Can't unplug wire harness... HELP!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thegoods06taco, Jan 5, 2011.
  1. Jan 5, 2011 at 8:31 AM
    thegoods06taco
    thegoods06taco [OP] New Member
    Utah
    06 Double Cab TRD
    3" lift, Wheels and Tires, Full stereo coming soon
    Does anyone out there know why the smaller wire harnesses on my AC/Heater fan assembly won't come unplugged? My fan chirps like crazy and I want to try lubricating the bearings. I removed the fan assembly from underneath the glove box, and unplugged the larger wire harness located under the dash, but I can't get the smaller one unplugged from the fan assembly. It seems to be completely locked in.
    It's rare that I run into a DIY project on my truck that I can't tackle, but I'm about to give up on this one. I'm worried I might damage the harness if I keep messing with it. Any advise or tips would be greatly appreciated.
  2. Jan 5, 2011 at 8:40 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Pictures of the connector?
  3. Jan 5, 2011 at 9:41 PM
    Bodete
    Bodete Well-Known Member
    Missouri
    2018 Tacoma TRD Off Road
    Mine was a bitch. I couldn't press the clip down far enough on the wiring harness to disengage it with just my fingers. I took a small flat head screw driver and pushed it between the clip of the wiring harness and the fan assembly. Press the clip down with the screw driver and and pull on the wiring harness. It should come loose.
