Cap City Build & BS AF
Discussion in '2nd Gen. Builds (2005-2015)' started by ChadsPride, Apr 16, 2016.
  1. Aug 29, 2016 at 6:52 PM
    #5641
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    Keep them dry and they will be fine
  2. Aug 29, 2016 at 6:52 PM
    #5642
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    One time use?
  3. Aug 29, 2016 at 6:53 PM
    #5643
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
  4. Aug 29, 2016 at 6:55 PM
    #5644
    Skyway
    Ande'
    St.Pete
    Just get out of the man cave and cozy up to a bar!
    Tender!
    ChadsPride[OP] likes this.
  5. Aug 29, 2016 at 7:02 PM
    #5645
    ChadsPride
    ChadsPride [OP] Tacoma Owner & Enthusiast
    Sponsored by TacomaWorld.com
    Luckily we have a few bars in Austin
  6. Aug 29, 2016 at 7:14 PM
    #5646
    ChadsPride
    I have to hit the hay yall.
    GOODNIGHT
    TACOMAWORLD
  7. Aug 29, 2016 at 7:21 PM
    #5647
    Ohiophil
    Ohiophil This space intentionally left blank
    Phil
    Central Ohio
    2015 Tacoma PreRunner
    Give me some money so I can fill in this info
    If OP = original postS, then every post would be OP. Dillhole
  8. Aug 29, 2016 at 7:21 PM
    #5648
    -dustin
    -dustin Well-Known Member
    Leander, TX
    2020SWDCSBTRDPROFTW
    It's 9. There better be a chick in that hay. Or dude. However you swang.
  9. Aug 29, 2016 at 7:25 PM
    #5649
    Skyway
    Ande'
    St.Pete
    Because- Buttercup ....
  10. Aug 29, 2016 at 7:32 PM
    #5650
    Pigpen
    Dan
    Northwest Montana
    My 5100s just sold to a guy outside Columbus
  11. Aug 29, 2016 at 7:32 PM
    #5651
    Pigpen
    Dan
    Northwest Montana
    ...in Blacklick
  12. Aug 29, 2016 at 7:34 PM
    #5652
    Skyway
    Ande'
    St.Pete
    That don't sounnd like no place I wanta ever go.... Ever never!
  13. Aug 29, 2016 at 7:40 PM
    #5653
    -dustin
    Leander, TX
    2020SWDCSBTRDPROFTW
    ....damn
  14. Aug 29, 2016 at 7:41 PM
    #5654
    Ohiophil
    Phil
    Central Ohio
    Doesn't sound appetizing, but it's actually a decent area
  15. Aug 29, 2016 at 7:42 PM
    #5655
    Ohiophil
    Phil
    Central Ohio
    Did you not like 5100s?
  16. Aug 29, 2016 at 7:43 PM
    #5656
    Skyway
    Ande'
    St.Pete
    They ought change that name to saltlick!
  17. Aug 29, 2016 at 7:46 PM
    #5657
    Skyway
    Ande'
    St.Pete
    Did you order the sill protectors?...
  18. Aug 29, 2016 at 7:48 PM
    #5658
    Skyway
    Ande'
    St.Pete
    They are cool and all but I don't really notice I have them....
    It's just not the wow factor that I thought I would get...
  19. Aug 29, 2016 at 7:49 PM
    #5659
    Ohiophil
    Phil
    Central Ohio
    Not yet. I will though.
  20. Aug 29, 2016 at 7:50 PM
    #5660
    Pigpen
    Dan
    Northwest Montana
    Depends on how you look at it...
