Can't get truck into 4Lo
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dave l, Jun 2, 2008.
  1. Aug 7, 2010 at 12:54 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Yup... use it or lose it!
    Seriously, H4 is shift on-the-fly 0-55 mph, and to go on to L4 is 'shift when STOPPED' and tranny is in NEUTRAL (not PARK) for those with Automatics.
    What takes some repeated attempts at in all three of my Tacomas has been locking the rear differential... Now, with A-TRAC, I don't have to!
  2. Aug 7, 2010 at 12:55 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    This is why I love my second stick....wait...(that's what she said). I wish car and truck manufactures would keep things simple, more hands on user interface, not a push button or switch to push. Good luck on the dealer helping you, sometimes they shrug their shoulders and play dumb.
  3. Aug 7, 2010 at 1:26 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    My 4wd system has worked flawlessly so far (3 years.) Getting into and out of 4lo used to require a bit of finesse. If it won't engage/disengage try going forward or backward and turning the wheel a bit then get back into neutral or push in the clutch before attempting again. The more you use it the easier it gets. Also, for a smooth and quiet disengagement without getting the "clunk" sound when going from 4hi back into 2wd let off the gas to where theres no load on the driveline then shift.
  4. Oct 4, 2015 at 9:02 PM
    Theoshow
    Theoshow New Member
    2011 Tacoma trd
    I have a 2011 that will shift into 4 hi perfectly every time also.. And when I switch to low range it never works.. I put in nuetral try backing up going forward sit there for 5 mins it just constantly beeps and flashes..
  5. Oct 5, 2015 at 8:38 AM
    David K
    If you are in Neutral, you can't back up or go forward... Neutral is being not in gear.
    Put the transmission in N (Neutral) and then rotate while depressing the transfer case dial (4WD dial switch) from H4 to L4. No beeping or flashing if you are in Neutral when doing that.
    To go back to H4 from L4, you also need to be in Neutral. Most fail because they put the transmission into P Park, instead of N Neutral.
  6. Oct 5, 2015 at 8:47 AM
    jmd025
    jmd025 Well-Known Member
    Louisiana
    2010 TRD double cab 4x4
    I'm new around these parts ... But I swear I'm shocked at the sheer number of people who cannot operate their transfer case properly .
    The manner of shifting it is unchanged from the way it's done for decades , and from various manufacturers .... Only now there are a couple electronic Nannys to deal with .
    Toyotas tcases arent magical or unicorn like in their operation.
    Only caveat is that with solenoids , if you don't exercise them they may or may not function .
    Ugly Betty likes this.
  7. Oct 5, 2015 at 9:09 AM
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    I wish it was that simple, unfortunately, not only can you not fix stupid, but it is not the answer in all situations.
    I have hundreds of hours in 4Lo, and nearly the same in 4Hi.
    If you had this happen to you, especially after having it work fine for years, then you would understand that it simply does not switch in and out as expected, with no warning, no matter how many ways you turn or reverse or go up or down a hill. There is a beeper in case you're doing it wrong too.
    The last time this happened to me I was on the trail, and it simply would not disengage from 4Lo. So I ran it for another hour, probably shut the motor off at least once, and the next time I switched to 4Hi, no problems.
  8. Oct 5, 2015 at 9:35 AM
    jmd025
    Louisiana
    I was singling no one out .
    I've shifted many a t case , and experienced binding that can keep a weak or poorly adjusted (or failed) linkage from shifting , as well as taken corrective action to remedy this in the field , sometimes drastic . If your t case is abnormally worn , or shift mechanisms failing , ok .
    I still stand by the statement that 90 some odd percent of the "won't shift" threads I've read here boil down to technique . The techniques apply whether it's a 85 k5 blazer , 2015 Tacoma , or whatever (electronic Nannys taken into account )
  9. Aug 1, 2016 at 4:37 PM
    MK42
    MK42 New Member
    Colorado
    2016 TRD Sport/1996 Taco
    I was having difficulty shifting in and out of 4low. Only would engage/disengage by cycling the engine. Read this thread, realized I had the clutch pedal in all the way but not !!FIRMLY!! Pressed to the floor. Engages/disengages 100% now I know the proper way.
    NAAC3TACO[QUOTED] likes this.
  10. Aug 1, 2016 at 5:56 PM
    little squirt
    little squirt 808 ALLDAY!!
    808 ALLDAY!!
    i have to put on my emergency brake for 4lo to engage. i have a 6spd though.
  11. Jul 5, 2018 at 1:34 AM
    casey2012
    casey2012 Well-Known Member
    mark
    yota
    none
    any body have problems getting in 4 low on there 2nd gen tacoma
  12. Jul 5, 2018 at 1:40 AM
    fleckosaurus
    fleckosaurus Certified Toyota Enthusiast
    Brian
    Versailles, KY
    2024 Tundra
    with an auto trans: while the truck is moving shift from 2H to 4H when it engages stop moving, put the truck in neutral, and then switch to 4L
    scottalot likes this.
  13. Jul 5, 2018 at 1:45 AM
    casey2012
    mark
    yota
    none
    mine is standard trans.
  14. Jul 5, 2018 at 1:45 AM
    Tootall604
    Tootall604 Well-Known Member
    2015 Tacoma sb
    With the manual, I sometimes have to reverse a little bit before it will go into 4L
    Or out.
  15. Jul 5, 2018 at 2:03 AM
    #35
    Mongoose
    Mongoose Well-Known Member
    Catskill Mts. NY
    Clutch HAS to be ALL the way to the FLOOR, just before and during turning the switch from 4H to 4L.
  16. Jul 5, 2018 at 5:47 AM
    #36
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Manual or auto, it doesn't matter. Go to 4hi 1st. Once in 4hi come to a stop. Place transmission in park, neutral, or press clutch all the way in depending on the transmission type. Shift to 4lo. The odds are about 50/50 that it will go to 4lo while still at a compete stop. Often you'll have to roll slightly in order for the gears to line up and shift. With a manual letting out slightly on the clutch will spin the gears enough to get them to line up and engage. With an auto it may be best to make the shift when still rolling VERY slowly. The gears may not line up until you shift back into gear and start moving with an auto.
    Getting out is harder. Once again DO NOT try to go straight from 4lo to 2 hi. Shift to 4hi 1st. If it doesn't come out of 4lo, then go back to 4lo and back up 20-25' then try again. It may take several attempts. Once you get to 4hi simply drive off and shift to 2hi and let it make that shift while you're driving.
    BTW, this isn't just a Tacoma issue. Almost all 4X4's are like this.
  17. Jul 5, 2018 at 7:06 AM
    #37
    reg0928
    reg0928 Well-Known Member
    Ross
    Crestone, Colorado
    05 TRD OR Access Cab
    3"OME, 255/85R16
    my manual doesnt have any trouble.
    as said above, shift to H4 while moving, once it's engaged, stop the truck, hold the clutch in, shift to L4
  18. Jul 5, 2018 at 8:34 AM
    #38
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    I miss the shift lever on the floor.
    buckhuntin-tacoma and vssman like this.
  19. Nov 25, 2018 at 12:32 AM
    #39
    casey2012
    mark
    yota
    none
    i have a 12 bought new allways had same problem until i changed fluid to a high grade synthedic never had any more issues
  20. Nov 25, 2018 at 2:57 AM
    #40
    Brewnmn
    Brewnmn Well-Known Member
    2014 4X4 Reg Cab
    My manual 2014 Regular Cab will only go into 4lo if I have the clutch depressed, and my foot is on the brake pedal. I thought for sure when I first got it that the actuator was messed up but read in a post somewhere to depress the brake. Goes in/out every time. No brake pedal and all you get is a flashing light going in or out of 4lo. Nowhere in the owners manual does it say that this sequence is to be followed.
