Capability of stock Tacoma?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Fxstchewy, Jul 2, 2015.
  1. Jul 2, 2015 at 5:53 PM
    Darthoma
    Darthoma New Member
    2011 black TRD Sport
    My stock tacoma does more than most lifted trucks in the sense that I actually use mine. I would suggest that the majority of people are lifting their trucks and putting armour on them for image more than function. I look at the multitude of lifted big bumper Tacomas in my area and they are shiny pretty trucks. They may have some mud splashed on the side occasionally from driving down a muddy road, but are otherwise perfect. Even saw a guy on kijiji selling his OME lift kit cuz he wanted to go bigger. His sales pitch included the fact that the suspension had never been used off road even though he had it for a year before that. Ha.
    I use my stock truck as a truck. I've made the commitment to myself that I won't spend big money on any major aftermarket stuff until I've broken the stock component or found something I was unable to accomplish in stock form. So far just broken antennas, some grill damage, and a paint job that is more scratched than clear. This has been from pushing through bush in remote areas where a breakdown or getting stuck could be a serious issue. Always made it through.
    All this being said, my suspension is now feeling pretty shot. I've hauled some big loads over some long distances and over some rough logging and bush trails. I think I'm close to having the justification to increase my load capacity and rough road handling abilities. I don't see a need for armour as I'm not recreationally rock crawling and have always been able to find the correct route through whatever obstacle has been in my way. I have had to use my chains in some deep wet snow areas but have only ever gotten "stuck" when I wanted to use my new hitch mount winch (which was an expenditure that was contrary to my previous stated commitment and I have had no REAL need for it since).
    If you want to navigate technical rock areas in some recreation trails built for that, or you just have money to burn, all the power to you to throw on the most aggressive bumpers, slides, skids, tires and lifts. But if you just want to do truck things in some rough country, your stock truck should get it done for ya.
    Crow52LA, Sig45 and burntcremebrulee like this.
  2. Jul 2, 2015 at 6:10 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Crow52LA and Sig45 like this.
  3. Jul 2, 2015 at 6:25 PM
    TT11
    TT11 Active Member
    Umm.... Perhaps you forgot about the Jeep Wrangler Rubicon and the 4Runner Trail and the Toyota Landcruiser.
    Tacoma is a really good off road vehicle, but I wouldn't say it is the best.
  4. Jul 2, 2015 at 7:18 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    Ford Raptor....
    I plan on finding out how capable one of the 16 models is soon... not sure which model yet
  5. Jul 3, 2015 at 4:41 AM
    Fxstchewy
    Fxstchewy [OP] Member
    Chewy
    East Coast
    2012 Tacoma
    Actually because I put it here by mistake :)
  6. Jul 3, 2015 at 8:27 AM
    David K
    I should have said best stock off road "truck" and not "vehicle", my bad.
    Raptors have weak spindles... upgrade before you go to Baja with one! Otherwise, they are nice full size trucks.
  7. Jul 4, 2015 at 10:04 AM
    Syncros
    Syncros Well-Known Member
    I found my Tacoma to be fairly poor off road.
    Over rough terrain there was excessive steering wheel feedback and the ABS was too sensitive. Not enough weight over the rear tires meant little traction in 2wd and the rear frame section wasn't rigid enough for the rear suspension to do its job. The access cab doors came out of adjustment once in awhile and would make a ton of noise. The e-brake jammed with dust and grit a few times. All in all it made me not want to buy another when it came time to replace it.
    I picked up a Frontier Pro-4x and actually figured it would be worse (having never owned a Nissan) but it was a really good price. It's very competent offroad, no issues. Having owned Toyota trucks for years it's hard to admit I actually prefer the Nissan in every way, it drIves like the old Toyota pickups I was used to . Of course my opinion might change with the more refined '16 Tacoma coming soon.
  8. Jul 4, 2015 at 12:03 PM
    David K
    Wow, I think you're the first??? If the pickup bed has little or no weight in the back, the traction is going to be poor... a truck is designed to carry cargo back there. That is why we get 4WD in these trucks when we use them for off road transportation and not hauling cargo... so the heavier half axle (under the engine) can have the pulling tires. Glad you like the Nissan... they really need some sales!
  9. Jul 4, 2015 at 12:32 PM
    Syncros
    Mine was 4wd so lacking traction in 2wd wasn't a big deal, it was just surprising how often I needed 4wd. It was an 06 SR5 so no a-trac, LSD or locker. The other issues though we're not expected or easily remedied. The steering feed back and sensitive abs were particularly annoying. I didn't mention the idler pulleys, tsb spring upgrade or mud flaps breaking because those were easily fixed.
  10. Jul 4, 2015 at 12:41 PM
    kyleTRDtaco12
    kyleTRDtaco12 Well-Known Member
    Kyle
    New Jersey
    2012 Toyota Tacoma Base DCSB 4x4 V6 6MT (202)
    TRD Cat-Back Exhaust TRD Sport Package Springs & Shocks (Front Linear Coil Springs, Rear TSB Leafs) Front & Rear Toyota/Bilstein 40mm Shocks) Silver Toyota 16" SR5 Wheels with 265/70/16 BFGoodrich Rugged Trail T/A Tires w/ Locks OEM Black-Chrome Housed Headlights (SR package) OEM TRDpro Grille Insert RokBlokz Rally MudFlaps w/ Stamped Logo OEM 'TRD Sport' Bedside Graphics TRD QuickShifter w/ TRD Shift Knob Hawk HPS Front Brake Pads w/ Brembo Blank Rotors OEM Front Aluminum Skid-Plate eBay TRD seat covers Rear Diff. Breather Mod A/C Drain Extension Mod OEM Fog Light Kit OEM Intermittent Wiper Switch OEM Bed D-Rings OEM Bed Mat OEM Door Sill Protectors Blacked-Out Badges (from Xrunner 205 Black Sand Pearl) Pop & Lock Tailgate Handle TruXedo TruXsport Roll-Up Tonneau Cover AVS BugFlector II Front Bug Guard AVS In-Channel Window Vent Visors TRD High Pressure Radiator Cap Stubby Radio Antenna Ultra-Gauge EM v1.2 w/ Windshield Mount BullaCulla 7-Pin Relocation Bracket Misc. Stickers
    They are fantastic in stock form, plus all TRD accessories minus the S/C of course lol... Mine does everything I ask it to do and more... :) and its basically stock.. It's a base model but has all mis matched TRD trim level parts and other toyota/trd accessories :D
  11. Jul 4, 2015 at 12:52 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    What tires were you running? One of the complaints of the Tacoma is the stock tires that come with the truck from the factory. There are complaints on the 4Runner as well about the tires. From the preproduction pics I have seen so far it looks like Toyota has addressed this issue.
  12. Jul 4, 2015 at 12:53 PM
    AK 08TACO
    AK 08TACO Well-Known Member
    Kyle
    Wasilla, AK
    The Tacoma will beat the Raptor in every aspect except going fast.
  13. Jul 4, 2015 at 2:39 PM
    Syncros
    265/75R16 Bfg AT KO. That's another thing, the Frontier Pro-4x comes with standard 265/75R16's with a matching spare rim and tire.
  14. Jul 4, 2015 at 5:54 PM
    David K
    It's okay, you got a Nissan and are happy. I had a 2005 and it had issues with abs the techs said was normal. It also had a couple other issues (too soft rear suspension, clock spring wire fail). However, the good outweighed the bad and after 4 years and 102,000 miles, I traded it for my 2010 and it has been near perfect and the best of my 3 Tacomas.
  15. Jul 5, 2015 at 10:57 AM
    #35
    SMHdavid
    SMHdavid Well-Known Member
    David
    California
    Sport
    MY stock sport does great.
  16. Apr 4, 2016 at 10:11 PM
    #36
    Crow52LA
    Crow52LA Well-Known Member
    Highland Park, L.A. CA
    2017 Black TRD OR 4x4
    my 2016 DCLB trd Sport 2wd stock ! 4k miles :headbang:
