Can't Turn Off Keyless Entry Beeps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Omerta, May 1, 2014.
  1. May 1, 2014 at 2:06 PM
    Omerta
    Omerta [OP] Member
    I've followed the instructions below numerous times, I can't figure out what I'm doing wrong. I hear the acknowledgement beep, but the car still beeps every time I go to lock or unlock. If anyone can help, I'd appreciate it.
    I have a 2009 TRD Tacoma, thanks.
    1. Open the driver's door, and insert the key into the ignition. Leave the door open.
    2. Remove the key from the ignition, and within 5 seconds, re-insert the key and then turn the ignition to ON.
    3. Wait at least 10 seconds, but less than 20 seconds. After waiting, press a button on the remote twice. Press the same button two times - don't press two different buttons. The system will acknowledge with a beep if you did it right.
    archerm3 likes this.
  2. May 1, 2014 at 2:12 PM
    The403Guy
    The403Guy Well-Known Member
    Calgary, AB
    14 DCLB TRD SPORT
    Pull by the dealership and they will do it for free
  3. May 9, 2014 at 6:41 PM
    Omerta
    Omerta [OP] Member
    Called 'em up, they want $120 to do it!
  4. May 9, 2014 at 11:40 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    unplug the beeper
  5. May 10, 2014 at 1:21 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    If my dealer pulled something like that on me ... $120 ... I'd find a new dealer.
  6. May 10, 2014 at 1:28 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    ^^^this...its by the fuse box iirc
  7. May 10, 2014 at 1:36 PM
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    Just unplug the beeper. Up close to the radiator on the drivers side. That way you can just plug it back an make it functional when you want it.
  8. Jun 1, 2014 at 5:37 AM
    The403Guy
    Calgary, AB
    14 DCLB TRD SPORT
    Had mine in for an oil change on Friday and asked them to disable this beeping and was quoted $30 to disable the door/keyless/seatbelt beeping. I went to pay and he said don't worry about it, no charge. $120 is ridiculous. When you find someone who does it for a reasonable price, make sure to let the manager of the original place know that they have lost your business for life.
  9. Jun 10, 2014 at 9:36 AM
    Omerta
    Omerta [OP] Member
    $120 is completely ridiculous. I called another few dealers, they all wanted over 100 bucks to do it!
    Does anyone have ANY ideas? I have a neighbor who has filed a complaint for noise abatement due to this horn problem and I don't have $100 to throw into the trash today. Thanks.
  10. Jun 10, 2014 at 10:47 AM
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    this worked with my 09
    Step one: Keep driver side door open. Insert key into ignition and take out.
    Step two: Put key back in ignition w/in five seconds. .
    step three: Turn to the "on" position, not the acc position and wait 10 seconds.
    Step four: click the "lock" or "unlock" twice as soon as the key is in the "on" position. You should here one continous beep for about a second.
    Step five: Take key out. Get out of truck. Shut door. Try your keyless entry button. You should get no beep but still see the parking lights flash.
    looks close to what you were doing but worded different
    Greenbean, jbeez4by and Rattlejay65 like this.
  11. Jun 10, 2014 at 11:43 AM
    Omerta
    Omerta [OP] Member
    This worked for the beep or for the horn? My problem is the horn, every time I lock or unlock, the beep AND the horn both sound.
  12. Jun 10, 2014 at 11:50 AM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    Nice neighbor. I hope you get this sorted out, but I'd really be pissed at the neighbor. Nitpicker for sure.
  13. Jun 10, 2014 at 12:04 PM
    Omerta
    Omerta [OP] Member
    Tell me about it. I'm desperate to turn the horn off now because if I ever have to deal with that person again I think I'm gonna get evicted or go to jail!
  14. Jun 10, 2014 at 12:31 PM
    Omerta
    Omerta [OP] Member
    Does anyone know why the horn honks when I lock my doors and most people just have a beep? I'm guessing this is some kind of upgraded alarm? I do have a flashing red LED to the driver's left.
  15. Jun 10, 2014 at 12:52 PM
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
    Why not just use the key instead? Is it that difficult to stick it in and twist?
  16. Jun 10, 2014 at 1:12 PM
    Omerta
    Omerta [OP] Member
    That sounds the horn as well.
  17. Jun 10, 2014 at 1:42 PM
    SIZZLE
    SIZZLE Pro-party
    Novato, CA
    2014 DCSB TRD Off Road
    A little a this, a little a that...
    My factory alarm doesn't trigger the horn. To turn off the alarm beep I just unplugged the beeper. Super fast and way easier than doing the rain dance. See if there's a wire at your horn coming from the alarm and unplug it.
  18. Jun 10, 2014 at 2:06 PM
    Omerta
    Omerta [OP] Member
    Wouldn't that disable the alarm also?
  19. Jun 10, 2014 at 2:29 PM
    medic2230
    Murph
    Bama! Roll Tide
    Shouldn't if the wire is going to the trucks horn.
    Kinda weird if you have a factory alarm and it sounds the horn. I've never seen a factory alarm do that on a Taco.
  20. Jun 10, 2014 at 3:32 PM
    Omerta
    Omerta [OP] Member
    The red LED is to the driver's left, looks like they put it on an empty button slot. There's no button underneath it unfortunately. The only button I see near the lever for the hood is the set button but I think that's for tire pressure isn't it?
