Cap City Build & BS AF
Discussion in '2nd Gen. Builds (2005-2015)' started by ChadsPride, Apr 16, 2016.
  1. Sep 21, 2016 at 8:25 AM
    ChadsPride
    ChadsPride [OP] Tacoma Owner & Enthusiast
    Sponsored by TacomaWorld.com
    scottalot likes this.
  2. Sep 21, 2016 at 8:28 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    No, no I don't o_O
  3. Sep 21, 2016 at 8:32 AM
    ChadsPride
    It's pretty fun. I use it a lot talking to the old lady.
  4. Sep 21, 2016 at 9:49 AM
    ChadsPride
    Even though it's been said a million times, I will ask it again anyways.
    What are good alignment numbers I should be looking for after lifting??
    Thank you
  5. Sep 21, 2016 at 9:54 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    0,0,3.0
    3.0 is the tough one to get, if there is a question, get the first two as close to zero as possible with as much of the other as is possible.
  6. Sep 21, 2016 at 10:06 AM
    ChadsPride
    And what order are those in?
  7. Sep 21, 2016 at 10:16 AM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    Remember when they have the kiddo...
    Noemi is gone be One Phat Ass!
    Put the '0' on the passengers side....
    The NTB is open until 8 pm, ask when the best alignment tech is on duty and then schedule appt.
    I would say between 4 & 6 so you can take more time on the install.
    Speedy Gonzales!
  8. Sep 21, 2016 at 10:17 AM
    Skyway
    Ande'
    St.Pete
    I guess momma's not available...
    ChadsPride[OP] likes this.
  9. Sep 21, 2016 at 10:18 AM
    medic2230
    Murph
    Bama! Roll Tide
  10. Sep 21, 2016 at 10:20 AM
    Skyway
    Ande'
    St.Pete
    :rofl::rofl::rofl::cheers:
  11. Sep 21, 2016 at 10:25 AM
    Skyway
    Ande'
    St.Pete
    You need a Super Pump your GF!
  12. Sep 21, 2016 at 10:29 AM
    Skyway
    Ande'
    St.Pete
    @ Because_chad didn't like this?
  13. Sep 21, 2016 at 10:41 AM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    Even though your lifting it & the alignment will be off it shouldn't be a problem getting it back into spec, the Maxtracs don't change the geometry. Now that I think about it @ChadsPride yours probably won't be as bad as mine or Black Horse's were cuz we both added nearly 3" more lift with the 5100's.
  14. Sep 21, 2016 at 10:46 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Understand your point, but I don't like to let them align to "spec" per se, because the range that is allowed in spec still makes the truck feel light and track a bit non-optimal. By specifying 0,0,3.0 to the tech, they tend to align it tighter to that and the truck just drives better. IMHO anyway
  15. Sep 21, 2016 at 11:17 AM
    ChadsPride
    So basically what I'm getting is I want
    Camber 0
    Toe. 0
    And caster around a 3
    medic2230 likes this.
  16. Sep 21, 2016 at 11:32 AM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Yeah that makes sense, keeps them from being lazy. Haha
  17. Sep 21, 2016 at 11:34 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    NP. Case in point, I am not lifted, just 5100s at 1.0, but I find my truck drives/tracks better at 0/0/3.0 than at spec ranges.
  18. Sep 21, 2016 at 11:37 AM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
  19. Sep 21, 2016 at 11:45 AM
    Ohiophil
    Ohiophil This space intentionally left blank
    Phil
    Central Ohio
    2015 Tacoma PreRunner
    Give me some money so I can fill in this info
    Do the home alignment chad. Might take 3 days but you'll save $.
  20. Sep 21, 2016 at 11:48 AM
    ChadsPride
    :humble:
    I appreciate the help gentlemen. Just hoping that they will try and achieve the number I would like.
    0 camber
    0 toe
    3 caster
