Can't get that damn climate control panel off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Marky, Oct 27, 2014.
  1. Oct 27, 2014 at 5:18 PM
    Marky
    Marky [OP] Well-Known Member
    Roanoke VA
    2014 DCLB Super White
    FLTruck's 2014 OEM Nav upgrade!
    I want to put a 120V outlet in one of my center console blanks, tapped off the inverter output. I can't get the climate control panel off to access the blanks. I just had that panel off a few weeks ago when I installed my new nav unit and it wasn't a problem at all. Now I can pop the bottom clips off but can't get the top clips to come loose, despite what I consider excessive force. I'm going to be very unhappy if I keep yanking on it and break something. Anybody else had this situation??
  2. Oct 27, 2014 at 7:14 PM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    I used a very thin paint scrapper to wedge between the top and help persuade the clips to release.
  3. Oct 27, 2014 at 7:15 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I used a putty knife
  4. Oct 27, 2014 at 9:01 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Use a Plastic Putty Knife.
  5. Oct 27, 2014 at 9:02 PM
    OZ-T
    Peter North
    British Columbia
    I put painters tape on mine
  6. Oct 27, 2014 at 9:15 PM
    mbroughton02
    mbroughton02 Well-Known Member
    Michael
    Cortland, NY
    07 DCLB
    OME 884, 5100s, Wheeler's 1.5" Progressive AAL, Firestone Ride Rite, Fisher Homesteader 7'4" Plow, Heated Seats, Viper 5806v Remote Start / Alarm.
    I once made the mistake of getting the bottom released before the top. Was at nearly a 45º angle. What happens if you do that is it can jam under the radio bezel just above it. Try pushing up on the bottom lip of the radio bezel, and then pushing the climate control panel back in. Then "start over" and try to pull straight out this time.
  7. Oct 27, 2014 at 9:16 PM
    Traviste
    Traviste Now with more woopow
    Travis
    Georgia
    2014 DCSB Locked 4x4 Mid-Travel
    F:King 2.5 coilover resi ext 700#coils R:King 2.5 ext allpro expos
    This is your best bet. I did the same thing and had it jammed
  8. Oct 28, 2014 at 5:06 AM
    Marky
    Roanoke VA
    This sounds exactly like what's happening. Many thanks; I'll try again.
