacoma TRD Sport 4 x 4 DCSB
    KDMAX-PRO-10.0 Diode Dynamics Sport Fog Lights Morimoto Clear Tail Lights TRD Skid Plate
    You'll have to check the wiring...sounds like the hot lead is grounded somewhere in the circuit.
  16. Feb 15, 2023 at 5:57 PM
    aleriance
    Jorge
    Naples, FL
    CMC 285/70/17
    Geez man this was so long ago... I don't remember at all. I've since moved over to Diode Dynamics SS3's and have been running them fine for years now. Sorry...
  17. Sep 17, 2023 at 5:27 AM
    AbdullaJaafari
    AbdullaJaafari Dubai Taco
    Abdulla
    Dubai, UAE
    2018 Tacoma TRD Off-road
    Having this issue now too. Anyone got a solution yet?
  18. Sep 17, 2023 at 2:22 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    are your brights on?
    RedWings44 likes this.
  19. Sep 17, 2023 at 2:41 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Or your lights even on in the first place?
    RIX TUX[QUOTED] likes this.
  20. Sep 17, 2023 at 3:10 PM
    RIX TUX
    are BRIGHTS on?.......mods are important to note when you are asking about a problem
