Can't get into Temp Check mode on 2016 TRD
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LbrTaco, Apr 7, 2025.
  1. Apr 8, 2025 at 5:47 AM
    #4TOY4ME
    #4TOY4ME Now driving #5
    Robert
    Kingman AZ
    17 MGM OR 4X4 AC
    Level 8 Mk6 16x8 0 offset , Bilstein 5100 G4 Elite Fold A Cover
    Have you let your truck cool off enough to be well under 95 degrees? It won't go into check mode if your truck if your truck is to warm.
  2. Apr 8, 2025 at 5:55 AM
    LbrTaco
    LbrTaco [OP] Member
    2016 Tacoma TRD Sport
    Yes I thought of that as well. The truck is cold. I let it sit, and the outside temperature here is cold right now as well.
    #4TOY4ME[QUOTED] likes this.
  3. Apr 8, 2025 at 7:20 AM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    You’ve got to buy the tacoma PID from within the app if i remember correctly. If you already did and it’s still not there you might need to update the app
    black3rdgen[QUOTED] likes this.
  4. Apr 8, 2025 at 8:50 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Fast and accurate way is to get phone based OBDII app.
    I would recommend fusion obdII and BT adapter that works with you phone. You can get it running as soon Amazon delivers the adapter.
    Will cost you $30-40
    Make sure to turn off all loads to have a stable idle.
    Other way is to get Techstream. The process of jumper pins happens in Techstream, but you still need to move the stick.
    LbrTaco[QUOTED][OP] likes this.
  5. Apr 13, 2025 at 9:36 AM
    LbrTaco
    LbrTaco [OP] Member
    Just wanted to circle back and thank everyone for the tips . I ended up buying a cheap Bluetooth OBD2 plug in for about 25$ then the upgrade (to be able to read transmission temp) was also about 20$. I borrowed a temp gun and when the app said it as at 96 the gun was almost dead on as well. I was able to get this job done finally. Good thing too, I was a quart low.
    Thanks again
    RockBunny and #4TOY4ME like this.
