Can't remove grille
Discussion in '2nd Gen. Tacomas (2005-2015)' started by The 2TR FE, Nov 13, 2014.
  1. Nov 13, 2014 at 8:54 AM
    The 2TR FE
    The 2TR FE [OP] 4 Bangin'
    Ian
    NH
    14 Toyota Tacoma Regular Cab 4x4
    LC Engineering Pro Flow Cat back exhaust w/ Magnaflow muffler and resonator delete, BF GOODRICH A/T KO2 (32s) bunch of led lights (two sets of duallys and a generic 28" light bar) smittybilt light bar mount HPS Short Ram intake with K&N cone filter Undercover tonneau cover (repaired)
    Hey
    I am having a hard time removing my grille from my truck. I got the clips and the two 10 mm but the clips on the bottom... Well... I just don't get how they work do I push up on them? down on them? I don't get it... It's making me a little frustrated :D and please don't send me the grille craft link it helps to a point but doesn't help me thoroughly. Btw its a 2014
    Thanks for your time!
  2. Nov 13, 2014 at 8:56 AM
    Htnswches
    Htnswches Well-Known Member
    E
    Lost Angels
    2006 Precummer Tacoma
    310,000 and counting
    Flat blade screwdriver, pop the middle up, then remove
  3. Nov 13, 2014 at 9:11 AM
    The 2TR FE
    Ian
    NH
    Is a 2014 different because I did that and it's still snug as a bug in a rug?
  4. Nov 13, 2014 at 9:12 AM
    1stTruck
    1stTruck Well-Known Member
    Jim
    South Carolina
    PreRunner
    Billies 5100's front set to 1.75 plus 1/4 taco lean spacer. Rears Billies plus AAL for a 2" leaf. 265/75/16 BGF's. Double din Kenwood stereo w/bluetooth and steering wheel controls and JBL speakers front & rear. Heavy duty battery. Billet grill blacked out. K&N air filter and MBRP cat-back. Just tuned it up new plugs and new front brake pads. Steel powered coated tailgate cap. Billet Grill painted black & factory roof racks. Oh new head lights thanks to toyota.
    I researched it before removing mine. Once the top two screws are out the the top push in pin are out, you grab the grill and pull up hard to pop out of the bottom clips.
  5. Nov 13, 2014 at 9:13 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Same thing on my 13. Flat head screw driver. Little bit of a pain for me with a custom grill, aftermarket horns and a LED bar but always worked great for me.
  6. Nov 13, 2014 at 9:35 AM
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    I've removed the grill on my 14. The clips on the bottom are done the same way, with a small flat head screwdriver. Not sure what else to really say, I did have a couple that were harder to remove than the others but they all popped up and then could be pulled out. You are looking to pop up the middle portion of the plastic clip and at that point once it is up you can pull the clip out.
  7. Nov 13, 2014 at 10:19 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    I did not use a screwdriver, nor do I think you should, too easy to mar the grille.
    Just grasp it firmly close to the bottom and pull hard up and slightly away from the front of the truck. It'll release from the clips. It feels like you are going to break it, but you won't.*
    Once you have it off it's easier to see / understand the orientation of the clips and then re installing it and removing it again later is easy.
    *if you do, it's on you
  8. Nov 13, 2014 at 10:21 AM
    Kevinztaco
    Kevinztaco Well-Known Member
    none yet
    I had to pull hard to get mine out when I did my 2013's grill.
  9. Nov 13, 2014 at 10:55 AM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
  10. Nov 13, 2014 at 10:56 AM
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    That's correct, once you get the plastic pop clips out there are a series of clips at the bottom. I started on one end with a firm tug and the bottoms clips started to disengage and then just worked my way to the other side. And yes with the amount of pull it does feel like something may break but the tabs released first. Have pulled the grill out 3 times... gets easier each time lol
  11. Nov 14, 2014 at 10:55 AM
    The 2TR FE
    Ian
    NH
    Thanks guys I got after getting really pissed off at it and just yanked at it and it popped out on one side and I eventually got the other side out same way. And this was all for just seeing where I can mount my R.I. Duallys when I get them. I'll start a new thread on that though.
    Thanks again!
  12. Dec 31, 2014 at 8:34 AM
    roydog
    roydog Member
    San Antonio, Texas
    2014 Tacoma Texas Edition
    IronBull Pre-Runner bumper Torchstar LED Headlights Vison X cannon lights 2" leveling kit on the front 1" leveling kit on the reat Viper Remote Start
    apparently when removing my grill i lost this bottom clip. what does it look like? do you have a pic of it?
