Cant locate my coolant drain plugs on the engine..anyone help me here?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bruce1271, Feb 23, 2010.
  1. Feb 23, 2010 at 5:39 PM
    bruce1271
    bruce1271 [OP] Well-Known Member
    I looked in the service manual and it shows two of them, but I cant see them or feel them anywhere on the block. Anyone know their exact location?
    thanks
  2. Feb 23, 2010 at 5:44 PM
    CAMZTRD
    CAMZTRD Well-Known Member
    steve
    hampton, va
    2006 DC TRD Off-Road 4x4
    billy 5100's @ 2.5 w/ 1/4 spacers, toytec aal, LR UCA's, revotec headlights,revotec taillights, lamin-x fogs, color matched grille and rear bumper, undercover, bed-extender, black nerf bars, scan gaugeII , afe drop in, 50 series flowmaster, 6000k bi-xenon hids, more to come.......
    you should have a drain on the bottom of the radiator..
  3. Feb 23, 2010 at 5:44 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    I couldn't find them either and didn't bother to drain the block. Most of the times if you drain the block you'll only end up getting an air bubble in the system and air lock the engine.
  4. Feb 23, 2010 at 5:45 PM
    ShadowFalken
    ShadowFalken Well-Known Member
    Jim
    Maryland
    10 Off Road
    Raptor stainless bars, Wet Okole covers, RollBak bed cover, PopNLock, Redline hood struts, XM radio factory kit
    What engine?
  5. Feb 23, 2010 at 5:48 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    air lock? hat the hell are you talking about? Please explain.I've never heard of this.
  6. Feb 23, 2010 at 5:49 PM
    lucky
    lucky Well-Known Member
    NB, TX
    07 PreRunnerX4
    TRD 2 CAI Firestone Ride-Rite TSB Leafs Toytec AAL 5100's and OME Blue LED dash
    If its the 1GRFE, the drain is located near the bottom of radiator on driver's side. It does not look like a typical drain valve, its plastic and looks alot like the plastic push fasteners on places all over the truck.
  7. Feb 23, 2010 at 5:52 PM
    Fortech
    CANADA
    Its when you get an air pocket in your cooling system that prevents the coolant from circulating at the correct volume, or at all. Common knowledge for anyone who wrenches.http://wiki.answers.com/Q/How_do_you_get_an_air_lock_out_of_a_cooling_system
    According to the service manual there are three drains. 1 on the bottom of the rad and two (if memory serves) on the engine. Draining the rad only drains 1/2 the system.
  8. Feb 23, 2010 at 7:22 PM
    bruce1271
  9. Feb 23, 2010 at 7:37 PM
    Fortech
    CANADA
    I think its a typo - I searched and searched and couldn't find them.
  10. Feb 23, 2010 at 7:45 PM
    bruce1271
    I wonder if they are behind the pulleys somewhere.
  11. Feb 23, 2010 at 8:52 PM
    nuckinfuts
    nuckinfuts NyQuil on the rocks.
    Pacific NW
    '06 AC TRD Off-Road
    DT Long Tube Headers, Empire O2 simulator, catback, Shrockworks Sliders, Old Man Emu 3" lift with 885 coils (with 1/2" top plate spacer and Dakar Leaf packs), Hi-lift mounted in bed with 4XRAC mounts, WT floor liners, other stuffs
    How often are you changing the coolant?
  12. Feb 24, 2010 at 12:24 AM
    ShadowFalken
    Jim
    Maryland
    10 Off Road
    One is located on the engine block on the left side toward the front. Look where the left motor mount bolts and forward. The other is on the right side of the block toward the rear. May need to remove skid plate to see. Right and left are from the driver's seat. You will drain a lot of more coolant.
    Two and a half gallon capacity (about) will let you know how much you actually got out.
  13. Feb 24, 2010 at 6:00 AM
    bruce1271
    Ok, i was looking for them from the top. I guess they are on the bottom then? Thanks!
    And I am at 96K miles. Wanted to do it early before the Texas heat for the 6th time.
  14. Feb 24, 2010 at 6:16 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    You're looking for the drains on the top?? Son,,, are you sure you should be doing this work? :D
    Just messing with you, I am known to have many brain farts and DAMs (Dumb Ass Moments) through the course of any day. :)
  15. Feb 24, 2010 at 6:19 AM
    bruce1271
    No, I was looking for the drains FROM the top. Not on the top. The picture in the service manual is deceiving. They should have used crayons and I would have understood it better. :rolleyes:
  16. Feb 24, 2010 at 6:39 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Got it, just sounded funny and I couldn't resist.
  17. Feb 24, 2010 at 7:01 AM
    dog tired
    dog tired Well-Known Member
    NE Ohio
  18. Mar 21, 2010 at 6:45 PM
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    I want to drain the radiator in my 05 Tacoma Pre-runner
    Anything I should know or some tips before doing a drain and refill on the radiator?
    I know to use the pink Long Life Toyota Coolant
    After I refill the radiator how can I burp out any air?
    Can I just run the engine with the radiator cap off at idle to burp it?
    Should I also leave the coolant jug cap off when running the engine at idle to burp it?
    Thanks for any info...
  19. May 1, 2011 at 10:26 AM
    bluesurfur
    bluesurfur Active Member
    Scott
    CO
    06 DC PreRunner
    Soft Topper Stereo upgrade
    The two engine block drains can be most easily accessed through the wheel wells. I was able to loosen them using 2 foot extensions.
  20. Jul 4, 2011 at 12:59 PM
    rag9836
    rag9836 Active Member
    Robert
    Riverside, CA
    06 Pre Runner SR5 TRD
    Can someone post some photos of the two plugs on the engine block, I can't find.... ugh
