Cap City Build & BS AF
Discussion in '2nd Gen. Builds (2005-2015)' started by ChadsPride, Apr 16, 2016.
  1. Feb 12, 2021 at 5:15 AM
    Built2Ride
    Built2Ride Who wants to ride out?! PM Me.
    JB
    Southeast
    ‘17 TacoTRDPro, ‘18 T4RTRDPro, ‘12 Tundra, ‘07 FJC
    All my rigs are purpose built. From crawling to camping. I also enjoy a nice stock truck for what that’s worth. Toyota’s are the jam!
    I have to do this throughout the season. Up on the top of the mtn shit will freeze up quick, I actually put radiator fluid in my drains and dishwasher, after I perform the drain out that Bill described above.
    MarX, lynyrd3, 23Skidoo and 3 others like this.
  2. Feb 12, 2021 at 6:00 AM
    ChadsPride
    ChadsPride [OP] Tacoma Owner & Enthusiast
    Sponsored by TacomaWorld.com
  3. Feb 12, 2021 at 6:06 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Mornin Chad and folks :wave:
    medic2230, MarX, lynyrd3 and 6 others like this.
  4. Feb 12, 2021 at 8:35 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Mornin All, :)
    medic2230, MarX, lynyrd3 and 5 others like this.
  5. Feb 12, 2021 at 8:38 AM
    FastEddy59
    Eddie
    This forecast will change. It’s -42 with no W/C nearby. Should be updated by noon unless time freezes.
    medic2230, MarX, lynyrd3 and 4 others like this.
  6. Feb 12, 2021 at 8:52 AM
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    MarX, lynyrd3, Taco critter and 3 others like this.
  7. Feb 12, 2021 at 11:12 AM
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
    Afternoon :wave:
  8. Feb 12, 2021 at 5:13 PM
    23Skidoo
    Paul
    meme
    From one of my HVAC/plumbing subs.
    weather coming and make sure you knew how to protect your pipes from bursting. This one is the real deal. Thousands of pipes will be broken all over Austin, and while we love working with you, we would really like you to not have an emergency this upcoming week.
    The areas that are the greatest concern are:
    1. Hose Bibs - Disconnect the hose, and run a trickle of water on all of them. IF you have frost free hose bibs, then you do not need to run water. They will be just fine. VERY FEWa homes in Austin have frost free hose bibs. If you are not sure, run water.
    2. All Fixtures on the Outside Walls of Your Home - They are susceptible to freezing behind the wall. Trickle water through your sinks and tub valves that are on exterior walls. This is particularly important on older homes and on the side of the home getting the most wind with no sun. Opening up your cabinets to help warm air get to the pipes in these exterior areas helps too.
    3. RPZ & Double Check Valves - These devices may be feeding your pool or sprinkler system. They come out of the ground and are completely exposed to the elements in most cases. Insulate these any way you can. If you can figure out how to shut the water off to these valves, that would be ideal.
    4. Outdoor Tankless Water Heaters - Tankless are very susceptible to freezing up if you are not trickling water on the hot side. Most tankless will not fire at a very low flow rate, so if you are worried about burning gas all night, you should be fine with a moderate flow. You will be happy if your tankless is 100% operational when you wake up in the morning.
    5. Outdoor Kitchens - These always take a beating and will for sure be destroyed if you are not running water through them.
    Random Tip :) - If you want to get the most out of your A/C-heating system or it struggles to keep up when it gets really cold, changing your filter will give you the best possible performance your system can give. You know that thing is full of cedar pollen anyway, so I highly recommend getting a new one right away.”
  9. Feb 12, 2021 at 5:34 PM
    23Skidoo
    Paul
    meme
    I’m not dripping mine, just covering them. It was easier when I lived in Ohio. Go to basement, shut them off and drain them.
  10. Feb 12, 2021 at 5:35 PM
    ChadsPride
    :bowdown:
    MarX, lynyrd3 and 23Skidoo[QUOTED] like this.
  11. Feb 12, 2021 at 5:35 PM
    ChadsPride
    Fookin skeeeeeeerud
  12. Feb 12, 2021 at 5:41 PM
    lynyrd3
    Bill
    East Central Upstate NY
    :rofl: It’s 9* here right now ,brrrr
  13. Feb 12, 2021 at 5:42 PM
    23Skidoo
    Paul
    meme
  14. Feb 12, 2021 at 5:44 PM
    ChadsPride
    These homes weren't built for this :laugh:
    I've got one as well, going to asses tings more mañana
  15. Feb 12, 2021 at 5:44 PM
    23Skidoo
    Paul
    meme
    Older houses in Austin are barely insulated. We will drop to 2 degrees on Monday, breaking the the record set in 89.
    Pipes are going to freeze, then leak.
  16. Feb 12, 2021 at 5:46 PM
    lynyrd3
    Bill
    Good time to be a plumber I guess :spending:
  17. Feb 12, 2021 at 5:46 PM
    23Skidoo
    Paul
    meme
    It looks like all three of my hose bibs froze at one time. They all have a repair coupling on them.
    MarX, ChadsPride[OP] and lynyrd3 like this.
  18. Feb 12, 2021 at 5:47 PM
    23Skidoo
    Paul
    meme
    We put tankless water heaters outside. :bananadead:
  19. Feb 12, 2021 at 5:47 PM
    lynyrd3
    Bill
    I’m sure most homes down there are not built to handle that cold . Even up here a lot of the older homes are poorly insulated . I gutted mine back in 1994 when I bought it and some walls had nothing .
  20. Feb 12, 2021 at 5:47 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    medic2230, Built2Ride, MarX and 3 others like this.
