Cap City Build & BS AF
Discussion in '2nd Gen. Builds (2005-2015)' started by ChadsPride, Apr 16, 2016.
  1. May 17, 2017 at 8:01 AM
    ChadsPride
    ChadsPride [OP] Tacoma Owner & Enthusiast
    Sponsored by TacomaWorld.com
    Rock on man!! :headbang::headbang::headbang:
  2. May 17, 2017 at 8:10 AM
    Pigpen
    Dan
    Northwest Montana
    All in good time. I have insanely easy access to great rivers just minutes from my front door. Travelling costs money, which is made by working - which wastes the time one could be using for play.
    It looks like we're going to try to put together a trip on the Main section of the Salmon River up north of you this fall. I'm more into the wilderness aspect of these trips than the white water. They Payette has epic white water, but soooooo many people are on it and it's not exactly in a wilderness area...
  3. May 17, 2017 at 8:18 AM
    Pigpen
    Dan
    Northwest Montana
    You have my attention
  4. May 17, 2017 at 8:25 AM
    Pigpen
    Dan
    Northwest Montana
    I like you even more now
  5. May 17, 2017 at 8:26 AM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    So much BS in my thread! Turning into this thread quick!
    That's what I get for actually building lol
  6. May 17, 2017 at 8:26 AM
    JayMac
    JayMac I'm not bad... I'm just drawn that way.
    Jessica
    Oregon
    2007 DCLBFTMFW
    Did you just leave your bs thread to come to Chad's bs thread to talk about your bs thread?? o_O
  7. May 17, 2017 at 8:28 AM
    dirty deeds
    Nick
    Eastern KY
    First rule about bs thread, don't talk about bs thread.
  8. May 17, 2017 at 8:28 AM
    ChadsPride
    Show off!!! :p
    Send stickers, or no bushings lol.​
  9. May 17, 2017 at 8:29 AM
    dirty deeds
    Nick
    Eastern KY
    FACK! I forgot again!
    I need to PP doll hairs to you too! btw, you figure out how wide the widest part in that kit is?
  10. May 17, 2017 at 8:30 AM
    ChadsPride
    It's just 2 bushings
    I would say each is 3x1.5
    dirty deeds[QUOTED] likes this.
  11. May 17, 2017 at 8:31 AM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    This^^^
    It has a big jet in it that creates a current you swim against & that allows you to swim laps in a small space. When I built pools we did a couple similar to that but the were concrete.
    MarX, medic2230 and ChadsPride[OP] like this.
  12. May 17, 2017 at 8:32 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  13. May 17, 2017 at 8:33 AM
    ChadsPride
    You, are the man.
    yota243[QUOTED] likes this.
  14. May 17, 2017 at 8:35 AM
    Roll Tide
    Roll Tide COO COO KACHOO
    Q
    Here and there. Sometimes.
    01 T4R
    Head unit. That's it.
    Stupid. Pools are for drinking, and hot bitches....
    Not actually swimming.
  15. May 17, 2017 at 8:36 AM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    This Ford is a pain in the ass. Leaking coolant crossover, and you have to remove intake just to undo the frickin bolts.
  16. May 17, 2017 at 8:42 AM
    Pigpen
    Dan
    Northwest Montana
    Finally getting around to breakfast. Sausage in the pancake. Eggs for gooey goodness.
  17. May 17, 2017 at 8:42 AM
    JayMac
    Jessica
    Oregon
    2007 DCLBFTMFW
    I DO WHAT I WANT.
  18. May 17, 2017 at 8:43 AM
    ChadsPride
    :drool::drool::drool::drool::drool::drool:
    JayMac likes this.
  19. May 17, 2017 at 8:45 AM
    JayMac
    Jessica
    Oregon
    2007 DCLBFTMFW
    Srsly x2
  20. May 17, 2017 at 8:46 AM
    medic2230
    Murph
    Bama! Roll Tide
    That's one of those pools you can keep swimming in and has a current. Don't need a huge pool because the water is moving in it.
    ChadsPride[OP] likes this.
