Cap City Build & BS AF
Discussion in '2nd Gen. Builds (2005-2015)' started by ChadsPride, Apr 16, 2016.
  1. May 17, 2017 at 2:50 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    Oh lord.
    There's another?!
    JayMac[QUOTED] and KelticAngel like this.
  2. May 17, 2017 at 2:50 PM
    medic2230
    Murph
    Bama! Roll Tide
    I gave you a step by step as to how to line them up. o_O
    The only thing on that sheet you need to use to install the snorkel is the one for the big hole. The small one's don't line up with the snorkel. Make a pattern with a piece of cardboard with big hole cut out. Then put snorkel through hole in cardboard. Put the studs in the snorkel and make the impression on the cardboard to where you know where to place the holes. Use a drill bit and drill out the stud holes. Use that patter on the truck to mark the small hole locations. Everything will fit perfect.
  3. May 17, 2017 at 2:51 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    23Skidoo and KelticAngel like this.
  4. May 17, 2017 at 2:52 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Should I stream it on Twitch?
    medic2230[QUOTED] and JayMac like this.
  5. May 17, 2017 at 2:52 PM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    .ok.:dancingbacon:
    KelticAngel[QUOTED] likes this.
  6. May 17, 2017 at 2:52 PM
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
    No excuse.
    Are they camo?
  7. May 17, 2017 at 2:56 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
  8. May 17, 2017 at 2:56 PM
    JayMac
    JayMac I'm not bad... I'm just drawn that way.
    Jessica
    Oregon
    2007 DCLBFTMFW
    So this brings me to a very important debate that came up recently: which is more important? Lacy bits from VS or truck parts?
    I was drunk and my automotive engineer totally fucked it up.
    :fingerscrossed::fingerscrossed::fingerscrossed:
    Yes. Would watch.
  9. May 17, 2017 at 2:57 PM
    Benzdriver81
    Kevin
    PNW
    05 DCLB Sport
    :pout:
  10. May 17, 2017 at 2:58 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    How do you have that kind of money?!
  11. May 17, 2017 at 2:59 PM
    Pigpen
    Dan
    Northwest Montana
    I fail to see a problem here
  12. May 17, 2017 at 2:59 PM
    JRunTaco15
    JRunTaco15 Well-Known Member
    Jake
    Hickman, TN
    2005 Blue Tacoma TRD
    4.5 in toyotech lift. access cab. 160,000+ miles v6 4.0
    I'll be damned if I spend $28 on a pair of underwear. She got me fucked up then....
    KelticAngel and greeneggsnspam like this.
  13. May 17, 2017 at 2:59 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    But I'm already going to do a gif stream on Sunday. And do them regularly.
    Plus I'm already halfway to the 12 hour gif a thon
    23Skidoo and JayMac[QUOTED] like this.
  14. May 17, 2017 at 2:59 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    I buy the packs for like $10. Thank you Target.
    medic2230 likes this.
  15. May 17, 2017 at 3:00 PM
    Pigpen
    Dan
    Northwest Montana
    I just dropped $250 on raft stuff I could easily live without.
    medic2230 and JayMac like this.
  16. May 17, 2017 at 3:00 PM
    JRunTaco15
    Jake
    Hickman, TN
    That's what I'm saying. Hanes is the real MVP.
  17. May 17, 2017 at 3:01 PM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    I like a cool truck.
    I LOVE....
    Well, Let's just say there's more important things in life than truck parts.....
    medic2230, JayMac and JRunTaco15 like this.
  18. May 17, 2017 at 3:02 PM
    medic2230
    Murph
    Bama! Roll Tide
    Don't most peeps go 4.5" BS and yours are 3.5 bs? The spindle pushes out an inch so that brings you to the same as 4.5" bs? So basically your the same as a 4x4 with 4.5" bs wheels. If you are rubbing on the firewall turning you need to re-evaluate your alignment. Push dem bitches forward.
    Bluegrass Taco likes this.
  19. May 17, 2017 at 3:05 PM
    Pigpen
    Dan
    Northwest Montana
    Trailer progress. Yesterday, the cage was part of the trailer.
    Ready to weld. More pics later.
    dirty deeds and JayMac like this.
  20. May 17, 2017 at 3:07 PM
    Pigpen
    Dan
    Northwest Montana
    Ladies underwear isn't the best thing in life, but it's very close to it!
    JayMac likes this.
