Cap City Build & BS AF
Discussion in '2nd Gen. Builds (2005-2015)' started by ChadsPride, Apr 16, 2016.
  1. Nov 28, 2018 at 2:48 PM
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
    You’re right
    lynyrd3, MarX, Tractorman and 2 others like this.
  2. Nov 28, 2018 at 2:49 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    That makes perfect sense! Those dorks are notorious for setting the pressure to higher than it should be.
  3. Nov 28, 2018 at 2:49 PM
    23Skidoo
    Paul
    meme
    The gauge at the gas station is off?
    medic2230, lynyrd3, MarX and 2 others like this.
  4. Nov 28, 2018 at 2:50 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    It's not uncommon for me to experience a 7-10lb pressure differential. But this is extreme "drivin on square tire" Cold. Can't see it happening down there Chad.
  5. Nov 28, 2018 at 2:51 PM
    ChadsPride
    ChadsPride [OP] Tacoma Owner & Enthusiast
    Sponsored by TacomaWorld.com
    It does not have a gauge. I carry 3 because I have trust issues :oops:
    ALI3N_123, lynyrd3, MarX and 3 others like this.
  6. Nov 28, 2018 at 2:56 PM
    Tractorman
    Tractorman Just A Dumb Farmer
    Stupid
    Misery
    2015 DCSB / MGM
    Could be the :rasta:.........:notsure:
    lynyrd3, RobP62, FastEddy59 and 2 others like this.
  7. Nov 28, 2018 at 2:59 PM
    ChadsPride
    Meant to say *it (edited just now)
    But yeah, I don't like doing things becuase my OCD I check and recheck stupid things and probably screw up things on the way.
    In this specific case, I'll stick with the discount story.
    Incredible how much better it rides just going from 46 to 36.
    I went ahead and let a ton of air out of all the tires and refilled them all to 36 including spare.
    lynyrd3, FastEddy59, 23Skidoo and 2 others like this.
  8. Nov 28, 2018 at 3:02 PM
    Tractorman
    Stupid
    Misery
    2015 DCSB / MGM
    Every year I can always look forward to my wife telling me the light is on, on her Highlander the first cold snap. Drops air pressure just enough to trigger it.
    Her broom doesn’t have sensors on it! :anonymous:
    medic2230, 23Skidoo, lynyrd3 and 4 others like this.
  9. Nov 28, 2018 at 3:05 PM
    ChadsPride
    Bahahaha!!! :p
    My wife calls and says her tire is flat when the light comes on
    :frusty:
  10. Nov 28, 2018 at 3:06 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Exactly, as the temps heat up, they will increase. As the temps drop they will decrease.
    I will reserve my opinion for the increase 1 psi for ever 10 degrees though. I mean, if the temps out there fluctuate as widely as they do and that statement is true then if you checked them in the morning and it was 30 degrees and then by 6 pm it shot up to 80 then that's only 5 psi.
    I would think too that at highways speeds the increase fluctuation should be less in the winter because while the tread is still making contact with the road surface at speed, the road surface and air flowing around the tires will be much lower helping to keep them cool.
    I will have to do some tests now with my laser therm to check temp and check tire pressures. It's been bitter here the past couple of days.
  11. Nov 28, 2018 at 3:07 PM
    FastEddy59
    Eddie
    Years ago I had a strange situation goin on with a set of aluminum wheels that would contact in extreme cold but when they looked for a leak they found none. :notsure:
    MarX, lynyrd3, RobP62 and 1 other person like this.
  12. Nov 28, 2018 at 3:08 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    See, now that's logic I can embrace. :thumbsup:
    MarX, FastEddy59, Tractorman and 3 others like this.
  13. Nov 28, 2018 at 3:10 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    :rofl:
    That's definitely been a cause of many issues for a lot of people.
  14. Nov 28, 2018 at 3:16 PM
    lynyrd3
    Bill
    East Central Upstate NY
    Good to know :thumbsup:
  15. Nov 28, 2018 at 3:22 PM
    ALI3N_123
    ALI3N_123 ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Eric
    Austin, Texas
    2021 Silver TuRD Squirt DCSB 4x4 // 2008 Black Rusty Shitbox DCSB PreRunner
    Valero sucks.
  16. Nov 28, 2018 at 3:38 PM
    FastEddy59
    Eddie
    They all Suck if they charge you for air. :luvya: I mean Really, didn't you just make enough money from my $75.00 fill? :rant: Maybe I should help y'all out & pay for the electricity that pumped your overpriced, overtaxed fuel too? :notsure:
  17. Nov 28, 2018 at 3:55 PM
    Tractorman
    Stupid
    Misery
    2015 DCSB / MGM
    Metric air is expensive!
    MarX, RobP62, ChadsPride[OP] and 3 others like this.
  18. Nov 28, 2018 at 3:57 PM
    FastEddy59
    Eddie
    Yeah, but you get more. :evil:
  19. Nov 28, 2018 at 3:58 PM
    Tractorman
    Stupid
    Misery
    2015 DCSB / MGM
    :rofl:
  20. Nov 28, 2018 at 4:02 PM
    23Skidoo
    Paul
    meme
    Must have been metric traffic on the way home, because I got extra. :goingcrazy:
