Can't get key out of ignition
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bamahoyt, Apr 15, 2012.
  1. Apr 15, 2012 at 1:50 PM
    Bamahoyt
    Bamahoyt [OP] Well-Known Member
    Ted
    Knoxville, TN
    2014 TRD Sport DC LB 4x4
    I got my new 1996 4x4 sr5 home today and I stopped, put it in park and shut her down and I could not get the key out. I went for a drive and then back and then tried again and cannot get the key out. I have been driving the truck all weekend with no problems in getting the key out and now it will not turn into the "lock" position to be able to pull the key out. It is a auto trans if that helps and I have made sure it was in park. Any help would be great as I don' t really feel like leaving my truck sitting with the key in it for someone to have a great day in. thanks in advance
  2. Apr 15, 2012 at 1:53 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Look under the dash around the brake pedal and and steering column to see if your foot has not unplugged the interlock switch; it should be a black box. If the steering wheel is locked too, give it a SUPERMAN pull down to reset the lock. Try to park your truck with the wheels in a straight ahead position in the future, too. Oh and if its not a Toyota key but some Hardware store variety, get a TOYOTA key cut (ask me how I know).
  3. Apr 15, 2012 at 2:05 PM
    Bamahoyt
    Ted
    Knoxville, TN
    I looked for the interlock switch but did not see any black box for it to be but I also did look pretty thoroughly and didn't see anything up plugged. The steering wheel is not locked either and the key won' t even turn out of the "ACC" position.
  4. Apr 15, 2012 at 2:12 PM
    Bamahoyt
    Ted
    Knoxville, TN
    haha yes it is.
  5. Apr 15, 2012 at 2:15 PM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
  6. Apr 15, 2012 at 2:18 PM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    do the first gens have the function where you turn teh key backwards (like your turning the truck off) to go to ACC? if so you may just need to turn it a click foward?
    probly already tried that a hundred times haha but oh well worth a try
  7. Apr 15, 2012 at 2:22 PM
    Madjik_Man
    Colorado Front Range
  8. Apr 15, 2012 at 2:24 PM
    jpneely
    Charleston, SC
    damn i need to start reading all the posts before posting haha...
    :D oops. proceed
  9. Apr 15, 2012 at 2:28 PM
    Bamahoyt
    Ted
    Knoxville, TN
  10. Apr 15, 2012 at 2:30 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    If the sterring wheel is NOT locked, SUPERMAN PULL (hands at 10 and 11 o'clock) and pull down to lock the column. When you get the key out you better find or have an original TOYOTA key made.
  11. Apr 15, 2012 at 2:32 PM
    Bamahoyt
    Ted
    Knoxville, TN
    Well the steering wheel wouldn't be locked unless the key is in the lock position am I correct. It is stuck in ACC so the wheel should still turn or am I mistaken?
  12. Apr 15, 2012 at 2:33 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Can you start the truck? No? Keep playing with that key. Tap it with a hammer back in then try to turn it. It's hooked up in there. Keep playing with that SOB.
  13. Apr 15, 2012 at 2:36 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    i blew the STOP LAMP fuse and i had the same problem, check to see if your breaklights work
  14. Apr 15, 2012 at 2:41 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    A fuse. Good call.
  15. Apr 15, 2012 at 3:48 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    So you figured out the problem?
  16. Apr 15, 2012 at 3:51 PM
    anthony250f
    Anthony
    San Diego, CA
    hes not the op
  17. Apr 15, 2012 at 3:55 PM
    Madjik_Man
    I couldn't get my key out.
    They ended up taking the whole assembly out, sending it to a locksmith who drilled out the cylinder, rebuilt it and rekeyed it.
  18. Apr 15, 2012 at 4:33 PM
    Bamahoyt
    Ted
    Knoxville, TN
    Thanks for all your help guys!!!! I drove it about 15 mins ago then parked at my house and gave it a real frustrated SLAMMMM into park and a smooth right jab and ... Pop she would turn and come up. I called the previous owner and he said he had problems with it sticking in the ignition like that every once in a while after he put the 1" body lift :notsure: and that you had to push the shifter towards the passenger seat some. Don't you just love those little quirks to our trucks. Looks to me like the key is pretty warn so I am going to have a new one cut. thanks for all your help guys!
  19. Apr 15, 2012 at 6:03 PM
    DNG
    DNG Well-Known Member
    Orange County, CA
    White 01 DC PreRunner
    Happens to my truck too. Sometimes I have to give my shifter another little click upwards after it's in park to completely disengage the key
  20. Aug 3, 2015 at 9:14 PM
    Helmetfire
    Helmetfire New Member
    Joe
    2001 Tacoma 4WD 4 door with TRD kit (locker in back).
    Custom Flat bed and rack, air bags (adjustable from cab), long travel suspension, True Track diff in front.
    I just fixed mine with the same problem. There are several interlocks. The one that got me was the shift interlock. I removed the plastic shift cover, then figured out that there is a switch that is triggered when the truck is in park. Only in my case the button you push down to shift wasn't coming back up all the way in park to trigger the switch. I had to file the slot in the shift lever smooth, then re-lube things. After that it works great.
    So, things to check:
    key is not worn out.
    Shift interlock switch.
