Can't Use Your Bed-Rail Cleats with Your Camper Shell?
Discussion in 'Tonneau Covers, Caps and Shells' started by DanCorcoran, Jun 20, 2011.
  1. Jun 20, 2011 at 5:57 AM
    DanCorcoran
    DanCorcoran [OP] Active Member
    Dan
    Richmond, VA
    2011 4x4 Auto Regular Cab
    (Update on June 25, 2011: see post #23 below...I've seen the error of my ways and now understand how to use the cleats!)
    When I had my A.R.E. camper shell installed (CX series), I was unable to use my Toyota adjustable bed-rail tiedown cleats (the lip of the shell blocked the track). Solution?
    I went to the A.R.E. dealer and ordered six bed-rail blocks (they are the small aluminum blocks that slide into the end of the rail, for fastening the clamps that hold the shell on). He said they'd be about $1.00 each, but ended up finding six spares in the warehouse, so he gave them to me free! (I ordered six so that I've have two for each rail).
    Then I went to Lowe's hardware section and bought six eye bolts. The aluminum blocks are already threaded, so I bought Stanley stainless steel eye bolts, 5/16" x 3 1/4". The threads on the bolts fit the threads on the blocks. I then removed one plastic end cap from each rail (they just pull off the end of the rail, lengthwise). Slide the blocks into the rail, replace the plastic cap, and screw an eye-bolt into each block (don't overtighten or you'll distort the track). Voila!
    The stainless steel bolts are more expensive than the regular ones, but will handle 130# safe working load each. The blocks for the front rail install as described above, but to get the blocks into the side rails, you'll first need to remove and replace the rear clamp on each side, since the clamp has its own block in the track. Once you have the blocks installed, you can either keep the eye-bolts in the blocks, or keep them in the cab and only install them when needed.
  2. Jun 20, 2011 at 6:24 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    How about some pics of said blocks?
  3. Jun 20, 2011 at 6:28 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Post some pics! I was able to use the OEM cleats with the MX series, maybe they're a different mounting system? :confused:
  4. Jun 20, 2011 at 6:51 AM
    Namyo
    Namyo -
  5. Jun 20, 2011 at 6:53 AM
    DanCorcoran
    Dan
    Richmond, VA
    If you have an A.R.E. shell, just look at the clamps holding the shell down on the truck. The block is the silver-colored piece, inside the track, that the clamp is screwed into. The block is about 1 1/4" inches long and is shaped like the inside of the track.
  6. Jun 20, 2011 at 7:49 AM
    DanCorcoran
    Dan
    Richmond, VA
    The lip of the shell covers the top edge of the rail, so that you can't insert the Toyota cleat. You can see three of the blocks...one under the clamp and one under each eye bolt.
  7. Jun 20, 2011 at 7:52 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    You can insert cleats at any point of the rail. There are notches on the rail just for that.
  8. Jun 20, 2011 at 8:07 AM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    my leer shell has clamps for the shell that still allow use of the rails. ill get pics later
  9. Jun 20, 2011 at 8:15 AM
    Pugga
    Massachusetts
    x2, that's how I got mine on there. Your rail doesn't look to hang down any lower than mine. They take a little work to get the cleats on and off but they're functional with the cap in place.
  10. Jun 20, 2011 at 1:39 PM
    DanCorcoran
    Dan
    Richmond, VA
    What year did you purchase your A.R.E. CX series shell?
  11. Jun 20, 2011 at 1:40 PM
    DanCorcoran
    Dan
    Richmond, VA
    What year did you purchase your CX series A.R.E. shell? I ask because I've read posts by other owners of 2011 models who couldn't install the cleats. Does your rail have the notches that BlueT mentioned?
  12. Jun 20, 2011 at 1:43 PM
    Pugga
    Massachusetts
    Not a clue, mine's an MX series and I bought it last year off a member here. He had it on a '05 or '06. He bought the truck used so neither of us know how old it is.
    The notches in are in the rail system, not the ARE shell.
  13. Jun 20, 2011 at 1:50 PM
    DanCorcoran
    Dan
    Richmond, VA
    Here's another view of the shell. You can see how the lip covers the top edge of the rail. When I unscrew the cleat all the way, the upper part is not long enough to go into the rail, plus the cleat is cocked at an angle.
  14. Jun 20, 2011 at 1:53 PM
    DanCorcoran
    Dan
    Richmond, VA
    Well actually, I was having trouble with a 2011 Tacoma and a 2011 CX series. My rail has no notches, so we're talking apples and oranges.
  15. Jun 20, 2011 at 3:26 PM
    whizkidder
    whizkidder Member
    Ron
    Fort Bragg, NC
    2011 DC 4x4 TRD OR
    Looks like an easy fix. Just trim the lower edge of the cap where it rolls over the inside edge of the bed to make clearance for the cleats. That much lip hanging down isn't needed.
  16. Jun 20, 2011 at 8:23 PM
    GuapOh
    GuapOh Well-Known Member
    Nor Cal
    2011 SR5 4x4 MT
    Skid Plate, Hood Protector, Wheel Locks, Snugtop XV, Yakima Rack, Weathertechs, Sick Speed Shifter, Avid Bumper, Avid Sliders, Bilstien 5100's, TSB Spring packs
    No problem with the Snugtop XV.
  17. Jun 23, 2011 at 9:02 PM
    cu52
    cu52 Well-Known Member
    Rocky Mountains - Denver
    2009 Crewmax Tundra Limited
    not a problem with my CX series, i have 4 mounting points that have holes to the center of the track and the topper connects at those four points (just like post #3). came off a topper purchased in 2009, maybe you have the old design.
  18. Jun 24, 2011 at 6:23 AM
    DanCorcoran
    Dan
    Richmond, VA
    Mine was purchased new from the factory two months ago...yours is two years older than mine. Post #3 says they have an MX series top, not CX.
  19. Jun 24, 2011 at 6:33 AM
    Pugga
    Massachusetts
    We have the same bed rail system in our trucks, no apples and oranges. There are notches in your bed rail. Slide the cleats down the bed rail and you'll feel them set in place at the notches. Mine covers the top edge of the rail also but I'm still able to use the cleats. If you unscrew the cleat all the way, turn it sideways to insert the metal clip then twist and it'll clip into the rail system and straighten out when you tighten it. If you've found an alternative that works, power to ya, just trying to show you that it is possible to use the stock cleats with the cap. It's not a perfect fit but it works.
  20. Jun 24, 2011 at 5:20 PM
    DanCorcoran
    Dan
    Richmond, VA
    The lip on your cap looks nothing like mine. I don't think you have a 2011 CX series cap. See the photo with post #6 above. My cap is held on with a five-piece clamp.
