Can't get my tach lights working
Discussion in 'Lighting' started by thewhiteknight, Mar 12, 2012.
  1. Mar 12, 2012 at 5:49 PM
    thewhiteknight
    thewhiteknight [OP] Well-Known Member
    Colby
    SW Alabama
    06 PreRunner TRD SR5 Dbl Cab
    foglight anytime, HIDs, lift, bilstein 5100s, AAL, LED interior, LEDs, BHLM, extended rear diff vent mod, upgraded audio system,
    Did the white led gauge swap and now my tach lights don't work? They all wok but the tach :( ??
  2. Mar 12, 2012 at 6:30 PM
    thewhiteknight
    Colby
    SW Alabama
    Oh well it looks ok. I'll just say I 'meant' to do it like this lol
  3. Mar 12, 2012 at 7:12 PM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    You swaped the led's on the tach? They probably arnt connected right or reverse polarity. Just buy 2 more white's and replace them.
  4. Mar 12, 2012 at 11:43 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    ^^^this...you might have not soldered them correctly..
  5. Mar 14, 2012 at 4:11 PM
    thewhiteknight
    Colby
    SW Alabama
    I went through 4 bulbs on each so I'm pretty sure 8 chips weren't defective an I checked it with a meter and they weren't getting as much voltage as the others.. So I don't know. Could the circuit board have gotten to hot or something?
  6. Mar 14, 2012 at 4:12 PM
    thewhiteknight
    Colby
    SW Alabama
    And reversed them about 2 or 3 times and they wouldn't work either way :(
  7. Mar 14, 2012 at 4:14 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    check to see if you didnt accidently dropped any solder around the board...that can cause a short
  8. Mar 15, 2012 at 6:27 PM
    thewhiteknight
    Colby
    SW Alabama
    I'll look for solder one day when I get bored but its back in the truck for now lol but if anyone else thinks of anything that it could be I'm still listening for help! Thanks
