Can't get online with Macbook
Discussion in 'Technology' started by Coma2010, Dec 8, 2017.
  1. Dec 8, 2017 at 8:43 PM
    Coma2010
    Coma2010 [OP] 2012 TRD Off Road Prerunner
    Dustin
    Glendale
    2012 TRD PreRunner Dbl Cab
    I have a Macbook Air... in the last week I have been unable to get online through safari. It just comes up and says Safari is unable to find page. Or it will give me a pop up saying another computer is using my IP address and to change it... I am not a Mac person or all that into computers to try and fix this. Any help would be appreciated.
  2. Dec 8, 2017 at 8:45 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    1. If this is at your home, have you tried restarting your modem and router by unplugging the power (thin black cable) to them for a few seconds?
    2. Have you tried getting online at a different wifi location like a coffee shop? This will help determine if it's your computer or home network. Sounds like the network though...
  3. Dec 8, 2017 at 8:47 PM
    Coma2010
    Dustin
    Glendale
    No have not tried that because I'm on it now.... I tried to use it 4 different times today and couldn't and I just tried and it worked. but thats how its been off and on for a week or so.
    No haven't taken it anywhere to see about it working on another wifi
  4. Dec 8, 2017 at 8:53 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I use a Macbook with safari and don’t have issues. Have you tried installing another browser? Are there other computers or devices on your home network.
  5. Dec 8, 2017 at 8:55 PM
    Coma2010
    Dustin
    Glendale
    Yeah i tried google chrome and same issue. no other computers just phones and tablets
    Ill have to try and reset the modem.... but once i do i don't know if ill be able to get back on TW on the computer
  6. Dec 8, 2017 at 9:06 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Reset the modem first, then the router if separate. The router will remember the settings as will the Mac. Can you connect via WiFi on your phone/tablet? Or is it falling back to LTE?
  7. Dec 8, 2017 at 9:14 PM
    07regtacoman
    07regtacoman Well-Known Member
    Davis Ca
    07 Silver REG Cab
    Painted arm rests, 2011 front grille,Readylift for 5lug.
    disconnect your Mac from the wifi than try logging on again.Sometimes that helps just disconnecting.
  8. Dec 8, 2017 at 9:14 PM
    Coma2010
    Dustin
    Glendale
    Ive tried that and no luck
  9. Dec 8, 2017 at 9:17 PM
    jshsltr
    jshsltr Well-Known Member
    Josh
    St Louis
    I have had this issue before on my MacBook. The reason was that once you sign on to WiFi with the MacBook,it tends to store the ip address that was assigned by the router. If at some point the MacBook was turned off and the router assigned the same ip address to another device, the MacBook will have issues connecting to the internet. This should be resolved by powering down or turning WiFi off on any devices that connect to your router including the Mac. Then reboot your router. Then power the devices back up one at a time after the router is back online starting with the Mac.
    crashnburn80 likes this.
  10. Dec 8, 2017 at 9:26 PM
    Coma2010
    Dustin
    Glendale
    Thanks for the information I didn't know it stored IP address or two devices could get the same address.
    I just unplugged the modem/wifi for a few and the computer let me get right back on.
    Thanks for all the help
    jshsltr[QUOTED] and crashnburn80 like this.
  11. Dec 8, 2017 at 9:27 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    After turning off/on your laptop WiFi, rebooting the modem/router should be the first go-to. It will resolve most issues.
  12. Dec 8, 2017 at 9:28 PM
    Coma2010
    Dustin
    Glendale
    Must have been the modem... unplugged it and it all works now. thanks
