CAN'T PUMP GAS
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JayBird1993, Feb 3, 2022.
  1. Feb 3, 2022 at 3:28 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    May be where you are placing the cap when filing. You using a Gasshole or letting it hang? :D
    Gen2Tacoma likes this.
  2. Feb 3, 2022 at 3:37 PM
    Kel Varnsen
    Kel Varnsen Active Member
    PO HO
    2005 DC TRD ...Sold 425k Now 2016DC TRD
    Yep, But willing to bet root cause is the same
  3. Feb 3, 2022 at 3:38 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    @JayBird1993
    There is a roll over safety valve between the filler neck and gas tank that has been known to cause this problem in 1st, 2nd and 3rd gen Tacomas.
  4. Feb 3, 2022 at 3:40 PM
    Gen2Tacoma
    Gen2Tacoma A Question Asked is an Answer Learned!
    North East Atlanta
    If the shit gets low it's harder to fill other than that ya'll crazy. It does it on my bass boat even! It's just physics.
  5. Feb 3, 2022 at 3:53 PM
    tacodubs
    tacodubs Member
    2020 TRD SPORT LB cement
    Evap canister under the bed. juste disconnect hose from fuel neck filler to evap canister and blow some air into canister through the hose (only by your breath). little check valve in canister stock close.
    it happen on my tundra, no code juste filling gaz impossible (only very slowly)
  6. Feb 3, 2022 at 4:21 PM
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
  7. Feb 3, 2022 at 4:58 PM
    Duckinatruck
    Duckinatruck Well-Known Member
    2019 OR DCLB
    Before you spend more time and any money, at least take it back to where you bought it and ask if they will check it out for you since you just gave them your business. Doesn’t hurt to ask.
    edit: Might even be covered under warranty?
  8. Feb 3, 2022 at 5:04 PM
    mrkabc
    mrkabc Mall Crawler with a Locker
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto XB LED Head & Fog Lights, Cali Raised Stealth Light bar, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO mirrors, gashole, switch panel & Stage 2 tails, PRO grille. Where's the mall?
    My Mustang does this. Known issue for years, Ford denies there's a problem.
    My solution: flip the pump handle upside down when filling up. For some odd reason that has worked for me so I never bothered with Ford for a fix. Try it out?
    Oh, and I'd go back to dealer too. GL!
  9. Feb 3, 2022 at 6:57 PM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Falken Rubitrek AT 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    I had this happen on my other truck, my Subaru Baha (laughing). Started happening at every station and pump. Replaced charcoal canister and problem went away. I sold my Baha and bought this Tacoma. I do sometimes miss the little Suby. A good mechanic will point you in the right direction.
  10. Feb 3, 2022 at 9:34 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Yup, lived in Oregon 65 years and the only time I could pump gas was when I worked at a gas station. People in the other 48 states are risking their lives every time they fill up not having a professional filling their tanks.:rofl:
    Grossomotto[QUOTED] likes this.
