Can't go into first gear until truck warms up?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by horstuff, Jul 15, 2015.
  1. Jul 15, 2015 at 12:06 PM
    horstuff
    horstuff [OP] Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    750 miles on odo... In the morning, I wait the 30 seconds or so until the idle comes down and then go. First gear, then second, then slow down for speed bump on road, and then I try to go back to first but it seems hesitant. Is that because it's a new truck, or will it always have to warm up longer, or...?
  2. Jul 15, 2015 at 3:08 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    Typical. It gets better as the the truck breaks in.
  3. Jul 15, 2015 at 3:19 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    Take it to the dealer!
  4. Jul 15, 2015 at 3:29 PM
    ilovich
    ilovich Well-Known Member
    Daniel
    Los Angeles
    2011 MGM Reg Cab 5-Speed 4x4
    Leaves in the bed
    How fast are you going when you try to put it back into first gear?
  5. Jul 15, 2015 at 3:33 PM
    AK Taco
    AK Taco Well-Known Member
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    20% tint on all windows, Deckplate mod, satoshi-ish grille, blacked out and/or body matched emblems, rattle canned rims, red l.e.d. interior lights, bilstein 5100's and OME 881 coils , deaver 8 leaf pack, 1.5" lift shackle, alpine sound system, 55w HID lightforce 140 and 170 fogs
    I can't put my truck into first unless I'm almost at a dead stop. Not that there's really any reason to put it in first after you're over 5mph anyways.
  6. Jul 15, 2015 at 3:40 PM
    ilovich
    Daniel
    Los Angeles
    Leaves in the bed
  7. Jul 15, 2015 at 3:42 PM
    horstuff
    PNW
    Cant be more than 2 miles per hour, but the point is that it seems easily able to go into first after awhile... I guess that does point to warming it up but I just wondered more if that's a break-in thing or not, which sr5vic concurs with.
  8. Jul 15, 2015 at 4:03 PM
    ilovich
    Daniel
    Los Angeles
    Leaves in the bed
    Gotcha. At around 2 mph I would expect it to go into first without hesitation, so maybe it is a break-in thing.
  9. Jul 15, 2015 at 5:48 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    I've never owned a vehicle that liked going into first once it was rolling. Blip the throttle a little in neutral before you go for first and see if that alleviates the issue.
  10. Jul 15, 2015 at 6:00 PM
    DSMJRV
    DSMJRV Well-Known Member
    justin
    Corona, CA
    pump the clutch, you may need to adjust it.. its pretty easy to do, there are two nuts on the back of the pedal.. pull it foreward and back and test it out to see what feels better.
  11. Jul 16, 2015 at 6:13 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Mine took like 40,000 miles before it would go into 1st without being completely stopped. The trans fluid temperature has a significant effect on this, overall, mine shifts much smoother after about 30 minutes of highway driving.
