cant install antenna x
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomaLS53, Aug 14, 2013.
  1. Aug 14, 2013 at 9:46 PM
    tacomaLS53
    tacomaLS53 [OP] Well-Known Member
    anybody that has an antenna x on their 2012 or any 2nd gen, how did you get it on there, none of the adapters fit
  2. Aug 14, 2013 at 9:46 PM
    medic2230
    Murph
    Bama! Roll Tide
    Superglue
  3. Aug 15, 2013 at 3:46 AM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    I have one and I had the correct adapter? Try again...
  4. Aug 15, 2013 at 4:01 AM
    Millertime187
    David
    Clay City, KY
    1995 Taco
    Dang I need to add some anti-seize!
  5. Aug 15, 2013 at 4:07 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    I just found this out the hard way. I had the "euro style" one break off leaving the threads in the antenna base when trying to unscrew it. I've got a new assembly with OEM antenna coming from camelback. Should be here tomorrow. I did notice when putting that particular antenna onto the truck there was a fairly decent gap between the base and the mast where it did not sit flush, but didn't think of it rusting out. I ordered their billet style one to give that a shot and if it does not sit flush I'll probably just use the OEM one or use some dielectric grease and wrap with heat shrink tubing.
  6. Aug 15, 2013 at 4:54 AM
    JMaberry
    JMaberry Well-Known Member
    Jack
    Salt Lake City, Utah
    01 3.4L TRD SR5 Extended Cab
    Spectre Intake, custom exhuast, ultragauge, bedlined bumpers and grill, ARE shell, jvc headunit, bottle opener in bed, satoshi, hella 500ffs behind grill
    I had the same issue on my truck with there being a piece of an old antenna broken off and stuck in the base. I just used a drill with an easy out to extract that broken piece from the base, took me about ten minutes and cost me nothing.
  7. Aug 15, 2013 at 9:01 AM
    TacoCat
    Johnny-5
    Chantilly, VA
    hmm. I'll have to try that. If it works I'll just save the base I ordered for if I ever do need it; if it doesn't, I'll just replace. Thanks for the suggestion.
