Can't get this sticker off
Discussion in '3rd Gen. Tacomas (2016-2023)' started by fsbrain03, Jan 14, 2013.
Has this thread helped in your journey through life?
  1. Yes
    278 vote(s)
    19.7%
  2. No
    187 vote(s)
    13.2%
  3. Maybe, I can't tell
    216 vote(s)
    15.3%
  4. I have a unicorn
    733 vote(s)
    51.8%
  1. Jan 14, 2013 at 8:07 AM
    fsbrain03
    fsbrain03 [OP] Well-Known Member
    I just recently purchased a 1994 Toyota Pickup It runs like new the tires are all aired up and look good The wheels need a little polishing but I figure I could get some help on here on shining those suckers up The interior needs a bit of work but nothing a little TLC cant take care of The dash is in shambles but I'll just drape a flag or some sort of cloth over it and good as new Any suggestions (just realized I have used no punctuation marks yet. I don't plan on going back and adding them either). Continuing on. The motor has 230,987 miles on it, and I was told the Tranny is "pretty new".
    So now that the introduction of the new rig is out of the way. I have some questions. Instead of starting many different threads, I'll post them all up in here. Let me know if I need to start a new thread for each topic, and I will do so.
    This truck had a bunch of window decals. I mean a lot. I don't know how this guy drove this thing down the road without getting ticketed every time. I mostly have all of the window decals removed, some of them have been on a while, and were sun baked. On a couple of them, I broke out the torch, and either burned or melted them off. Worked for the most part, and that's all I'll say about that.
    One sticker is on the tail gate, and it's still there. I'm not sure how to remove it from the truck without messing up the paint. I need to remove it quick though. I live in a smallish town, and the local folks don't appreciate it. It has to do with a gay unicorn or something about church? Are unicorns gay? Anyway, what are your thoughts on getting this thing off, and how can I do it quickly without making a mess? If you really want to see the picture. Google "Gay Unicorn Sticker". There is one that says something about being a priest in the church of gay. This sucker is huge, takes up the entire tail gate. Any suggestions are welcome here.
  2. Jan 14, 2013 at 8:08 AM
    Cain
    Cain Well-Known Member
    Southern California
    2012 Tacoma
    Chrome don't get you home
    Hair dryer and goof off and a plastic type scraper with a good edge
  3. Jan 14, 2013 at 8:09 AM
    fsbrain03
    Hair dryer? Am I drying the Unicorns hair? Doesn't seem like that would work at all.
  4. Jan 14, 2013 at 8:10 AM
    FastEddie
    FastEddie Well-Known Member
    MD
    2012 super white access cab, base model
    if its just the glue residue use goo gone then wash your truck. if you need to peel the sticker i use a steamer and pull it off slowly
  5. Jan 14, 2013 at 8:11 AM
    FastEddie
    MD
    hair dryer will work. you just need to apply heat to loosen the adhesive
    ScrippsRanch67, willie2 and Vmax540 like this.
  6. Jan 14, 2013 at 8:11 AM
    fsbrain03
    Steamer? I have one that I use on my carpet. Should i just run it over the tail gate like I do on my carpet? May be hard to hold it up without spilling the water everywhere.
  7. Jan 14, 2013 at 8:14 AM
    FastEddie
    MD
  8. Jan 14, 2013 at 8:14 AM
    fsbrain03
    Help please! I have to drive through town in a bit, and not sure the locals can take much more of this.
    Let me go try the hair dryer
  9. Jan 14, 2013 at 8:15 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    ^ that's some good advise right there! :thumbsup:
    Barcelona Rahab likes this.
  10. Jan 14, 2013 at 8:15 AM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    Warm soapy water?
  11. Jan 14, 2013 at 8:15 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Hair drier, as suggested earlier, or a heat gun on low setting. Don't let the paint get too hot because it can do damage. Go slowly and use a soft plastic squeegee, like you'd use if you were tinting your windows. It should come right off. Then use a cleaner for the residue, if any is left. You want to use the weakest cleaner that will get the job done. Start with something like WD-40 (if simple car wash soap won't take it off).
    leftright, MikeyD.25 and cwthrn like this.
  12. Jan 14, 2013 at 8:17 AM
    fsbrain03
    Well, just tried the hair dryer, and all I had to scrape was a paint scraper. That didn't go so well, the paint bubbled up under the sticker. I stopped before more damage happened.
  13. Jan 14, 2013 at 8:17 AM
    fsbrain03
    Thanks a lot for that horrible advice guys!
  14. Jan 14, 2013 at 8:19 AM
    TeamSarcasm
    The better coast
    You used a paint scraper and thought that was a good idea? :rolleyes: Don't bitch at us, for your stupidity. A plastic scraper was suggested
  15. Jan 14, 2013 at 8:20 AM
    fsbrain03
    Hey, I saw scraper of some type. Plastic preferred. I dodn't have a plastic scraper, so metal was my best bet.
  16. Jan 14, 2013 at 8:20 AM
    Pugga
    Massachusetts
    It's not horrible advice, you just have to be smarter than the hair drier. Look on youtube for sticker removal and a lot of the videos will use a hair drier or a heat gun. It is the best way to get a sticker off but you have to go slow and you can't get it too hot.
    Also, you used a metal paint scraper, what did you think would happen?!?!?!
    Mark77, rev25sharp, Deet and 2 others like this.
  17. Jan 14, 2013 at 8:21 AM
    fsbrain03
    Yes, seems like this could work. Maybe i'll try heating it up again, and then sand. I have an 80 grit, will that work?
  18. Jan 14, 2013 at 8:22 AM
    fsbrain03
    According to your post, the sticker would come right off. Well, it didn't!
    Barcelona Rahab, seanb06 and AxisCab like this.
  19. Jan 14, 2013 at 8:22 AM
    dlooney
    dlooney Well-Known Member
    Dennis
    Wilmington NC
    07 TRD Sport PreRunner
    Satoshi w/ hella 500s mounted behind, 20% tint, 6K HID retro headlights, 4300k HID fog lights, DTRLs, plastidipped front valence, cb mount
    You sure it was paint bubbling up?
    ...either way, don't use a paint scraper...that's a great way to scratch your paint.
    cwthrn likes this.
  20. Jan 14, 2013 at 8:23 AM
    fsbrain03
    Not sure? I just saw a bubble under the sticker, and stopped. After i stopped I tried to push it back down, and burned myself. So, another horrible idea.
