Can't stop in snow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DryFly45, Jan 1, 2013.
Thread Status:
Not open for further replies.
  1. Jan 1, 2013 at 4:22 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The ABS works great on dry pavement
  2. Jan 1, 2013 at 4:25 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Have you tried learning from the experience. Bad tires and abs dont mix well. Down hill with snow is dangerous with anything other than a sled.
    I have done the same thing multiple times. I even had the same problem when my abs wasnt working for a while. Just choose your routes wisely and keep safe.
    Anything you cant get down safely probably means your gonna have a hell of a time getting back up.
    This is what happens when you rely on your tires in snow.:D
  3. Jan 1, 2013 at 4:26 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    OEM tires for the TRD Off Road is BFG Rugged Trail. It is an all-season highway tire with aggressive-looking tread design (and advertised as such). It is notoriously bad in the snow, as shown by the dismal reviews on the TireRack:
    http://www.tirerack.com/survey/Surv...rail+T/A&fromTireDetail=true&tirePageLocQty=#
  4. Jan 1, 2013 at 4:27 PM
    Blueridge
    Blueridge Well-Known Member
    That's amazing. On a slight incline mine needs 4WD to move at all if the road is snow covered. Stock BFG tires.
  5. Jan 1, 2013 at 4:49 PM
    Workman
    Workman Well-Known Member
    06 access cab, off road, V6
    The 2nd gen Tacoma is one of the best trucks Workman has owned for summertime use, and hands down the worst truck for wintertime use. The ABS system is ridiculously sensitive, and is going to cause an accident someday. When its below zero, icy, and snowy it doesn't matter how slow you are going or how careful you are to slowly apply pressure to the brakes, the ABS kicks and and many times doesn't allow for a very clean stop. By far the worst thing about these trucks. Totally unacceptable the way it performs in icy situations
    /rant
  6. Jan 1, 2013 at 5:47 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Don't hammer the brakes then the abs won't kick in.
  7. Jan 1, 2013 at 5:47 PM
    Blygy
    Blygy Well-Known Member
    East of Edson
    Supercharged 2012 DCLB TRD Sport Trail Teams
    Trail Teams Edition Supercharger
    I ran into this with my 2012 TRD Trail Edition in an icy parking lot in Stony Plain.. Had to goto N to actually stop..
    ABS is dangerous in these things..
    I think I will wire in a switch to turn it off and on next summer..
  8. Jan 1, 2013 at 6:04 PM
    offroadwonder
    offroadwonder Well-Known Member
    Jared
    Aurora, CO
    '10 Tacoma DCSB 4x4 TRD Off-Road
    Chopped mud-flaps (yup, I'm hardcore)
    Gotta be careful engine braking on ice. It works great to maintain a lower speed. But not for slowing down. If you downshift, the wheels could skid just like steeping on the brake, but you won't be able to just let off the brake to get the wheels rolling again.
    Some high performance motorcycles have a slipper clutch that essentially prevents engine braking for this exact reason. engine braking can be more dangerous than using the brakes.
  9. Jan 1, 2013 at 6:05 PM
    OZ-T
    Peter North
    British Columbia
    Unfortunately untrue
  10. Jan 1, 2013 at 6:16 PM
    jermoids
    jermoids Well-Known Member
    Jeremy
    Winnipeg, Manitoba, Canada
    2021 TRD Sport
    17x9 Fuel Mavericks +1 offset 265/65/17 duratracs NFAB Epyx step sides AVS hood protector Thule xsporter pro rack Weathertech floor liners Tacoma rubber bed mat
    i think it has a lot to do with tires and driving habits. where i live it seems like it's winter 8 months a year, i have been driving on snow and ice for the last month and my abs rarely kicks in, you have to drive to the conditions. with saying that, since i put on my duratracs, i don't even need to use 4x4 anymore. when i had my stockers i couldn't even get into my flat driveway if there was a 1" snow drift with out spinning out.
  11. Jan 1, 2013 at 6:38 PM
    BamaToy1997
    Bill
    Navarre, FL
    The system has no idea what type of surface you are driving on. The ABS system watches for excessive wheel speed decline on specific wheels. When it detects that any single or multiple wheel "decelerates" faster than the others, it will pulsate the solenoid for that wheel's brake system to attempt to prevent lockup which causes slide, and loss of control.
    That being said, ANY small truck like the Tacoma or Frontier or the like will have an issue in snow or icy conditions. The lack of weight in the rear increases the chance of a rear wheel locking up and causing the ABS system to activate. Cars and larger trucks have more weight and/or better weight distribution so they tend to have a lower chance of a specific wheel set issue.
    When I lived in an area that was prone to snowy weather or ice I would always carry additional weight in the back of the bed. (Usually in the form of 2 bags of concrete near the tailgate) This helps in traction for acceleration as well as braking.
    Remember that the ABS system is not designed to help you stop faster. The purpose is to increase your control of the vehicle on uneven or slippery road conditions. However on icy roads or roads with slick snow, nobody, even a computer can predict traction. THAT is based on tires and the surface itself. Good tires will greatly improve the ABS system's ability to do it's job. Bad tires, and suspension changes such as lifts or poorly operating suspension components can drastically affect traction.
    I am reminded of a customer that we had when I worked for Cadillac. They complained that when they were coming to a stop passing over a set of railroad tracks near their home, the ABS system would activate. There we no codes stored and no problems with fluid contamination. After inspecting the vehicle I told the customer that he needed to replace the front struts because they were weak. He thought I was trying to snow him. He eventually agreed and after the struts were replaced, he no longer had an ABS activation going over the railroad tracks.
    So look at ALL parts of a truck that is having braking issues before disabling the ABS system. Just my professional opinion.
  12. Jan 1, 2013 at 6:41 PM
    boatswain
    boatswain Well-Known Member
    carl
    palmerton,PA.
    2018 Tacoma TRD Sport access cab, magnetic grey metallic.
    I also don't like the ABS system. Went halfway through an intersection before the truck stopped. It was bad enough with no ABS, having discs on the front, and drums on the rear, but I feel even less comfortable with the ABS.
  13. Jan 1, 2013 at 6:45 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    All the above
  14. Jan 1, 2013 at 6:50 PM
    1sttaco11
    1sttaco11 Well-Known Member
    Coleville, California
    TRD sport 4x4
    Fox 2.0 coil overs, ToyTec add-a-leaf, debadged, Marathon seatcovers, antennax stubby, Ted Nugent spear chucker sticker, American Outlaw wheels, 265/75/16 Goodyear Wrangler MTR's, Relentless bed bars, cargo basket, painted grille emblem, painted engine cover, flowmaster original 40 dumped at the axle.
    i use to have this problem when i had the OEM tires on, with just 2'' on the road it felt like the truck was on ice skates. Since then I have picked up a bitchin' set of aggressive tires and put a little weight in the rear, no more sliding around on the roads. And i live in the sierra nevada mountains where there is a ton of snow and steep grades to contend with. Plus, since its a new truck you've never drove in the snow it might take some time to get use to how it handles/performs compared to your previous truck. just a thought.
  15. Jan 1, 2013 at 7:20 PM
    #35
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    I wouldn't blame the truck or ABS in your case necessarily. If the road surface was super slick to the point that all 4 wheels locked up without resistance then the traction control wouldn't kick on... the truck just thinks your stopped. Your best bet in this case, like others said, would have been downshifting if there was any traction at all.
    Last weekend I tried a short climb that was basically solid ice. About 1/2 way up I lost momentum/traction and had to back down. As soon as I stopped on the climb I just slid back down like a sled with all 4 tires locked up. My truck just thought I was stopped the whole time since there wasn't any resistance telling it I was sliding.
    I find traction control annoying most of the time but it's always done well for me when braking on snowy roads where there is some traction to be had. Most of the time I can't even pitch the truck sideways in snow when I want to because of the traction control is working so well. Sometimes shit just happens on slippery surfaces and no driving skill/tires/vehicles/ etc is going to get out of it.
  16. Jan 1, 2013 at 7:31 PM
    #36
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Unfortunately not completely accurate. Hit a bump while going downhill on pavement or drive in snow and the abs is more inclined to kick in.
  17. Jan 1, 2013 at 7:44 PM
    #37
    gtmotor
    gtmotor Active Member
    I also noticed the sensitive ABS in the snow. I'm on OEM tires with a 2012 TRD OR. I adjusted my driving habits and the Tacoma has done exceptionally well in the snow. I don't feel like buying $600+ in new tires on a brand new truck so I'll just deal with it. It would suck to have an emergency stop though...
    Here's a picture of our cabin from this morning:
  18. Jan 1, 2013 at 8:00 PM
    #38
    WVHellbilly
    WVHellbilly Well-Known Member
    Mullens,WV
    2012 Tx Baja
    It sounds like some people need to adjust thier driving habits for slippery conditions.
  19. Jan 1, 2013 at 8:33 PM
    #39
    Haskett039
    Haskett039 Well-Known Member
    Rob
    Ontario, Canada
    2012 TRD Alpine White
    This is my first winter with my '12 TRD OR and i admit i was suprised at how poorly my truck performs in the snow. I pull forward into my driveway then back into the garage, once i stop the truck to put it in reverse i have to engage the 4WD just to get it moving again. And thats only in 3" - 5" of fresh snow and I have about 300+ lbs of extra weight in the back. Personally i think it is just the stock tires on the truck, with only 20,000kms on them i think i will be running snow tires next year.
  20. Jan 1, 2013 at 8:46 PM
    #40
    akhermit
    akhermit Well-Known Member
    Anchorage Alaska
    12 DCSB Magnetic Gray Metallic TRD Offroad
    I am in the middle of my first winter with the Tacoma, and I am actually impressed with it.
    As far as braking, the ABS is no more sensitive than other vehicles I have owned. I got rid of the OEM tires before winter and got the Michelin LTX M/S2 tires. When it is really slick, I drive slower. The slicker it gets, the slower I drive. The ABS only kicks in at really slick intersections, but I normally slow down ahead of time, to prevent it from kicking in at all.
    OP, are you sure that you were only going 15 MPH?
    As others have stated, the Rugged Trails are rated pretty poor for snow and ice.
    I have not put weight in the back yet, so in 2WD, I still spin a little taking off, but no issues in 4WD.
Thread Status:
