cant turn in 4low
Discussion in 'Technical Chat' started by JOJO316, Sep 5, 2009.
  1. Jul 1, 2012 at 2:17 AM
    Manwithoutaplan
    ID
    should say in your little instruction card on your sun visor.
  2. Jul 1, 2012 at 2:25 AM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
  3. Jul 1, 2012 at 2:26 AM
    BulletToothTony
    and again...
    lol ;)
  4. Jul 1, 2012 at 2:40 AM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    can you not get into 4-LO or can you just not turn? turning on pavement in 4-LO is always an awesome thing to do, and gives you a huge increase in horsepower as soon as you go back to 2wd. you have to really turn the wheels to full lock and push the gas as hard you possibly can though or else it wont work, and if you have a locker, engage that too.
    make sure you have AAA before you do that, they will have to come and turn on the secret switch in your engine to unleash the extra HP after you complete the steps above. everyone on this site has done it, our trucks really have 300 horse, we just gotta go thru this process to get the rest.
    :anonymous:
  5. Jul 1, 2012 at 2:53 AM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Hahahahahahahahaha :D
  6. Jul 1, 2012 at 2:57 AM
    650H1
    Michael
    VA
    haha :eek:
  7. Jul 1, 2012 at 6:10 AM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    I love these threads.
  8. Jul 6, 2012 at 11:42 AM
    JOJO316
    JOJO316 [OP] Member
    JOEL
    CHESAPEAKE VA
    STOCK 2009 TACOMA
    realy people i was just asking a ? when im on the beach and started to get stuck the truck would not turn to good and it smelt like it was burning the cluch i was just asking if this thing happen to any one elese or should take it to the shop thank you for you help
  9. Jul 6, 2012 at 11:53 AM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Sounds like it was still in 2wd and he was trying to rock it with the clutch... hence the burning clutch smell. Manual Tcase FTW!
  10. Jul 6, 2012 at 12:03 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Merged the 3 threads.
  11. Jul 6, 2012 at 12:09 PM
    BamaToy1997
    Bill
    Navarre, FL
    You should not try to load up your truck when at full turn. When you are stuck in sand, engage the 4wd and keep your wheel reasonably straight. Rock the wheel back and forth about 45-90 degrees while carefully accelerating. This will allow maximum traction and help clear the sand from the wheels (assuming you did not have it buried too deep) Sand is tricky to drive in if you are not experienced. No need to take it to the shop. This is normal for most all 4WD trucks.
  12. Jul 6, 2012 at 12:10 PM
    MXscott14
    MXscott14 Bartle Do Member
    Keith Stone
    In Front Of You
    2006 2nd generation antique
    Black Headlight, Foglight always on,
  13. Jul 6, 2012 at 12:13 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    sounds like you need to learn how to drive stick
  14. Jul 6, 2012 at 12:18 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Making sharp turns while in 4WD will cause binding and eventually break things. This is especially true on dry pavement but can even happen in dry snow conditions (like when pulling into a tight parking space) or on rock/hard pack dirt. This might be what your experiencing even on the beach if your close to getting stuck like you mentioned. Just get in the habit of making your turns a bit wider while in 4WD...don't ever turn with the wheels fully locked to one side or the other. If your actually stuck try to straighten out the wheels a bit before attempting to get out with 4WD engaged...easier on the clutch and the front end components. Read the links below for more information.
  15. Jul 6, 2012 at 1:48 PM
    #35
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I think you mean transfer case.
