Can't re-connect sway bar after ome 887 install
Discussion in 'Suspension' started by ecgreen, May 23, 2016.
  1. May 23, 2016 at 8:04 AM
    ecgreen
    ecgreen [OP] overeducated redneck
    Sean
    2015 4x4 4-banger Access
    Well, I have the 887 coilover installed, but I can't reconnect the sway bar. It is about 2 to 3 inches to low to connect to the spindle. When I jack the LCA to try and get the two to meet, the whole truck jacks up because of the strength of the coilover.
    Ideas? Any help appreciated.
    Sean
  2. May 23, 2016 at 8:10 AM
    Jrobertson
    Jrobertson Well-Known Member
    James
    green valley (Henderson)
    2010 Tacoma off road. 4x4
    Stock. For now.
    disconnect the sway bar completely. and bolt on the sway bar lower bolts. then jack up the tire to compress the spring and isntall the swaybar at the tire?
  3. May 23, 2016 at 11:20 AM
    ecgreen
    Sean
    I'm an idiot. Sway bar was also connected to the non lifted side. So it wouldn't let it rotate enough on the lifted side. That's why all the instructions tell you to take the sway bar off 1st. Thanks
