Can't get front alignment correct after installing Bilsteins
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma 14, May 5, 2019.
  1. May 5, 2019 at 4:09 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    You say that like it's s bad thing.:p
  2. May 5, 2019 at 4:12 PM
    Tacoma 14
    Tacoma 14 [OP] dclb brm lb
    Va
    2014 tacoma
    I should have known better. I saw too many threads hear should have gone full blown bds lift
    Running Board Man likes this.
  3. May 5, 2019 at 4:15 PM
    Tacoma 14
    Va
    2014 tacoma
    So can anyone here tell me should I back the bilsteins down and get a real lift or put in adj ucas?
  4. May 5, 2019 at 4:15 PM
    RN923
    RN923 Well-Known Member
    Quebec Canada
    08 Tacoma TRD Off Road 6-MT
    seems to be fairly well documented that going to the top of the bilstiens will requre UCA's to get your alignment angles back. I would say go that route or drop it down to the second from the top setting.
    whatstcp likes this.
  5. May 5, 2019 at 4:16 PM
    Tacoma 14
    Va
    2014 tacoma
    Thanks rn923
  6. May 5, 2019 at 4:19 PM
    Tacoma 14
    Va
    2014 tacoma
    Any advice on adjustable ucas
  7. May 5, 2019 at 4:19 PM
    Tacoma 14
    Va
    2014 tacoma
    Or brands
  8. May 5, 2019 at 4:20 PM
    RN923
    Quebec Canada
    If UCA's are in your budget and you want the height then do that, if you UCA's arent in the budget then down to 2" you go
  9. May 5, 2019 at 4:21 PM
    Tacoma 14
    Va
    2014 tacoma
    Ok thanks
  10. May 5, 2019 at 4:21 PM
    ToyotaRoamer86
    ToyotaRoamer86 Well-Known Member
    Brandon
    Frisco, CO
    2007 Tacoma TRD Sport
    SPC uppers
    ImMrCrash and RN923 like this.
  11. May 5, 2019 at 5:20 PM
    NBourque
    NBourque Well-Known Member
    Nick
    Maine
    ‘21 PRO
    Set the 5100s to 0 and add a 2” lift coil.
  12. May 5, 2019 at 7:26 PM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Need more details. You’re not giving all the info. How off are we talking. Is it your toe? Camber? Caster? All of them? Was it installed professionally or by you? Before you do anything, take it to a shop that has an updated alinement system so you can get actual printouts and know your numbers
    whatstcp and Running Board Man like this.
  13. May 5, 2019 at 7:33 PM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    His guy being old school tells me he wasn’t going off of numbers at all. And if he’s eyeballing it, then that’s the whole problem right there. Get an alinement on a computerized system that will show you the alinement numbers
  14. May 5, 2019 at 7:41 PM
    Clearwater Bill
    Billy
    Largo Florida
    What does that even mean?
    Is he using strings and voodoo?
    Regardless of experiential wisdom no one can assure you of a correct solution unless the full problem is known.
    So we need to see numbers like @JaCado asked for.
    And that much lift using preload isn't cool anyway, regardless what the Billie fans say. Using the correct spring rate is a much better way.
  15. May 5, 2019 at 7:44 PM
    #35
    Clearwater Bill
    Billy
    Largo Florida
    Nope. Hubs are what are aligned. Tires and wheels dont even need to be on the vehicle.
  16. May 5, 2019 at 7:47 PM
    #36
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Although it would be nice to have them on o_O
    tcjacado likes this.
  17. May 5, 2019 at 7:48 PM
    #37
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Just like it’d be nice if my wife stopped yelling at me for buying stuff for the truck :anonymous:
    Running Board Man and tcjacado like this.
  18. May 5, 2019 at 7:48 PM
    #38
    tcjacado
    tcjacado Well-Known Member
    I hear duck tape can solve that
  19. May 5, 2019 at 7:50 PM
    #39
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    She’d rat me out in a second! Oh hey Jay! How ya been? You seen the crap the douchbags in the RCI groupbuy were tryna pull!
    tcjacado[QUOTED] likes this.
  20. May 5, 2019 at 7:51 PM
    #40
    tcjacado
    Nah, I missed it. What went down??
