Can't separate rear drive shaft flange from diff.
Discussion in '1st Gen. Tacomas (1995-2004)' started by travelfeet, Oct 27, 2013.
  1. Oct 27, 2013 at 6:24 AM
    travelfeet
    travelfeet [OP] Well-Known Member
    Andrew
    Troy, NY
    02 xtra 4x4 v6
    I am trying to trace a low speed drive line vibration, so I am pulling the drive shaft. I have the center support bearing loose, and all four bolts between the rear flange and the differential out. The flange is still stuck to the diff though.
    How hard can I bang on the flange? I have given it a few wacks with a hammer, and tried driving a flathead screw driver between them, but so far nothing. I don't want to damage anything, and if I move things around too much the slip joint starts pulling out (and I don't want the splines exposed until the shaft is off the car.
    I can pull the bolts out of the front flange too, but I am not sure it will be any different.
    :confused:
    Any suggestions?
  2. Oct 27, 2013 at 6:42 AM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    Put steady bearing back in to hold the drive shaft then get a dead blow ( rubber mallet) and just wack the flange till she comes loose. Put your purse down and it will come off GL
  3. Oct 27, 2013 at 6:42 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Most likely just surface rust, try a dead blow or big rubber hammer. try not to whack it too hard with regular hammer, use a block of wood to whale on if you only have a hard hammer. Before you remove it, make a mark on the flange so it can be re-installed in the same orientation.
  4. Oct 27, 2013 at 8:29 AM
    travelfeet
    Andrew
    Troy, NY
    02 xtra 4x4 v6
    Thanks for the suggestions. I'll out some mustard behind it (with wood block cushion). I was hesitant to hit it too hard.
  5. Oct 27, 2013 at 9:17 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Keep in mind that the ds flange won't move sideways, a round lip on the that flange prevents sideways movement and helps line up the flanges when re-attaching. The shaft must move towards front to separate.
    Use some solvent (like PB blaster) first. When it does come loose, it can drop hard on whatever is underneath, so be careful. I like to suspend some rope just underneath the lower end of the shaft to prevent it from dropping to far when it does finally break free.
    SR-71A likes this.
  6. Oct 27, 2013 at 9:21 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Don't hit it with a hammer too hard. You can break the yokes. Put a probar in there and pry it off. You can tap on I with a deadblow at the same time as prying, this will help. Hit if you hit the shaft directly it will mess up the balance.
  7. Oct 29, 2013 at 10:46 PM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    This. I didn't catch it on time and it landed safely on my arm. Sucked.
  8. Oct 30, 2013 at 3:32 AM
    travelfeet
    Andrew
    Troy, NY
    02 xtra 4x4 v6
    Hey folks, I had preemptively soaked the flange and bolts with PB blaster. The next day a short pry bar popped it loose with zero effort.
    Thanks for the advice. My new zerks, and clean and freshly lubed splines thank you.
  9. Oct 31, 2013 at 5:19 PM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    I found that removing the tiny 6 mm zerk that greases the slip- splines the best route. It decompresses the driveshaft, and makes it way easier to come apart.
  10. Nov 5, 2013 at 4:17 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    this and hit it harder with your purse
  11. Nov 5, 2013 at 4:32 PM
    jdkilroy
    jdkilroy Well-Known Member
    Jon
    Southern NH
    '02 4x4 SR5 Access Cab
    Apply anti seize compound to the two faces before reassembling.
    SR-71A likes this.
