cant pass emissions, secondary air pump not working
Discussion in 'Toyota Trucks & SUVs' started by Jay5Choi, Apr 16, 2021.
  1. Apr 16, 2021 at 7:46 AM
    Jay5Choi
    Jay5Choi [OP] New Member
    jay
    Emissions won't pass because it keeps showing on the report secondary air not ready and evap not ready. Did little more research, checked inside the are pump and its clean. Fan blades are free and clear from any debris. The stock foam/filter piece is still condition some how. Not sure if im checking right but i was told i should be getting 12v going to the plug. Not getting 12v and also maybe its the EFI relay. Really trying not to go to the mechanics shop. Its been awhile since ive been on here, any information will help.
    update:
    Codes showed up
    P2441 and P2445
  2. Oct 12, 2022 at 12:02 PM
    hewitt-tech
    hewitt-tech Dont Replace SAIS, Bypass It!
    Lexington, SC
    Secondary Air Injection System Bypass Kit
    Happy to give you some resources on the failure prone Secondary Air Injection System. The Secondary Air Injection is failure prone and you can spend all day reading horror stories of owners trying to address. The question is not "If" it will fail but "When" it will fail. If you have any questions do not hesitate to reach out, DM or give us a call.
    What Does the Secondary Air Injection System Do?
    https://www.tacomaworld.com/threads/what-does-the-secondary-air-injection-system-do.780847/
    What Do My Secondary Air Injection Error Codes Mean?
    https://www.tacomaworld.com/threads/what-do-my-secondary-air-injection-error-codes-mean.780848/
    How to Fix Secondary Air Injection System?
    https://www.tacomaworld.com/threads/how-do-you-fix-the-secondary-air-injection-system.780849/
