Can't get the tire off!
Discussion in '1st Gen. Tacomas (1995-2004)' started by elkshedz, Jan 31, 2015.
  1. Jan 31, 2015 at 1:45 PM
    elkshedz
    elkshedz [OP] Taco lover
    50 miles from nowhere in NoAZ
    1998 Tacoma V6 ExtraCab Limited
    OK, so I've skinned my knuckles, banged my head a few times, and have run out of patience. So I'm turning to you guys, the experts.
    Here's the story: I was out hiking, 6 miles down a forest service road from the main highway, and I got a flat tire. When I tried to put the spare on, it seemed to be very tight around the center hub, basically a metal cap. I had to force the lug nuts on several times until they were tight....very tight.
    Took the truck to the shop the next day to have a new tire put on (irreparable: sidewall damage) and they couldn't get the spare back off to put on the new tire. With no other choices, I brought the truck home, jacked it up, tried getting it off myself and ended up chiseling off the center cap to see if that would help. It didn't. (And yes, I did take off the lug nuts first)
    I've tried pushing, pulling, prying, praying and cursing to no avail.
    My only other idea is to get a wheel puller and try to work it off that way but I'm not sure if that's the way to go. Not wanting to spend a fortune on one, either.
    By the way, I live in the sticks and I'm an hour away from any town/city so it's not like there's a AutoZone right around the corner.
    Any help would be greatly appreciated. I need to get back out hiking.
    98 Tacoma
    BD
  2. Jan 31, 2015 at 1:52 PM
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    try putting lug nuts back on,leaving them a thread or two loose,drive back and forth in driveway and see if it come frree of center hub
    Kevlarster likes this.
  3. Jan 31, 2015 at 1:56 PM
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    Wow, good luck, I have never had anything like that happen.
    I like the loosnut suggestion, he should know.
  4. Jan 31, 2015 at 2:03 PM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    Icon ext. travel 2.5RR in front, Icon ext. travel 2.0RR in rear, BuiltRight uniball UCAs, Wheelers Superbumps, Goodridge steel braided brake lines, BruteForce front plate bumper w/ Warn M9000+synth line, American Auto Horns ACDF, Pelfrey Bussman mount+Sandman bussman fuse block (soon), 255/75R16s on painted stockers...because I'm not paying $800 to rock rash new wheels you scrubs. Shok Industries 2/0 big 4 upgrade and sound deadener.
    Or jack it up and leave one lug nut on a couple threads and smack it with a dead blow a few times.
  5. Jan 31, 2015 at 2:19 PM
    elkshedz
    Good idea. Tried it but it's just stuck on there way too hard. I even drove on the shoulder of the road, over rocks, etc. but no luck. Any other ideas?
  6. Jan 31, 2015 at 2:20 PM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    That's a great way to break off wheel studs. I would go the dead blow hammer route.
  7. Jan 31, 2015 at 2:23 PM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    Subd to see the out come.
    Very strange. Never heard of that happening before.
  8. Jan 31, 2015 at 2:26 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    It sounds like the it was the wrong rim...I would try heat...if not, start cutting the rim and get a pry bar or chisel/wedge behind it.
    Howard
  9. Jan 31, 2015 at 2:29 PM
    elkshedz
    I think you're right about being the wrong size rim since it required so much force to get it all the way on. By the way, I'm not sure what is meant by a "dead blow hammer".
  10. Jan 31, 2015 at 2:31 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Dead blow is a hammer, usually plastic, with beads or sand inside to deaden the blow.
  11. Jan 31, 2015 at 2:34 PM
    crainholio
    crainholio Well-Known Member
    Tough to answer but check here for specifics:
    Dead Blow Hammer info
    Good luck to the OP, I'm guessing it's torch time.
    Or drill & tap a pair of holes 180deg apart like the rear brake drums are designed for removal.
  12. Jan 31, 2015 at 2:35 PM
    elkshedz
    Not sure I understand how hitting the lug nut would loosen the rim...
    Anyway, the closest thing I have is a rubber mallet.
  13. Jan 31, 2015 at 2:37 PM
    hetkind
    Howard
    Johnson City
    No need for a dead blow since the rim is scrap...I believe destructive removal is in order.
    Howard
  14. Jan 31, 2015 at 2:39 PM
    53wick
    53wick Well-Known Member
    kentucky
    2014 accesscab prerunner
    you might try like the one guy said put the lugs on it loose, then take a floor jack and jack the other wheel off the ground with the jack sideways so it can roll, then heat the hell out of it, then grab the side of truck and start rocking it back and forth hard
  15. Jan 31, 2015 at 2:40 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Put a couple of lugs loosely on the rim then start the truck and put in gear. Now hit the throttle, crank the steering wheel and slam on the brakes. It might take a few attempts.
  16. Jan 31, 2015 at 2:43 PM
    arifleman
    arifleman Well-Known Member
    Pacific NW
    2002 TRD 3.4L Ext Cab
    I might try lifting the wheel, pulling the lug nuts and using a bottle jack from the other side, maybe braced against a tree, rockery, or even the opposing wheel.
  17. Jan 31, 2015 at 2:43 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Hit the wheel not the lugs. Put a nut on so if/when the wheel comes off from the hitting it won't fly across the room.
  18. Jan 31, 2015 at 2:44 PM
    VintageFast
    VintageFast Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    Sledgehammer & leather gloves
  19. Jan 31, 2015 at 2:50 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    I'd suggest against using the opposing wheel.
    You had to break the center cap off? If you can get the wheel off without damaging it, it would probably fit without the extra metal from the cap.
    What I would do:
    Jack that wheel up and put jack stands under two points that will support that corner (you're gonna be under it and 2 are better than 1). Remove all lug nuts. Drain air from tire. Put board across back of wheel. Give it a few smacks with mallet or sledge hammer. Rotate wheel 90*. Repeat.
    Once the wheel is off, remove all material remaining from center cap. Check if it will go back on without having to use force (if the wheel and tire are in damaged from any previous attempts).
  20. Jan 31, 2015 at 4:07 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Do the loose nut thing it works just shift forward reverse several times.
