Can't get gas in my truck! LOL
Discussion in '1st Gen. Tacomas (1995-2004)' started by bunkerboy, Dec 1, 2011.
  1. Dec 1, 2011 at 10:03 AM
    bunkerboy
    bunkerboy [OP] Well-Known Member
    Gainesville, FL
    2014 Prerunner
    Hey folks, brand new newbie here ... here's my issue.
    When I try to fuel up, the gas comes foaming up into (and out of) the neck after a couple seconds. The pump won't go slow enough to prevent it, and it happens at all pumps. I can only pump about 50 cents worth, then wait a few seconds, pump 50 cents more, and so on.
    It's like a clogged breather tube or something, only worse.
    When you look into your filler neck, aren't you supposed to see a little metal trapdoor in there? 'Cause I don't see one, and if it used to be there (don't remember) it may have come loose and fell down into the neck somewhere to clog the flow of fuel to the tank.
    Any thoughts??
    Thanks!!
  2. Dec 1, 2011 at 10:20 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    I think you are right about the trapdoor thingy. It is supposed to be there, and its possible it fell off and is sitting down there stopping up the hole.
    See if you can take one of those long magnet tools and pull it out.
  3. Dec 1, 2011 at 10:23 AM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    Squeeze halfway?
  4. Dec 1, 2011 at 10:24 AM
    GrayTacoma
    GrayTacoma Well-Known Member
    Andy
    Huntingtown, MD
    2011 TRD off road
    PIAA ion yellow fogs stay on all time,aux reverse lights, aux lights, camper with rack, cb, air bags, on board air, aux fuse box, aux batt, CAI, etc.............
    Some newer vehicles dont have the trapdoor thingy. Dont know if yours is one.
  5. Dec 1, 2011 at 10:26 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    have you tried holding up the nozzle and pumping?
  6. Dec 1, 2011 at 10:29 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    His is an 04. Doesn't seem too new. I thought the newer ones have to have it?
  7. Dec 1, 2011 at 10:55 AM
    bunkerboy
    Gainesville, FL
    2014 Prerunner
    I've tried everything. You can pull the nozzle clear out til you're watching the gas flow.
    No gas pump will pump slow enough to not overflow the neck. The only way I can fuel up at all is to do the start-and-stop thing.
  8. Dec 1, 2011 at 10:58 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    ill take a look at my truck to see how thick and if there is any places for hoses to get kinked and reply back tonight
  9. Dec 1, 2011 at 10:58 AM
    babytruck
    NorCal
    You said that it happens at all pumps. Do you mean at THAT particular station or at other stations too?
    The reason I ask is because that happened with my son's car and my first thought is that someone shoved something in there. But he said the nozzle looked more curved than usual.
    So what we did was take it to another station and noted that the nozzle was more straight. The gas went in just fine.
  10. Dec 1, 2011 at 11:13 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    do you have a body lift? the fuel filler extension tubing always gave me trouble on my 99 taco with a 2" BL
  11. Dec 1, 2011 at 11:17 AM
    gooch14
    gooch14 Well-Known Member
    Kyle
    Michigan
    2011 Blk DC Taco SR5 4x LB
    Bestop, Child Seats, petrified french fry, dog hair, empty Mtn Dew cans cracked windshield, scratches.
    did you try sorta 'lobbing' the fuel in from like 10ft away from the trucK?
    yah you'll spill a little but it won't pressurize the tank and make it burp that way.
  12. Dec 1, 2011 at 11:21 AM
    gov875
    gov875 WahooTaco
    Pacific Beach, CA
    TRD Sport DCLB
    Wet Okole's (front & rear), Weathertech Floormats (front & rear), cheap tailgate theft mod, extra d-rings, low profile toolbox (flat black), Thule Roof Rack (58" load bars), Thule Ski/Snowboard Roof Rack, Blacked Out Badges, Fishing Bobber Trailer Ball Cover, AVIC-X930BT w/ XM & steering controls, 5100s All Around (front set at .85), Eibach Coils, Rear TSB, rear AAL, LR UCAs, Toytec Diff. Drop, Mudflap Delete, Tailgate Reinforcement, Spidertrax (all 4), 285 Nittos, Rear Diff Breather Extension, TRD Exhaust, Powered Rear Sliding Window, DeeZee Bedmat, rear-view anytime mod, trailer bracket relocate, fog light anytime mod, redline hood struts, Satoshi with Homertaco Custom TRD Mesh, Hella 500s behind the grill, Brighter Reverse Lights
    my boat is acting the same way right now and never has before. completely different but at least be thankful you're only filling a 20 gallon tank 50 cents at a time and not a 70 gallon one.
  13. Dec 1, 2011 at 11:30 AM
    bunkerboy
    Gainesville, FL
    2014 Prerunner
    All pumps, all stations.
    Nope, no lift.
    LOL - I've tried lobbing it from about an inch, hadn't thought to back off a few steps though.:D
  14. Dec 1, 2011 at 11:35 AM
    gooch14
    Kyle
    Michigan
  15. Dec 1, 2011 at 11:42 AM
    fishntaco
    fishntaco Well-Known Member
    Josh
    Mobile Al
    08 Silver Streak DCLB Prerunner Sport
    When you filled up previously did you pump more gas after the pump cut off? I don't know if 1st gens have a charcoal canister but I have seen this problem before.
  16. Dec 1, 2011 at 12:22 PM
    bunkerboy
    Gainesville, FL
    2014 Prerunner
    You mean like pumping a little more gas to bring it up to an even dollar amount?
    If so yes, I've always done that.
  17. Dec 1, 2011 at 1:44 PM
    babytruck
    NorCal
    Educate me, please.
  18. Dec 1, 2011 at 2:08 PM
    TacoMX
    Jonathan
    Deltona, Florida
    I know my 2.7 has a charcoal/evap canister. There is a pipe/tube that runs off the main fill neck, about 3'' below the filler cap, and it has a hose that runs to the evap/charcoal canister under the hood. Mine is on the drivers side, fender side, inside the engine bay. Its a black box that is about 10X4X6 and has two circular cap things on top.
    Any overfill or expanding gas fumes are routed there.
  19. Dec 1, 2011 at 2:11 PM
    babytruck
    NorCal
    So it's like a reservoir type thing?
  20. Dec 1, 2011 at 2:16 PM
    TacoMX
    Jonathan
    Deltona, Florida
    not really, but sorta...
    The charcoal absorbs any fumes and moisture. So there is no fluid in it. The evap canister also has a valve to let any gas fumes out. Mine buzzes when it is warm (80degs+) because the fuel vapor in the tank expands and it lets off the pressure.
