Cap City Build & BS AF
Discussion in '2nd Gen. Builds (2005-2015)' started by ChadsPride, Apr 16, 2016.
  1. Dec 17, 2016 at 6:50 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    Cold air is more dense, engine runs better
  2. Dec 17, 2016 at 6:52 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Its been misting all day. Too hot to hunt even if the wind wasnt blowing 30 mph and wet. I delivered a holster, built a quilt ladder, amd watch some netfilx and youtube. Also made some bomb biscuits if i do say so myself
  3. Dec 17, 2016 at 6:52 PM
    Pigpen
    Dan
    Northwest Montana
    Less moisture, more oxygen
    ChadsPride[OP] likes this.
  4. Dec 17, 2016 at 6:52 PM
    ChadsPride
    ChadsPride [OP] Tacoma Owner & Enthusiast
    Sponsored by TacomaWorld.com
    I can see that lol
    Pigpen[QUOTED] likes this.
  5. Dec 17, 2016 at 6:53 PM
    yota243
    E.J.
    north Alabama
    Dense air also creates more drag and requires more fuel to maintain a 14.7:1 afr.
    ChadsPride[OP] and Pigpen like this.
  6. Dec 17, 2016 at 6:56 PM
    Pigpen
    Dan
    Northwest Montana
    Makes a big difference at the rifle range, especially when practicing longer work.
  7. Dec 17, 2016 at 6:58 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Hmmm... well I'm stumped
    Pigpen and ChadsPride[OP] like this.
  8. Dec 17, 2016 at 6:58 PM
    ChadsPride
    Everybody had a good day?
    DustStorm4x4 and yota243 like this.
  9. Dec 17, 2016 at 7:01 PM
    yota243
    E.J.
    north Alabama
    Well depending on how much he went up in elevation, That may have been enough to offset the cold increasing density otherwise i too am stumped
  10. Dec 17, 2016 at 7:02 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    I was actually thinking elevation might play a factor but don't know enough about it to contribute anything lol
  11. Dec 17, 2016 at 7:02 PM
    yota243
    E.J.
    north Alabama
    Better than a work day
  12. Dec 17, 2016 at 7:04 PM
    ChadsPride
    I was honestly thinking because the more gas being used the lighter it was....making the milage go up 1.5mpg.
    That's at an average speed of 61 mph
    because_wumbo-truck likes this.
  13. Dec 17, 2016 at 7:07 PM
    yota243
    E.J.
    north Alabama
    It might in somethin with a really big tank but gas only weighs a little more than 6 lbs per gallon and u only have a 17 gallon tank. So thats gonna be less than 100lbs difference. Not even a passenger weigh difference. It might help but it wouldnt be 5%
    Did u take a really big poop there?
  14. Dec 17, 2016 at 7:08 PM
    Pigpen
    Dan
    Northwest Montana
    It was just happy to be out for a drive. That's all
  15. Dec 17, 2016 at 7:09 PM
    yota243
    E.J.
    north Alabama
    Do any drafting comin home like behind a semi?
  16. Dec 17, 2016 at 7:12 PM
    ChadsPride
    Tbh, not even sure how big the tank is on the Rav. When I filled it up before we left this morning I got 10.5 gallons in but it already had just under a quarter tank.
    That's a great Lil car.
    I think you may be right!!! Rolled over 2k on milage today!!
    Nah not really. I usually just pass em and create space behind and in front of me so I can roll solo.
    Hit some heavy traffic when we got back to Austin tho
  17. Dec 17, 2016 at 7:21 PM
    yota243
    E.J.
    north Alabama
    Yeah my wife has an 07 with the 2.4 she gets 24-25 driving around home. And will get 27ish runnin 80 on the hwy . 16xxxx miles and runs pretty dang good. Leaks a little oil, bout a quart every 3k miles and the 06 and 07 had a problem with a leaky cowl, i took some black pipe insulation and plugged about half the slits and fuxed that. It would get a wet floor board in a hard rain before.
    Probably be my daughters first car in 13 years or so
  18. Dec 17, 2016 at 7:22 PM
    -dustin
    -dustin Well-Known Member
    Leander, TX
    2020SWDCSBTRDPROFTW
    2hrs ago it was 73. Now it's 37.
  19. Dec 17, 2016 at 7:23 PM
    yota243
    E.J.
    north Alabama
    I ate an orange this week; i suggest u do the same
  20. Dec 17, 2016 at 7:24 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    My parents are going to your neck of the woods to visit my aunt and uncle Tuesday. I hope they don't freeze
