Can't open rear passenger door.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by fr33loader, Dec 1, 2016.
  1. Dec 1, 2016 at 7:35 AM
    fr33loader
    fr33loader [OP] Member
    Kurtis
    Rockville, Ut
    2016 Tacoma sport
    Soooo, being the big idiot that I seem to be I have managed to mess up my truck. I took off the door panel to run some speaker wire and when I was hooking everything back up I switched the cables going from the door handle to the door lock. I didn't realize my mistake until I had already shut the door and now I can't open it. Being that the door is shut I can't take off the panel to switch the cables back. Anyone have any suggestions on how I can open it again?
  2. Dec 1, 2016 at 7:40 AM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Are the inner door latch release handles a separate bezel on these? Usually they have a screw or two holding them on. Pop that off and manipulate the plastic retainers to completely release the handle assembly and then grab a pair of pliers and pull either one to release the latch mechanism. I doubt the whole door panel needs to be popped off.
    0210 likes this.
  3. Dec 1, 2016 at 7:57 AM
    fr33loader
    Kurtis
    Rockville, Ut
    2016 Tacoma sport
    I'm not too sure, I will give it a look when I'm off of work. Thanks for the reply.
  4. Dec 1, 2016 at 8:04 AM
    GPsevinSixx
    Ros Angerus
    https://www.youtube.com/watch?v=BeVKDwHrkus
    Just saw this vid, looks like they're installed from underside. The main door panel looks like it needs to come of first, but not sure how that's gonna happen with a closed door.....
    May have to do some damage or break parts of the door handle to get access and replace the inner handle assembly after.
  5. Dec 1, 2016 at 8:12 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Not gonna lie, thats too funny.
    RIDERED67 and Nfarrall like this.
  6. Dec 1, 2016 at 8:15 AM
    Marbleyard
    Marbleyard Thread killer
    Virginia
    2019 4Runner Pro
    SOLD 2016 taco: premium technology and tow package. OV Tune 1.05; A.R.E. V Camper Shell; BRO grille & Tails; OEM bed mat; Xenon Depot HID headlight conversion; reflective gray tailgate letter inserts; GoPro session; Hondo radio knobs; K&N cold air intake, quicksand painted dash bezels, Subaru dash speakers, Kicker CS 6x9 fronts and 6.5 rear speakers; All LED interior lights and LED high-beam headlights. Redline elite hood shock props. prinsu cab and camper rack with rough country 30" light bar; (2) 8" rear facing “F.U.”rough country black LED lights; prinsu cargo basket kit, (2) prinsu load racks; roadshower 4; ARB 2500 awning and room kit; weather tech floor mats; carhart seat covers; ckma12 ARB air compressor under the hood; blue ridge overland gear air tools bag, tool bag, driver's seat molle. Rack mounted TRED 800 recovery treds and plano case. Rotopax water and fuelpax fuel canisters; Pelican cased first aid kit in bed. rockblokz mud flaps. ARB rear dif. breather. Stand alone fuse block. SSO bumper with 10k smittybilt synthetic line winch and factor55 ultrahook. Pro Eagle 2-Ton “The Beast” jack. OME lift kit: 90000 front shocks and 886 OME coils, Camburg 310078 UCA, 60091 rear shocks with light duty Dakar leafs. Good Year duratracs 285/75R16. Black vinyl inlays on factory OR wheels; RCI Steel Front/Trans/Trans Case/Rear Diff Skids, Alum A-Arm; Mobtown bolt-on sliders with scorpion bed coating; pelfreybilt aluminum fuel tank skid; Cali-Raised full length Molle storage LH & RH bed sides; Caliraised bedside reinforcements; HELLA sharptone horns; Optima blue-top battery with AJT machined red tiedown bracket. AJT quicksand key fob. Overland Bound member #6996
    You may be able to pop the belt molding (the strip on the outside of the truck) off and try to get to it from that side,if your window is up. :notsure:
    Toyko Joe likes this.
  7. Dec 1, 2016 at 8:19 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    Maybe use a slim-jim or coat hanger to jimmy the lock like you were breaking in? Watch you-tube on how to videos?
    0210 likes this.
  8. Dec 1, 2016 at 8:19 AM
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
    I cant either. :rofl:
    Ok ok...i'll show myself out..:anonymous:
    cabo wabo, 0210, Herniator and 2 others like this.
  9. Dec 1, 2016 at 8:20 AM
    Toyko Joe
    Beautiful truck. (offtopic) :gossip:
  10. Dec 1, 2016 at 8:21 AM
    Taco Addiction
    Houston, TX
    Thanks T Joe. just injecting whatever little (and I mean little) humor I can.
  11. Dec 1, 2016 at 12:45 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    OP, how are you trying to open the door..?? From inside or outside..?? It should open manually from the inside unless you flipped the child "door lock" switch inadvertently..! Sounds odd that by switching wires, you can't open the door manually. Are these doors electrically operated..and not by a rod from the handle..??
  12. Dec 1, 2016 at 12:47 PM
    GPsevinSixx
    Ros Angerus
    I can't believe he reversed the rods either! They're usually unequal lengths and sometimes a plastic clip that orients upper and lower fastened to the sheet metal.
    Weirder stuff has happened though.
  13. Dec 1, 2016 at 12:51 PM
    over60
    Muskoka, Ontario
    I see now... OP said he switched "CABLES"...and not electrical wires like I presumed..? so this truck uses a cable instead of a rod..??
  14. Dec 1, 2016 at 12:52 PM
    GPsevinSixx
    Ros Angerus
    Probably. There's vid link I posted further back. Looks like cables.
  15. Dec 1, 2016 at 12:58 PM
    over60
    Muskoka, Ontario
    OP... I just watched that video and see what you mean... not hard to mix them up.... Is it possible to remove the inside door handle and disconnect it's cable.... then PUSH on the cable to unlock the door...? If you hooked up the outside door handle, why not unlock the drro with that door handle..?? If all you was reverse them and they are connected...they should work in reverse... right..??
  16. Dec 1, 2016 at 12:59 PM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    If all else fails, your local body shop should be able to open it...
  17. Dec 1, 2016 at 1:02 PM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    GPsevinSixx likes this.
  18. Dec 1, 2016 at 1:05 PM
    GPsevinSixx
    Ros Angerus
    RichVT saves the OP's day! Good recall on that thread. Too much stuff to read. LOL
  19. Dec 4, 2016 at 8:21 AM
    fr33loader
    Kurtis
    Rockville, Ut
    2016 Tacoma sport
    I really appreciate all the responses to my foolishness haha. This is what I get for working 16 hours then trying to do some 2am work on my truck.
