Cap City Build & BS AF
Discussion in '2nd Gen. Builds (2005-2015)' started by ChadsPride, Apr 16, 2016.
  1. Nov 16, 2016 at 6:05 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Well still fuck that guy haha, unless he is on here. Then still fuck that guy :p
  2. Nov 16, 2016 at 6:08 AM
    ChadsPride
    ChadsPride [OP] Tacoma Owner & Enthusiast
    Sponsored by TacomaWorld.com
    :goingcrazy:
  3. Nov 16, 2016 at 6:14 AM
    -dustin
    -dustin Well-Known Member
    Leander, TX
    2020SWDCSBTRDPROFTW
    dumb question alert!
    how do in-channel work? is there plastic touching the glass or is it sandwiched between the seal and the door?
    is anyone else seeing the Christy Mack poster as one of the products being discussed in this thread?
    ChadsPride[OP] and yota243 like this.
  4. Nov 16, 2016 at 6:22 AM
    ChadsPride
    Not sure.
    Yes.
  5. Nov 16, 2016 at 6:22 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    My AVS has an adhesive strip that faces out. It's positioned in the window channel groove and adhered to the weatherstripping (I think...maybe not) on the outer edge of the door. The window does come in contact with the plastic on the very top edge of the window. About 3/8" if I had to guess.
    SpruceTaco and ChadsPride[OP] like this.
  6. Nov 16, 2016 at 6:27 AM
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    Instead of being glued to the outside of the window, they attach to the steel inside the window channel. They come with alcohol cleaning pads for you to REALLY CLEAN THE CRAP out of the channels to make sure that painted area is clean. You then drop the windows, peel a corner of adhesive protective tape, place the visor in position, and carefully peel the protective tape off. Once in position you roll the windows up.
    Once you do the first, the others go FAST.
    SpruceTaco, Sig45 and ChadsPride[OP] like this.
  7. Nov 16, 2016 at 7:17 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    Hook em fuckin horns brothers!!! :headbang:
  8. Nov 16, 2016 at 7:18 AM
    ChadsPride
    :woot::woot::woot::woot::woot:
  9. Nov 16, 2016 at 7:18 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    Fuck that, we already gave him 600 bucks. if you wanna buy em for a poor person there's always me
  10. Nov 16, 2016 at 7:20 AM
    Truggin
    Truggin What a long, strange trip it's been
    Don
    39.15737720308645, -77.92212986904099
    Black 2016 TRD Sport V6 4x4 Access Cab
    It's a work in progress. See my build thread.
    Christmas is coming....
    ChadsPride[OP] and Sig45[QUOTED] like this.
  11. Nov 16, 2016 at 7:30 AM
    Sig45
    Mark
    Maine
    What did he do with the $600? Blow it on strippers?
    ChadsPride[OP] likes this.
  12. Nov 16, 2016 at 7:31 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    Where have you been?
  13. Nov 16, 2016 at 7:32 AM
    Sig45
    Mark
    Maine
    I evidently missed that. :confused::confused:
  14. Nov 16, 2016 at 7:34 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
  15. Nov 16, 2016 at 7:37 AM
    ChadsPride
    Bought my spindles or Dakars with it. whatever way you wanna look at it.
  16. Nov 16, 2016 at 7:38 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    See,,, you did spend it on the hoes.
  17. Nov 16, 2016 at 7:38 AM
    Pigpen
    Dan
    Northwest Montana
    We bought him the bulk of his lift
    Sig45[QUOTED] and ChadsPride[OP] like this.
  18. Nov 16, 2016 at 7:40 AM
    ChadsPride
    Damn truck gets more action than me!
    Sig45 likes this.
  19. Nov 16, 2016 at 7:40 AM
    Pigpen
    Dan
    Northwest Montana
    It started a GoFundMe epidemic that needed to be squashed by the mods.
    Sig45 likes this.
  20. Nov 16, 2016 at 7:40 AM
    ChadsPride
    BYJOSHCOOK and Sig45 like this.
