Cant get my truck aligned after lift...HELP!?
Discussion in 'Suspension' started by MountainMan777, Mar 30, 2012.
  1. Mar 30, 2012 at 4:07 PM
    MountainMan777
    MountainMan777 [OP] Well-Known Member
    CA
    07 TRD Offroad Prerunner
    I just installed a set of fox coilovers and Total Chaos UCAs on my 07 prerunner, everything else is stock on the truck, the coilovers are adjusted to 3" and no one can align it now. Iv taken it to 4 different alignment shops and they all cant do it, I have a bad inner tie rod, but i dont think that should make it not algn-able? They say the inner tie rods are maxed out and dont have anymore thread to pull the toe in and the wheels are still toed out really bad. Anybody have any answer or suggestions for me? Id really appreciate any help. Iv even taken it to mechanics and 4x4 shops and no one seems to have a solution, they all keep referring me to other places and giving me different diagnosis of the problem i dont think anyone knows what they are talking about. Its so bad right now my tires squeal as i drive down the road and turn.
    Iv heard the tacoma spindles are kind of weak and although they work fine at stock height sometimes as the as the suspension droops out from a lift you get bumpsteer, and to replace your spindles may fix my problem any thoughts anyone?
  2. Mar 30, 2012 at 4:10 PM
    medic2230
    medic2230 Ditch Doctor
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    20% Tint, OME 3"complete lift with Dakar's, Light Racing UCA's, 285/75/16 Nitto Terra Grapplers, 10 HP TW sticker, Ultraguage, B.A.M.F. Rock Sliders, MedicFab Bed Rack, Relentless front bumper
    You trying to sell it now? Might get a better answer if you posted it in the right category.
  3. Mar 30, 2012 at 4:18 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    i think after 4 alignment shops and i cant tell how many different answers you said because you didn't say, i would start with the obvious and replacing bent inner tie rod and go from there. assuming alignment shops are reputable and they are obviously still in business, i can't say take it to another alignment shop because you already did that..................so ahmmmmmmmmmmmm get that bent rod replace and do it again for starters. my next guess is your set too high, are your cv angles really bad??????????
  4. Mar 30, 2012 at 4:30 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Tie rods control toe. Bad tie rod=no control over toe. If camber and caster are fine, and toe is the only problem, replace the tie rods. It'll take care of the problem.
    I have 3.5 front, and 4.5 rear. I had no problems with alignment. Vibrations? yes. A shim and diff drop will take care of that.
  5. Mar 31, 2012 at 10:11 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    You went to 4 different shops, got the same answer and still don't believe them? Why should what we tell you make any difference?
    Also, I've been told to do it, and did it... ask them to push the caster forward a bit.
  6. Apr 1, 2012 at 5:28 PM
    MountainMan777
    CA
    Yea my coilovers are set pretty high right now,but i thought that they woud be fine considering the rear of my truck is still stock and the front sits a little higher than the rear right now.
  7. Apr 1, 2012 at 5:30 PM
    MountainMan777
    CA
    I would just replace the tie rod but the place i took it to told me even if i replace the tie rod its not going to solve the problem because my bad tie rod isnt bent it just has some play in it right now, but the toe is still so far out and the inner tie rods have no thread left so they told me the problem must be something else like i need more parts with my lift and i should call Total Chaos.
  8. Apr 1, 2012 at 5:33 PM
    MountainMan777
    CA
    No, i got a whole bunch of different answers none of them being true. the only one that might be a probability only because i havent checked them yet is my frame may be bent? (but i dont know how) and i may need additional parts to go with my TC UCAs and FOX COILOVERS. Or maybe im set to high right now and need to lower them but they are only at 3"
  9. Apr 1, 2012 at 5:45 PM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series LC
    Tons and 40s
    Post pictures of the tie rods. GOOD pictures. and your alignment numbers
  10. Apr 1, 2012 at 5:48 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    You don't need any other parts, possibly lowering the coilovers will help but TC's are one of the best for alignments. I'd say fixing that tie rod is first and finding a better shop is second. Hell a dealership at this point will know more specifics for the truck and they'll prob charge you the same amount.
    What are your measurements? Hub to fender?
  11. Apr 1, 2012 at 9:24 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Lives: Pyeongtaek, South Korea/Home: Leesburg, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    his profile says prerunner. doubt he has bad cv angles
  12. Apr 1, 2012 at 11:50 PM
    k9cop
    k9cop if your not the lead dog, the view never changes
    Farva
    Hogwarts
    10 tacoma dbl cab trd off road prerunner
    CST 3.5" spindles, King 2.5 rr ,All Pro Expo's, Ext. Billy 5100's rear, Ext rear All Pro brake lines, LR UCA's, debadged, Cobra 29,2ft firestick, satoshi by jim, ARB front bumper, Smittybuilt xrc8 winch, wethatecs, bhlm also by jimbob, belgium malinois and German Shepherd in bed
    go back to everything stock and get spindles..
  13. Apr 2, 2012 at 10:06 AM
    MountainMan777
    CA
    Ok ill post pics once i get a minute, but the readings are
    Drivers side
    Camber:-0.1
    Caster: 3.3
    Toe:-2.44
    Passenger side
    Camber:0.6
    Caster:6.1
    toe: -1.50
  14. Apr 2, 2012 at 5:41 PM
    MountainMan777
    CA
    the camber and caster are off to, but the toe the most. iv heard my spindles might need to be replaced or i might need TC lower control arms but i called Total Chaos and they told me i didnt need any of these with my kit so idk what the hell to try next?
  15. Apr 2, 2012 at 5:49 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    LIFT SPINDLES
  16. Apr 20, 2012 at 12:43 AM
    MountainMan777
    CA
    Alright ill try that thanks for the tip man
  17. Apr 20, 2012 at 12:44 AM
    MountainMan777
    CA
    I already have to much money invested into my new coilovers and UCAs to just eat it all and buy spindles plus i want suspension in front not just lift
  18. Apr 20, 2012 at 12:45 AM
    MountainMan777
    CA
    I actually got my inner tie rod replaced and its still off and cant get it straight. Im thinking maybe i have a bent spindle or my LCAs mounts on that side are bent.
  19. May 3, 2012 at 5:41 PM
    anthony250f
    Anthony
    San Diego, CA
    dude are you serious?spindles add to your suspension, it will make it 1000x better....
  20. May 3, 2012 at 5:47 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Shit dude, that sucks!
