Can't get my lower shock bolts out??!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by RacerP, Oct 29, 2011.
  1. Oct 29, 2011 at 10:11 AM
    RacerP
    RacerP [OP] Well-Known Member
    Chicago
    2003 4x4
    7th Injector kit, Trans Cooler, Donohoe c/o's, Billy's in the rear, FJ Cruiser Trail Team SE wheels.
    I am putting in some ICONS and have the tops unbolted, have the bottom free but, the bolts won't come out at all!!
    I have hammered on it pretty good!
    What next?
  2. Oct 29, 2011 at 10:12 AM
    98tacoma27
    Ben
    Not Beech Creek
    Is the truck off the ground?
  3. Oct 29, 2011 at 10:16 AM
    RacerP
    Chicago
    2003 4x4
    Yeah...both sides on jack stands, wheels off. I have the nut off, but can push the bolt out.
  4. Oct 29, 2011 at 10:17 AM
    98tacoma27
    Ben
    Not Beech Creek
    It sounds like you still have pressure on the bolt. It's at full droop right?
  5. Oct 29, 2011 at 10:19 AM
    RacerP
    Chicago
    2003 4x4
    Yeah, full droop. I am trying to think how to take pressure off??
  6. Oct 29, 2011 at 10:21 AM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    Put the nut on and use a hammer to get the bolt started. Sounds like it may just be frozen or rusted in. You could spray it frist with WD40 or a loosing oil.
  7. Oct 29, 2011 at 10:23 AM
    TMW
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    If the top of the coil assembly is loose there should not be any pressure other than the weight of the spring and shock assembly
  8. Oct 29, 2011 at 10:25 AM
    TMW
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    If there is pressure loosen the four lower ball joint bolts, you should not need to take them out just loosen.
  9. Oct 29, 2011 at 10:26 AM
    99PreRunner.
    99PreRunner. ^ I no longer have a Tacoma
    Alex
    Mobile, AL
    2008 GMC 3500 Duramax 4x4 - CCLB
    x2
  10. Oct 29, 2011 at 10:31 AM
    RacerP
    Chicago
    2003 4x4
    On my one side I have hit it so much the lower shock mount is starting to bend out!!
    Maybe I will let it soak with PB for a while, but, I can't imagine how much that would do versus beating the hell out of it with a hammer??
    I have used a spreader to take all the pressure off where the upper is completely free of the upper shock mount.
  11. Oct 29, 2011 at 10:35 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Either use a punch and a hammer to get it out, ir cut it and buy a new bolt. Either grade 8 or 10 is sufficient for shear strength.
  12. Oct 29, 2011 at 10:38 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    I would try to loosen the bolt from the other side, if it is frozen if you can break the other side loose you could get it out, if not have one person loosen the head and another person hit it out.
  13. Oct 29, 2011 at 10:42 AM
    05tacoSPORT
    05tacoSPORT Well-Known Member
    Tennessee
    TRD SPORT
    Geared and Locked
    A pry bar pushing the LCA down "taking pressure off the shock" is the best way.
  14. Oct 29, 2011 at 10:43 AM
    TMW
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Just so I understand what you are doing. Are you trying to remove the coil spring and shock as an assembly? This would be the normal way, and the three top nuts for the coil are off? Or are you just trying to remove the shock leaving the coil spring attached at the top mount? If just removing the shock you may very well have pressure on the lower control arm and you will need to remove the 4 bolts at the bottom of the lower ball joint to drop the lower control arm.
  15. Oct 29, 2011 at 10:44 AM
    fidencio74
    fidencio74 Well-Known Member
    Fidencio
    Escondido, CA.
    2018 TRD Sport 4x4
    Stock for now
    Lose the sway bar, that will give you more room
  16. Oct 29, 2011 at 10:48 AM
    TMW
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Yes I forget about it. Good call.
  17. Oct 29, 2011 at 10:48 AM
    fidencio74
    Fidencio
    Escondido, CA.
    2018 TRD Sport 4x4
    Stock for now
    Make sure that you have another lower bolt. this one is stripped already. Don't do the same on the other side, just free the sway bar, I think they are 6mm hex bolt.
  18. Oct 29, 2011 at 10:58 AM
    RacerP
    Chicago
    2003 4x4
    Removing everything as an assembly, 3 bolts on top, and have the nut off the bottom.
    Upper sway bar link is unbolted...
    And I have completely taken the pressure off the suspension where the top is completely free of the upper shock mount.
  19. Oct 29, 2011 at 11:00 AM
    fidencio74
    Fidencio
    Escondido, CA.
    2018 TRD Sport 4x4
    Stock for now
    hit the bolt with a screw driver and a hammer. do you have a pic?
  20. Oct 29, 2011 at 11:04 AM
    HIYota
    HIYota Well-Known Member
    Angel
    Las Vegas, NV originally Kauai, HI
    09 Silver 6 spd TRD Sport DCSB 4x4
    Check my build thread...too much to list.
    Just put my new foxes on the truck 2 weeks ago. Maybe the pressure is coming from the weight if the shock and coil assembly. Try lifting the assembly a little as you pull the bolt out. Oh and WD40 sounds like a good idea also.
