Can't Turn Off Keyless Entry Beeps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Omerta, May 1, 2014.
  1. Jun 10, 2014 at 10:09 PM
    Omerta
    Omerta [OP] Member
    I'm 100% sure the alarm came with the truck when I bought it brand new, 0 miles, at the dealer. Is calling the dealer the easiest way to figure this out? Thanks.
  2. Jun 10, 2014 at 11:04 PM
    Omerta
    Omerta [OP] Member
    Longo Toyota in El Monte(same guys who want $120 to disable it). I'll call them up and see what they have to say. Appreciate it Itaro.
  3. Jun 11, 2014 at 2:48 AM
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    Mine never honked the horn. I don't have any type of alarm that must be whats different.
  4. Jun 12, 2014 at 5:47 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    seems it must be an add-on item like the RS3200 I have on my '04. Keyless was there with a Piezo and they added the alarm for free (basically a glass breakage sensor) but never had the horn tied in.
    when I got my remote starter they tied into the horn for lock/unlock. now that I think about it I should ask them to get rid of this and maybe use the piezo instead....hmmm
  5. Jun 12, 2014 at 11:47 AM
    Omerta
    Omerta [OP] Member
    No luck yet, I'm still trying to get Longo to tell me what kind of alarm it is. They're really dragging their heels. Definitely wouldn't recommend these guys.
  6. Jun 12, 2014 at 3:13 PM
    wobble
    wobble Well-Known Member
    Ridgefield, WA
    2014 TRD OR
    Modified RCD Lift, 315/70R17 STT Pros
    Thank you! This worked on my 2014. It's been bugging me since I got the truck.
  7. Jun 12, 2014 at 3:18 PM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    I didn't read the entire thread but out of curiosity why would you not want your truck to beep when you lock the door? I could understand if it was obnoxiously loud but mine is pretty quiet and I like the conformation that it is locked.
    Sorry if I missed something by not reading the entire thread being on my phone.
  8. Jun 12, 2014 at 3:30 PM
    wobble
    Ridgefield, WA
    2014 TRD OR
    I find it unnecessary. I don't need a beep to let me know it's locked or unlocked. I can see the lights flash and I can hear the door lock actuators click.
    I also do a lot of camping in the summer. These beeps get a little irritating to those sleeping in tents near you that don't have the same sleeping schedule you do.
    I traded in my '05 for a '14 a few months ago. My '05 did not beep. I definitely missed that.
  9. Jun 12, 2014 at 3:35 PM
    la0d0g
    running for the hills
    For crawling not hauling
    x2
  10. Jun 13, 2014 at 7:39 AM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    The OP has a neighbor that filed some kind of "noise complaint" because of his alarm. Evidently, a half second beep is too much for some folks to put up with.:rolleyes:
  11. Jun 13, 2014 at 7:53 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    I put a piece of tape over the beeper. I poked a hole in the tape so it still makes a lower volume beep. I'd imagine if you taped over the whole thing it wouldn't make much if any sound.
  12. Jun 13, 2014 at 9:37 AM
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    I thought the same, turns out his horn also honks everytime as well. He's looking to find a way to make the horn stop honking, but still have the quiet chirp/beep.
  13. Jun 13, 2014 at 1:27 PM
    Omerta
    Omerta [OP] Member
    OK, called again and spoke to someone this time. I think they're just a huge dealership.
    It's called a "pursuit alarm" and the way to disable the horn is to cycle the key on and off 3 times in the ignition. So you insert the key into the ignition and turn it to the on position, then off, 3 times. No other instructions, worked for me. Hope this helps someone else cause what a headache for such a simple fix.
  14. Jun 13, 2014 at 6:00 PM
    mcdee
    mcdee Well-Known Member
    mike
    Northern Cal
    12 PreRunner OffRoad TRD
    TRD center cap, quick bed mat, Gatekeeper, WTs, TRD skid plate from bpfab, plastidip emblems, security slider bar, interior LEDs, AFE Pro Dry air filter
    Thanks for info , good to know and ez fix for you. In reading forum on this issue I couldn't figure out why some had the beeps and others didn't. Dealers may change them, either way this info should be in the factory manual IMO.
    SoCalSB likes this.
  15. Oct 31, 2014 at 10:40 AM
    #35
    sprucebowhunter
    sprucebowhunter Member
    Las Vegas
    14 Spruce Mica TRD Sport 4X4
    I know this post is a bit old but I discovered during hunting season that began shortly after I purchased my 2014 taco that the beep and honk no matter what i did was quite annoying...and would scare off or alert any critters that were nearby more than they should have been, I followed the instructions for the rockledge horn turn off email and the beep removal on page 1 and 2 and now all I have is the flashing lights and the sound of the doors locking/unlocking... Thanks to those on here who had more trouble than the rest of us to figure this out, no more annoyed neighbors and silence in the woods, oh and they both worked the first attempt... :headbang:
  16. Oct 31, 2014 at 11:44 AM
    #36
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    A note for those who have unplugged the sensor in the steering column so you don't get the beeping when the key is in the ignition: that sensor needs to be plugged in when you do the key cycle thing mentioned in the first post. If it's unplugged, the sequence won't work.
  17. Nov 20, 2014 at 8:06 AM
    #37
    McPhiiil
    McPhiiil Member
    Indiana
    2015 AC Taco SR5
    This works great on a 2015 :) Thanks for the info
  18. Nov 20, 2014 at 11:09 AM
    #38
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    - Lift hood
    - Hit key fob
    - Locate noise/sound/beep (right hand side)
    - Unplug beeper
  19. Nov 20, 2014 at 11:21 AM
    #39
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    I just tried this, could not find the horn for the life of me. My neighbors must have though I was nuts. Any chance you have a pic of the horn for a dummy like me?
    Scratch that. The process detailed above worked for me. No more beeps, but still have the lights.
  20. Nov 20, 2014 at 11:49 AM
    #40
    jpmorrisvb
    Jimmy
    Virginia Beach
    It's a little square box ... maybe 1" x 1" ... attached on radiator frame ...
    ... anyway ... glad it worked out good for you.
