Can't stop in snow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DryFly45, Jan 1, 2013.
Thread Status:
Not open for further replies.
  1. Jan 6, 2013 at 12:01 PM
    #261
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    :laugh:
  2. Jan 6, 2013 at 12:03 PM
    #262
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    This is from Edmunds.com, it touches on the subject but I've seen it broken down way better. Still looking.
    1. Give yourself a brake. Learn how to get maximum efficiency from your brakes before an emergency. It's easy to properly use antilock brakes: Stomp, stay and steer. Stomp on the pedal as if you were trying to snap it off. Stay hard on the pedal. Steer around the obstacle. (A warning: A little bit of steering goes a very long way in an emergency. See Tip 8.) If you drive on icy roads or roads that are covered with snow, modify your ABS technique: After you "Stomp" and the ABS begins cycling — you will feel pulses in the pedal or hear the system working — ease up slightly on the pedal until the pulsing happens only once a second.
      For vehicles without ABS, you'll have to rely on the old-fashioned system: You. For non-ABS on a mixed-surface road, push the brake pedal hard until the wheels stop rolling, then immediately release the brake enough to allow the wheels to begin turning again. Repeat this sequence rapidly. This is not the same as "pumping the brake." Your goal is to have the tires producing maximum grip regardless of whether the surface is snow, ice or damp pavement. Use the tips in "How To Survive the Top 10 Driving Emergencies" to practice before the emergency.
  3. Jan 6, 2013 at 12:04 PM
    #263
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    That doesn't seem to be the case from my experience but would be nice if it was
  4. Jan 6, 2013 at 12:08 PM
    #264
    Highland Logan
    Frank
    Nova Scotia, Canada
    I'm too sure how that would work in conjunction with Brake Assist.
    Frank
  5. Jan 6, 2013 at 12:12 PM
    #265
    Fightnfire
    Marysville, WA
    From the National Safety Council website, NSC.org:
    This is under the don't list for normal driving conditions.
    "...pump the brakes. In four-wheel ABS-equipped vehicles, pumping the brake turns the system on and off. ABS pumps the brakes for you automatically, at a much faster rate, and allows better steering control."
    I'm pretty sure if you hit the brakes hard to engage ABS and then back off and re-apply to threshold you should reduce the effectiveness of ABS. Still looking for that great write up, oh well.
  6. Jan 6, 2013 at 12:13 PM
    #266
    Fightnfire
    Marysville, WA
    If you let off the brake after applying "panic" pressure brake assist turns off unless you panic brake again.
  7. Jan 6, 2013 at 12:14 PM
    #267
    Fightnfire
    Marysville, WA
    I wonder if the "over sensitive" ABS we are reporting in our Tacoma's on snow/ice is really the panic brake assist and the ABS is quite normal?
  8. Jan 6, 2013 at 12:20 PM
    #268
    Fightnfire
    Marysville, WA
    Hmm I didn't know about this one:
    6) Smart Stop Technology - SST
    Smart Stop Technology provides an added layer of confidence that can help the driver stop the vehicle, even if the accelerator pedal is fully depressed under certain conditions. Smart Stop Technology will engage when all 3 of the following conditions happen simultaneously: (1) The throttle is more than one-third open beyond the idle position. (2) The vehicle is moving faster than 5mph, and... (3) The brakes are firmly applied for longer than a half second. When Smart Stop Technology is engaged, engine output is cut to the idle position, reducing the load on the brakes. The driver can then cancel activation of Smart Stop Technology by taking his or her foot off the brake pedal.
    Taken from this:
    http://www.toyotaofsanford.com/toyota-star-safety-system.htm
  9. Jan 6, 2013 at 1:42 PM
    #269
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    ABS will increase stopping distance.
    Please point to where I agreed that ABS Stops you quicker on snow.
  10. Jan 6, 2013 at 1:46 PM
    #270
    OZ-T
    Peter North
    British Columbia
    I was refering to this post however in rereading your post , I could have misunderstood your comment
    http://www.tacomaworld.com/forum/showpost.php?p=6228519
  11. Jan 6, 2013 at 1:51 PM
    #271
    Jimmyh
    SC
    2012 Prerunner SR5
  12. Jan 6, 2013 at 1:59 PM
    #272
    OZ-T
    Peter North
    British Columbia
    Ah , my apologies .
    So you are not agreeing with his " ABS stops me faster on snow " statement , only that in his opinion his ABS works as it should even though we both know that ABS doesn't work that way
  13. Jan 6, 2013 at 2:54 PM
    #273
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    This was part of the accelerator recall. Go out and stomp on it in the right order and the motor goes back to idle, let off the brake and it spins back up.
  14. Jan 6, 2013 at 5:41 PM
    #274
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Just finished switching over my abs/vsc off Landphil's method. Thanks to Oz-T and Sandman.
  15. Jan 6, 2013 at 8:01 PM
    #275
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That was just absolutely horrid to watch.
  16. Jan 6, 2013 at 8:50 PM
    #276
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Highly HIGHLY agreed. There are too many hotshot drivers out there nowadays who seem to think that they can do anything, anywhere with anyone and they will be invincible. Those kind of people need to watch this kind of video to get a rude awakening before something happens to them and others around them.
  17. Jan 6, 2013 at 11:24 PM
    #277
    Jimmyh
    SC
    2012 Prerunner SR5
    I used his post to highlight the fact that the opinions are all over the map with respect to if it is too sensitive or not.
    I'm just glad I don't have to deal with the fuckin snow and ice except in the rare times when we get 2 or 3 inches... :D
  18. Jan 7, 2013 at 1:32 AM
    #278
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Maybe we should have a competition. Who thinks they can stop faster on this with or without ABS? Let's say from 15 MPH right where the car is in the background.
  19. Jan 7, 2013 at 3:12 AM
    #279
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    I don't like our ABS in the snow/ice. I have had a few occasions where it was slushy wet snow, and if my ABS didn't kick in like it did, I would of stopped a few feet shorter every time, it wasn't that slick.
  20. Jan 7, 2013 at 6:52 AM
    #280
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Thats why proving that traction control had put you in the ditch is almost impossible. With out detailed log from vehicle and multiple camera's. But if you break down second by second video. You can kind of figure out what is going on. This video is probably the best proof that Traction control is dangerous in winter driving.
    0:16 - all normal except guy moves to left and front left tire drives o nthe snow patch, that starts putting drag on left front tire trying to spin truck to the left.
    0:17 - guy ends up with both left tires on snow, at the same time truck is starting to climb. So now front left is generating drag, truck is climbing and rear left tire on the snow starts losing traction. (been there done that). Once rear tire spins, traction control cuts power, and applys brake to left rear.
    0:18 - power cut (for 5 seconds at least) + left tire braking send surge to right tire which loses traction, so now both rear tires have no traction. Since left tire is dragging on the snow, rear end swings to the left, guy tries to turn to right to get off the snow, Bad move!
    0:19 - traction control kicks in and does what was design to do. Make truck go where wheels pointing to. So right side brakes gets applied and truck swerves into the right, slamming into the box truck
    0:20 - both box truck and Nissan are swinging their tails
    0:21 - Nissan driver turns wheel to the left to get away from box truck. Bad move again. traction control hammers the brakes on left side which now catches snow. Sending Nissan sideways.
    0:22 - Nissan driver counters to the right but at this point Nissan is going sideways and still there is no power to the wheels No way to avoid 18 wheeler.
    0:23 - boom. In the meantime box truck with no traction control recovers from slide and goes on its merry way.
    Nissan driver did everything right, what he did not anticipated was traction control.
    If he knew Traction control is junk, he would have kept steering wheel to the right and allow traction control to ditch him.
Thread Status:
