Can't get the tire off!
Discussion in '1st Gen. Tacomas (1995-2004)' started by elkshedz, Jan 31, 2015.
  1. Jan 31, 2015 at 4:21 PM
    Phil5393
    Phil5393 Well-Known Member
    Phil
    Long Island, New York
    TRD Sport
  2. Jan 31, 2015 at 4:52 PM
    nswsparky
    nswsparky Well-Known Member
    Chad
    Minnesota
    '03 TRD, SAS, ARB's F/R, Atlas 4 speed
    D44, SAS, 3 link coilovers, ARB's, Ford 8.8, Atlas 4 speed, cutting brakes.
    if it is a steering tire stick something between the frame and the tire turn it against it use the power steering to pop it off.
  3. Jan 31, 2015 at 6:58 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    I don't have any info to get the rim off but I do think I know why it happened...that rim is hub centric, so, there is NO room for that center cap when mounting the rim. when the rim was mounted with that center cap installed its was basically pressed on like a big ass bearing(metal from the center cap is totally squished/wedged between the hub and wheel) when the lugs were tightened down. You pry were using some Chevy alloys weren't you?(not hub centric so those caps work just fine with those rims)
  4. Jan 31, 2015 at 7:09 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    expect to need a new rim, most likely the rim wasn't ever right and your just finding out now.
    go where they have a lift and put it in the air, loosen a few turns each but don't remove the lugs, use a 30 pound sledge hammer on the rim to break it free, then put your rim and tire back on and go to the salvage yard to get a proper fitting spare rim.
    just don't go Hercules on the rim, you don't want to damage the rear axle bearings and seals so whack it in and out in a few spots as you rotate around it so you get it broken free and give it a damn good soak with wd40 or penetrating fluids
  5. Jan 31, 2015 at 7:11 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    kick the f**k out of it! Get some real good hits on the top of the tire, maybe over inflate it a little so it absorbs less impact.. looks like you put the center cap on there with a hub centric wheel, so the metal is squished between the hub and the wheel. Only way to break that free is brute force
  6. Jan 31, 2015 at 9:41 PM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    Put it on jackststands and use the widow maker and some boards against the frame to push it off. Wheel is most likely rurnt anyway.
  7. Feb 1, 2015 at 1:35 AM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    I don't know how to get your wheel off, but however you do it check the studs afterward. If there are any burrs or the lug nuts don't go on smoothly then clean the threads with a die.
  8. Feb 1, 2015 at 5:46 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    So.................. did you get it? :confused:
  9. Feb 1, 2015 at 9:00 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    This is exactly what happened. He needs to loosen the nuts like several people have mentioned and do a short hop in the driveway.
    I love your assumptions and recommendations. :rolleyes:
  10. Feb 1, 2015 at 9:01 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Applying heat to the wheel with a butane torch, before pounding, might make things easier.
  11. Feb 1, 2015 at 9:46 AM
    elkshedz
    elkshedz [OP] Taco lover
    50 miles from nowhere in NoAZ
    1998 Tacoma V6 ExtraCab Limited
    The sledgehammer approach seems to be the one that would likely work, if anything. I've tried it but without rotating the tire 90* as you suggest. Also, I don't have jack stands so about all I can do is stack 2x6's. I'm also finding it difficult to get a good, solid smack with the hammer with the limited room underneath the truck. I'll give it another go before the big game.
    Also, why deflate the tire?
  12. Feb 1, 2015 at 9:52 AM
    keakar
    karl
    louisiana
    "if" the rim isn't hub centric then its likely someone grabbed a rim from a camry or corolla because it had the same bolt pattern yet the hub size isn't the same.
    as to the 30 lb sledge, a large hammer delivers a good "shock impact" without needing a hard blow to do it so it is much safer then banging the shit out of it with smaller hammers.
    and the rim may have been bent since it was obviously forced on too tight and couldn't seat correctly.
    expectations of the rim being reusable after it is forced off should be low if being realistic, but it might be ok.
    you and others think its fine to risk the weight of the truck ripping the wheel loose (along with bending or breaking the studs off the hub) and you think this is god advice, maybe if you want to do more damage to the truck :rolleyes:
  13. Feb 1, 2015 at 9:57 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    A filled tire has a good bounce to it.
    By using a piece of wood and rotating the tire, the wood hits the wheel/tire instead of the sledge. It also gives a greater area of impact which can help to not damage the wheel/tire.
    With the center cap on, it basically became a press fit. By rotating the tire between hits, it will "walk" the wheel off instead of trying to pry it off.
  14. Feb 1, 2015 at 10:04 AM
    keakar
    karl
    louisiana
    no, I was never that stupid, that's why I said hit the rim with it. duh!
    I assume if its loose enough to move with leveraging a board on it then he wouldn't be needing help asking how to get it off. yes of course if a board works that's the safest way but he said it was frozen on solid so a hammer to shock it free is most likely the thing it will need but prying with leverage (when possible) is always preferred to hitting something
  15. Feb 1, 2015 at 10:30 AM
    #35
    windsor
    windsor Just a guy
    Homeless in Oregon
    Sorry to confuse you keakar, that post was directed towards OP. My signal is spotty today, so it takes a little bit for it to get through.
  16. Feb 1, 2015 at 10:41 AM
    #36
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    This. The spare wheel was most likely OEM, so it was designed to go on the hub without the center cap.
    I recommend acquiring a wheel puller. Too much hammering/prying risks damaging the wheel hub / halfshaft in the axle.
  17. Feb 1, 2015 at 10:53 AM
    #37
    webb323
    webb323 Well-Known Member
    Jordan
    Tennessee
    97 4x4 Regular Cab (sold), 2014 Double Cab TRD Sport
    The sledge hammer is the way to go. Sledge hammer to the back of the wheel. I've had to do this a quite a few times working at a tire shop. People put the wrong wheels on more than you would think. You may have to hit it really hard quite a few times. And heating it first would help.
  18. Feb 1, 2015 at 12:50 PM
    #38
    bry838
    oregon
    Keaker, I believe he means hitting the 2x4 WITH the sledge(as to not create damage)....not prying or trying to leverage it off...
    On another note he doesn't have a Camry or corolla rim. Its an OEM spare. Camrys and corollas don't have anywhere close to a 106mm hub bore. Or six lugs.
  19. Feb 1, 2015 at 1:27 PM
    #39
    keakar
    karl
    louisiana
    well he said he put THE spare tire on, he never said he was sure it was the OEM spare tire.
    do you have any idea how many trucks are running around with non OEM spares on them?
    also a camry rim wont fit a 4wd but it will fit the lug bolt patterns on a 2wd taco and fit tight enough to wedge itself on the hub so its jammed in place, espescially if the cap is left on.
    also dodge rims will fit the lug bolt patterns on chevy trucks but fit tight enough to wedge it on the hub so its jammed in place. its a fairly common issue on old trucks to find previous owners just threw any spare tire under them. so you cant "assume" (as you are doing) that it is an OEM spare rim unless you know the history of the truck.
  20. Feb 1, 2015 at 2:11 PM
    #40
    crainholio
    crainholio Well-Known Member
    keakar, you've been giving wrong advice again and it's time to put the keyboard down...
    It's a 6-lug hub as the pic in Post #1 shows, so the whole Camry thing is out the window.
