Can't get rear axle back in
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jerrymax, Sep 7, 2014.
  1. Sep 7, 2014 at 9:57 PM
    Jerrymax
    Jerrymax [OP] New Member
    Jerry
    95 2 wheel drive
    I removed the rear axle to have the bearing replaced and now I can't get it back in. It sticks out about the same depth as the spline. Not sure how much force to use. I was planning to do one side at a time, so the other side is still in.
    "95" 2 wheel drive
  2. Sep 7, 2014 at 10:00 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Pictures? I am not sure myself, BUMP!
  3. Sep 7, 2014 at 10:17 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    Should slide right in the splines. Assuming the bearing and all was replaced and reassembled correctly.
  4. Sep 8, 2014 at 10:18 AM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    turn the wheel some to align the splines. you make also need to align the end to get it perfect. just keep wobbling the end around.
  5. Sep 8, 2014 at 10:29 AM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    carefully jiggle and angle it around, being mindful of the seals. The splines are probably not matching up quite right, orientation wise.
  6. Sep 8, 2014 at 10:31 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    So to recap, just jiggle the end and it'll eventually slide right in :)
  7. Sep 8, 2014 at 10:39 AM
    TacoLlama
    TacoLlama Well-Known Member
    R.I.
    2019 SR5 DCSB
    Yeah sometimes you have to lift the splined side up a little to get it started.Usually some manipulation on the side you can grab will get it in.Keep a little pressure on it and push the bottom in and pull the top out a little.That will lift the splines up enough to get in the bore.Then a few turns with a little pressure and the splines will go right in.Watch your fingers.
