Cap City Build & BS AF
Discussion in '2nd Gen. Builds (2005-2015)' started by ChadsPride, Apr 16, 2016.
  1. Jul 25, 2018 at 9:15 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Yes
  2. Jul 25, 2018 at 9:16 AM
    ChadsPride
    ChadsPride [OP] Tacoma Owner & Enthusiast
    Sponsored by TacomaWorld.com
    In between?
    lynyrd3 likes this.
  3. Jul 25, 2018 at 9:16 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Cold is more funner.
    Hot is less funner
    In between is.....in between.
    All acceptable.
    lynyrd3 and ChadsPride[OP] like this.
  4. Jul 25, 2018 at 9:17 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Couple of methods here. Some run it a bit to warm the oil up and get it to flow faster. Personally, I do it cold so all the oil is in the pan and not up in the valve train/heads oozing back. Since we don't get too cold this works for me. If we were talking freezing or below, I might warm it up a bit, but with 0 weight oil, I think it flows fine there to.
  5. Jul 25, 2018 at 9:18 AM
    ChadsPride
    Thank ya!
    lynyrd3 likes this.
  6. Jul 25, 2018 at 9:20 AM
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    Viscosity is much better around 100 degrees or so as the oil drains more completely, and doesn't burn you when the inevitable happens. Cold takes longer to get a good drain.
    Then again, when it's 100 outside...no need to start the engine, just park in the sun.
  7. Jul 25, 2018 at 9:22 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Even with colder temps, I put the drain pan under the truck, pull the plug, and come back 20 or 30 minutes later. I've done oil changes like that for 45 years. Never had an issue. Be sure to put a water bottle or something similar under the drain hole on the oil filter base....Oil will run out the drain into the bottle. saves a mess.
  8. Jul 25, 2018 at 9:59 AM
    Wallbright
    Wallbright Well-Known Member
    2017 MGM DCSB SR5
    Yes :bananadead:
  9. Jul 25, 2018 at 10:09 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    OHHHHH!
    FTFM.
    Sorry to hear about all the bad shit Bill!
    :D
  10. Jul 25, 2018 at 10:13 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Got a new 7 pin on order for the bumper and truck is at the dealer now to check my transmission fluid for peace of mind ! Thanks
  11. Jul 25, 2018 at 10:16 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    I respect, not question my senior members :thumbsup: (notice I didn't say elder :D )
    ChadsPride[OP] and lynyrd3 like this.
  12. Jul 25, 2018 at 10:19 AM
    lynyrd3
    Bill
    About to order some Dakar’s :oops: Getting tired of spending money . $1500 extras during frame swap $1200 to have camper awning repair and new skylight in bathroom and drop bar for weight Distribition hitch that I now do not need until I get the new springs because after frame swap truck sits low in the ass end :annoyed: it never ends . I ordered the part for the hitch before my frame swap because my camper was nose high when hooked up:oops: :facepalm: I will need it anyway after Dakar install so .......:notsure:
    ChadsPride[OP] and RobP62 like this.
  13. Jul 25, 2018 at 10:21 AM
    CaptAmerica
    Cap
    I might resemble that remark too. Staring down the barrel at turning 50 next year.
    :pout:
  14. Jul 25, 2018 at 10:24 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    :rofl:Well then shit, I feel better. I just turned 56 the other day and act like a 14 year old (as we all well know).
  15. Jul 25, 2018 at 10:31 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    :goingcrazy:
    Remember.....oil is RED. :D
  16. Jul 25, 2018 at 10:33 AM
    lynyrd3
    Bill
    Turned 56 in April :p
  17. Jul 25, 2018 at 10:36 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I like to think of it as mature enough to know better, but not remember why :confused:, and immature enough to think you know everything, but not remember why :confused:
  18. Jul 25, 2018 at 10:38 AM
    Plain Jane Taco
    USA
  19. Jul 25, 2018 at 10:42 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    So what do you mix the used filter oil with afterwards, vodka, bourbon, ?
  20. Jul 25, 2018 at 11:07 AM
    CaptAmerica
    Cap
    Spiced rum.
