Cap City Build & BS AF
Discussion in '2nd Gen. Builds (2005-2015)' started by ChadsPride, Apr 16, 2016.
  1. Nov 29, 2018 at 7:43 AM
    lynyrd3
    Bill
    East Central Upstate NY
    :rofl:
    MarX and ChadsPride[OP] like this.
  2. Nov 29, 2018 at 7:43 AM
    lynyrd3
    Bill
    Or Bourbon :D
    MarX, RobP62, medic2230 and 2 others like this.
  3. Nov 29, 2018 at 7:54 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Ok, so I took some temperature measurements at the sidewalls and checked the air in the the tires, I needed to add about 2 lbs since it's been cold and I haven't checked them in a couple thousand miles. Here's where I am..........
    Before leaving this AM. Outside air temp was 34 degrees. Front tire Temp 31.5 degree, rear tire temp, 30.5 degrees.
    PSI rear 36, PSI front 37 (I run 1 lb more in the front to compensate for the engine weight vs an empty bed).
    1 hr 20 min drive to work. Outside temp 36 degrees. Front tire temp 46 degrees, rear tire temp 45 degree.
    PSI rear 40, PSI front 41. (4 psi increase, which is what I average in the summer too)
    So, outside temps rose only 2 degrees. Tire temps rose approx. 15 degrees, and the PSI rose 4 lbs.
    Data was pointing to a 1 psi increase or decrease for every 10 degrees. 17 degrees (including air temp) would equate to only a 1.7 psi increase. I suppose there are a lot of different factors involved here though. I would assume, the tire is the biggest. Mine are load range E and after nearly 20k miles have only shed 2mm of tread. I drive like a nut too. I was pushing 80 and the psi on the display was still at 41/40. Road surfaces would play an important role too. Concrete is harder than asphalt. That might relate to some differences. Front end alignment would also have an impact. If you are not aligned properly that could play a role. But I think for a bunch of guys that just drive their trucks and not use them to explore Mars or transport WMDs it's safe to assume these findings, while average, are sufficient. I might test again when I leave tonight to go home since I have the thermometer with me.
    :thumbsup:
  4. Nov 29, 2018 at 7:55 AM
    medic2230
    Murph
    Bama! Roll Tide
    You just quote that to remind us?
    MarX, lynyrd3, RobP62[QUOTED] and 3 others like this.
  5. Nov 29, 2018 at 7:57 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Airing on the Safe Side. :D
    MarX, lynyrd3, RobP62 and 2 others like this.
  6. Nov 29, 2018 at 7:58 AM
    medic2230
    Murph
    Bama! Roll Tide
    ^^^This guy.
  7. Nov 29, 2018 at 8:12 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    :thumbsup: @medic2230 is the Patch master. Hit him up for all your Stitched needs!
  8. Nov 29, 2018 at 8:13 AM
    ChadsPride
    ChadsPride [OP] Tacoma Owner & Enthusiast
    Sponsored by TacomaWorld.com
    MarX, lynyrd3, Tractorman and 5 others like this.
  9. Nov 29, 2018 at 8:18 AM
    FastEddy59
    Eddie
    Lots more on the way, lol. Stay tuned :popcorn:
    MarX, lynyrd3 and RobP62[QUOTED] like this.
  10. Nov 29, 2018 at 8:24 AM
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
    :eek:
    MarX, lynyrd3, Tractorman and 2 others like this.
  11. Nov 29, 2018 at 8:24 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    You could I suppose. I just drink it straight.
    MarX, lynyrd3[QUOTED] and FastEddy59 like this.
  12. Nov 29, 2018 at 8:26 AM
    Sig45
    Mark
    Maine
    Well look at you go! :thumbsup:
    MarX, lynyrd3, RobP62[QUOTED] and 2 others like this.
  13. Nov 29, 2018 at 8:27 AM
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
    I am waiting to see where # 14,000 will be popped :D
    MarX and RobP62[QUOTED] like this.
  14. Nov 29, 2018 at 8:28 AM
    Sig45
    Mark
    Maine
    I think my intermittent humming from what appears to be driver's side is in fact the needle bearing (or something axle assembly related). It goes away immediately after engaging 4WD.
    I'm calling to report it just in case it's related to the new front Diff I had installed in December of last year.
    Skyway, MarX, lynyrd3 and 2 others like this.
  15. Nov 29, 2018 at 8:30 AM
    FastEddy59
    Eddie
    Should hurry up & see if that 10% off from ECGS is still goin on.
  16. Nov 29, 2018 at 8:30 AM
    Sig45
    Mark
    Maine
    I'll check it out...thank you!
    MarX and lynyrd3 like this.
  17. Nov 29, 2018 at 8:34 AM
    Sig45
    Mark
    Maine
    It hadn't done it for 4 days and just did it while I was running an errand.....just threw it in 4WD while doing about 25 on a straight section. It's my understanding that it's not a serious problem, more of an annoyance, right?
    MarX, lynyrd3 and FastEddy59 like this.
  18. Nov 29, 2018 at 8:41 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Like a dumb ass my comments got added to one of the quotes. I fixed it right after I saw it. I think that's what you are referring to right Murph?
  19. Nov 29, 2018 at 8:48 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Yea, I have my moments where the nerdiness just has to come out. No worries though, I have my cool kids pants back on. Backwards as usual.
  20. Nov 29, 2018 at 8:49 AM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Yea, i saw the news this morning and thought of y'all. I sorta chuckled, sorry, but then thought, phht, nothing but a thing to them.
