Can't get high pressure rail line to stop leaking
Discussion in '1st Gen. Tacomas (1995-2004)' started by Grabo, Jul 16, 2023.
  1. Jul 16, 2023 at 10:52 AM
    Grabo
    Grabo [OP] Member
    Keith
    2002 Toyota Tacoma TRD
    Factory
    I've tried but no luck. Any help would be appreciated
  2. Jul 16, 2023 at 10:59 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Engine?
    Just where did the line fail ?
    just what have you attempted ?
    What caused the line to fail?
  3. Jul 16, 2023 at 11:07 AM
    Grabo
    Grabo [OP] Member
    Keith
    Factory
    Right at fuel filter both ends aluminum crush washers
  4. Jul 16, 2023 at 11:09 AM
    Grabo
    Grabo [OP] Member
    Keith
    Factory
    3.4 v 6
  5. Jul 16, 2023 at 11:10 AM
    Grabo
    Grabo [OP] Member
    Keith
    Factory
    Two different kinds of washers aluminum and copper
  6. Jul 16, 2023 at 11:22 AM
    Bivouac
    Aluminum on a fuel filter ?
    I never used anything but copper .
    You installed 2 washer per Banjo Bolt both sides of the fitting?
    Every thing was cleaned before being assembled real well?
    It only takes a tiny piece of dirt to leak.
    What brand filter there are some of very poor quality being sold.
  7. Jul 16, 2023 at 11:25 AM
    Grabo
    Grabo [OP] Member
    Keith
    Factory
    I only installed on bottom end of fitting
  8. Jul 16, 2023 at 11:26 AM
    Grabo
    Grabo [OP] Member
    Keith
    Factory
    What ever advanced auto parts gave me
  9. Jul 16, 2023 at 11:28 AM
    Grabo
    Grabo [OP] Member
    Keith
    Factory
    Have you ever tried tape on threads the gas approved stuffl
  10. Jul 16, 2023 at 11:29 AM
    Bivouac
    Now that is interesting because The 3.4 does not use banjo fittings but Flare fittings on the fuel filter.
    Has your filter been changed from the stock filter?
    Flare fittings do not use crush washers.
    Cloud99 likes this.
  11. Jul 16, 2023 at 11:30 AM
    STOCKTRD
    STOCKTRD Well-Known Member
    In Traffic
    CustomTacos Mafia!
    Nachos, Lemon Heads, My Truck Is Stock!
    @Grabo
    I dont think you need to use washers at all. The fittings both side of the fuel filters are B-Nut style which dont require washers. Also, do not use any pipe tape on the threads either. But give me a a few minutes, Im digging into my 1st Gen info to get some info on replacing the fuel filter. to verify this.
    Nessal and Cloud99 like this.
  12. Jul 16, 2023 at 11:32 AM
    Bivouac
    If the filter is stock it is a flare fitting
  13. Jul 16, 2023 at 11:33 AM
    Bivouac
    Your filter is on the frame Correct?
    tape is never a good idea with fuel injection.
    ScrippsRanch67 likes this.
  14. Jul 16, 2023 at 11:41 AM
    Bivouac
    if Autozone gave you the correct filter for your 3.4 you do not use washers!!
    Using washers would cause your leak!
  15. Jul 16, 2023 at 11:42 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    In this modern age it still amazes me how people don't post pictures of what they are talking about. Photos!!!!!
    Kwikvette and Bivouac like this.
  16. Jul 16, 2023 at 12:17 PM
    STOCKTRD
    In Traffic
    CustomTacos Mafia!
    @Grabo I found some info that should help you with the filter replacement.
    The fuel filter connections are flared fittings. They do not require any gaskets, washers, or orings. Using any of these would cause the fittings to leak. Also, using pipe tape on the threads would also cause the fittings to leak. The factory service manual states to use a light coat of oil on the threads when you install the fittings. I attached a screen shot of that information below. I have replaced several fuel filters on 1st Gen V6 Tacomas and it does take a few tries to get the fittings to seat properly so they will not leak. You also need to inspect the ends of the flared fuel tubing to make sure there on no small cracks that will cause them to leak.
    Here are some how to guides for replacing the fuel filter;
    https://www.yotatech.com/how-tos/a/toyota-tacoma-1996-2015-how-to-replace-fuel-filter-416268
    https://www.tacomaworld.com/threads/fuel-filter-replacement-3-4-v6.591791/
    https://www.youtube.com/watch?v=vdDhXZIs6Lo&t=127s
    Madjik_Man likes this.
  17. Jul 16, 2023 at 12:19 PM
    batt700
    batt700 Well-Known Member
    2017 SR5 Premium 4Runner
    I replaced the fuel filter on my 1st gen before selling it, and let me tell you i had to tighten the absolute shit out of it before it stopped dripping. Like an insane amount of force.
    shankyjones and Bivouac like this.
  18. Jul 16, 2023 at 6:19 PM
    Bivouac
    It only takes a tiny burr or piece of grit on the flare to cause a leak .
    The nut can bottom out before the flare seals.
    Poor quality boot leg filters floating around.
    Then the OP never returns!
    Nessal likes this.
  19. Jul 16, 2023 at 7:42 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Heard that!
    "What's my truck worth?" (No pics)
    "What engine do I have?" (No pics)
    "What suspension do I have?" (No pics)
    "Can't get this bolt off, alternative method?" (No pics)
    So many threads, all requesting assistance and never posting pics.
  20. Jul 16, 2023 at 11:53 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    There shouldn't be any crush washers for a 3.4 v6. Here's a photo of what you should be looking at, and a step-by-step guide that details the process of replacement (and the correct part number to replace the old one):
    How-to: Replace the Fuel Filter in a 96-04 Tacoma
    Fuel fiter itself: 23300-62010
