Cap City Build & BS AF
Discussion in '2nd Gen. Builds (2005-2015)' started by ChadsPride, Apr 16, 2016.
  1. Nov 1, 2016 at 8:32 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
  2. Nov 1, 2016 at 8:35 AM
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    Murder dog just uses laundry baskets as beds. Cuts out the middledog.
  3. Nov 1, 2016 at 8:36 AM
    Sig45
    Mark
    Maine
    I'm up the earliest - 5:00AM....everyone else stays in bed until after I've shit, showered & shaved and then come back to get dressed.
    ChadsPride[OP] likes this.
  4. Nov 1, 2016 at 8:40 AM
    medic2230
    Murph
    Bama! Roll Tide
    The 3 S's. :thumbsup:
    Me and little man are usually the last one's to get up in the morning.
    Sig45[QUOTED] and ChadsPride[OP] like this.
  5. Nov 1, 2016 at 8:40 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Ha that sucks, I just want one that has my RTT level with my Prinsu rack, square tubing and then have the holes line up with the holes already drilled into my bed. Plus a Hi-lift mount and maybe some D-rings from my old rack welded to it
  6. Nov 1, 2016 at 8:40 AM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    That grill is ON FIRE!:bananadead:
    The thing in the bed, what is it and how much do they run? Appears to be a viable option while hauling 1 or 2 yaks and have a tent on there, or haul 2 more yaks on that platform doohickey
  7. Nov 1, 2016 at 8:41 AM
    medic2230
    Murph
    Bama! Roll Tide
  8. Nov 1, 2016 at 8:41 AM
    Sig45
    Mark
    Maine
    If my G/F is positioned properly...I sometimes surprise her with a good ole' Door Knob!! :rofl::rofl:
    I'm 46...you'd think I'd grow up!!
  9. Nov 1, 2016 at 8:42 AM
    medic2230
    Murph
    Bama! Roll Tide
    No it isn't. I got the polished devil horns. :rolleyes:
  10. Nov 1, 2016 at 8:43 AM
    Sig45
    Mark
    Maine
    I forgot to add.....I don't drink that shit. Get all my coffee from a great local place.
    http://www.carrabassettcoffee.com/
  11. Nov 1, 2016 at 8:43 AM
    CaptAmerica
    Cap
  12. Nov 1, 2016 at 8:43 AM
    ChadsPride
    ChadsPride [OP] Tacoma Owner & Enthusiast
    Sponsored by TacomaWorld.com
    :headbang::headbang::headbang::headbang::headbang:
    Sig45[QUOTED] likes this.
  13. Nov 1, 2016 at 8:44 AM
    medic2230
    Murph
    Bama! Roll Tide
    I just noticed you had a 2000. That would actually be the size tubing you want. The 1x2 band looked better to me on the 2nd gen because it was bigger. Only thing I have together is the center section. It doesn't have the legs on it yet. I'd also need a 1st gen to get the spacing right to finish it.
  14. Nov 1, 2016 at 8:44 AM
    Sig45
    Mark
    Maine
    See #17710
  15. Nov 1, 2016 at 8:44 AM
    medic2230
    Murph
    Bama! Roll Tide
    You're only as old as you feel. :cheers:
    ChadsPride[OP] and Sig45[QUOTED] like this.
  16. Nov 1, 2016 at 8:45 AM
    ChadsPride
  17. Nov 1, 2016 at 8:45 AM
    Sig45
    Mark
    Maine
    Dam Straight!
  18. Nov 1, 2016 at 8:45 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Where are you located? If you're semi local I could drive out there and we could hack up my old rack and use the L-brackets and my D-rings then knock it out in a day or so if possible.
  19. Nov 1, 2016 at 8:47 AM
    ChadsPride
    Now THATS, what friends are for!!! :thumbsup:
    BYJOSHCOOK[QUOTED] likes this.
  20. Nov 1, 2016 at 8:47 AM
    Pigpen
    Dan
    Northwest Montana
    A pic from last night. I went looking for elk in an active logging unit.
    BYJOSHCOOK, Sig45 and ChadsPride[OP] like this.
