Can't remove rear tail light lens due to frozen/stripped screws on 1996
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1996_2.4, Mar 16, 2024.
  1. Mar 16, 2024 at 10:20 PM
    1996_2.4
    1996_2.4 [OP] Well-Known Member
    Today I tried to put on a set of LED back up lights. I got one side done, screws came out very easy. Then the other side had 2 screws that would not come out.
    I got a perfect fit with a real sharp phillips screwdriver, but they would not move. And the screws seem to be slightly stripped. I even tried spraying a little WD-40 to try to unfreeze them. Does anyone have any suggestions on how to get these screws out?
    I don't own a drill to drill them out. Does anyone know a place I can get replacement tail light lens for a 1996?
    Finally, will having one LED back up bulb and one standard bulb damage anything?
    Thanks/
  2. Mar 18, 2024 at 8:21 AM
    mootiger49
    mootiger49 It’s mine, not yours!
    23’ Lunar Rock OFF ROAD. 24’ Underground 4-Runner. 2000 IJM OFF ROAD
    V2 grille OTT Tune 5100’s Pro rims
    You will need a drill and tap out kit.
    The drill you will need needs to have pretty high rpm.
    As far as the lights go, I have no idea
    1996_2.4[OP] likes this.
  3. Mar 18, 2024 at 8:47 AM
    1996_2.4
    Thanks. Since I don't have a drill or tap kit, might be easier to just break the damn plastic lens, use vice grips to turn the screws until they come out, and put in new lens and screws. It all depends if I can find a super cheap lens.
  4. Mar 19, 2024 at 5:56 AM
    1blink
    1blink Well-Known Member
    Storm Mtn, CO
    2000 3.4 manual SR5
  5. Mar 19, 2024 at 5:59 AM
    mootiger49
    I have to say I have never seen this.
    How good do these work?
  6. Mar 19, 2024 at 6:06 AM
    1996_2.4
    Thanks that looks amazing. I've never seen this before
  7. Mar 19, 2024 at 7:39 AM
    Madjik_Man
    Colorado Front Range
    In the past five years I’ve bought only Vessel for screwdrivers. The JIS standard is what most of the fasteners on our Tacomas are, and the new DIN standard work far better on Phillips also.
    I have that impacta screwdriver and it works wonderfully.
    I also have their manual impact driver but that would be overkill for a tail light lens.
    https://www.amazon.com/dp/B001WHKSS4
  8. Mar 19, 2024 at 9:19 PM
    Corvax
    Corvax Member
    JL
    Corrales
    '01 Ext Cab TRD
    I just removed my tails to install a trailer lighting kit. The screws go into plastic inserts and the drivers side was difficult. For some reason, there was a lot of friction and squealing as they came out. You might be able to access from below to get some pb blaster sprayed on them.
