Can't get rear locker to lock
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jrain904, Feb 3, 2017.
  1. Feb 3, 2017 at 2:32 PM
    jrain904
    jrain904 [OP] Well-Known Member
    Hey. I have tried to lock the rear locker but the indicator light never quits blinking. I followed the instructions in the manual. is there a trick to getting it to lock? 2017 TRD OR.
    thanks
  2. Feb 3, 2017 at 2:35 PM
    beyer075
    beyer075 Rock Licker
    Northern Nevada
    2016 White TRDOR
    Tried driving forward and turning the wheel slightly? I've had to do that a couple times.
  3. Feb 3, 2017 at 2:38 PM
    Cold_Toad
    Cold_Toad Well-Known Member
    Do this, but nice and slowly so that everything can line up like it should.
  4. Feb 3, 2017 at 3:18 PM
    stevebaz
    stevebaz Well-Known Member
    2016 access cab, TRD offroad 4x4, Quicksand
    Were you in 4wd low range first?
  5. Feb 3, 2017 at 3:25 PM
    eon_blue
    Azusa, CA
    If you're 4wd then you need to be in 4lo for it to engage. I'm not sure what the restrictions are on the 2wd TRD OR model, I think you have to be going under 15mph for it to engage?
    Rolling forward a few feet and turning the wheel side to side seems to help. Everything has to be properly lined up so it will rarely engage right away when you press the button, I usually have to drive forward anywhere from a few to up to 15-20 feet before mine locks in.
  6. Feb 3, 2017 at 4:25 PM
    jrain904
    thanks everyone. The advice worked!
    beyer075 and ManBeast like this.
  7. Feb 3, 2017 at 6:47 PM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    What advice?? Which one worked??
    G.
