Capacitor under hood?
Discussion in 'Audio & Video' started by JoshLV, Feb 25, 2011.
  1. Feb 25, 2011 at 12:59 PM
    JoshLV
    JoshLV [OP] Well-Known Member
    Josh
    Hanford, CA
    2007 Tacoma SR5
    Been doing a little research on capacitors because my headlights dim pretty badly at night when my sub hits. I've read that you want it as close to the amp as possible. But I've also read that capacitors are capable of melting shit which doesn't make me too comfortable having it inside my truck. Not to mention it looks tacky.
    Would there be any problems putting it under the hood, or is the distance not that big of a deal?
  2. Feb 25, 2011 at 1:07 PM
    atsaubrey
    atsaubrey Dealer/Sales Rep for Sundown Audio.
    california
    blue 2007 double cab
    Sundown Audio 100.4 and 1500D, Pioneer 880PRS, Zapco Refernece 6.5" comps, 2 10" Image Dynamics IDQ, 200ft of Second Skin deadener, Kicker wire
    What year and syle of truck? I have ran a boat load of power in the Taco and have yet to experience a voltage issue.
  3. Feb 25, 2011 at 1:10 PM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    They are only tacky if you buy a junk one. I suppose they could melt if not properly installed, but I haven't seen anything before. Just put it as close as you can to the amp.
  4. Feb 25, 2011 at 1:15 PM
    JoshLV
    Josh
    Hanford, CA
    2007 Tacoma SR5
    2007 Access Cab. I have my amp under my seat and the passenger seat sits lower so it won't fit under there. I don't want it visible at all. Also I always have people in the back so it would be getting kicked or smacked etc.
    Is a new alternator my only other option?
  5. Feb 25, 2011 at 1:17 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    x2
    Caps are bandaids
  6. Feb 25, 2011 at 1:17 PM
    Jigzor
    Pennsylvania
    Some Caps are the shape of amps. Run it under to the drivers seat.
  7. Feb 25, 2011 at 1:18 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
  8. Feb 25, 2011 at 1:22 PM
    coma09
    coma09 Updated avatar
    BC Canada
    2013 taco access cab 4x4
    List of fixes:
    - battery ... larger capacity to handle the current requirements
    - wire guage ... appropriate for current draw
    - alternator ... to supply more current to battery
    Cap is good for improving transient response (providing you have enough current supply and the wire guage to handle the spikes), needs to be close to the amp.
    Cap provides very short term capacity for instantaneous current draws.
    Not a solution if your lights are dimming.
    Proper wiring methods and lugs make a difference as well.
  9. Feb 25, 2011 at 1:34 PM
    coma09
    BC Canada
    "I would still runa cap even with all the fixes in place. I like overkill. "
    cap is good .... very good actually. However it isn't any good as a crutch for an underpowered system. It's good to add punch and dynamic range, providing ..... you have the juice to supply your amp without dimming lights. Need to fix the root of the problem.
    got enough capacity(battery), got heavy enough cables and proper lugs(complete conductor is terminated at the ends, not a piece of it cause it didn't fit) , heavy enough alternator to make the juice. cap is the icing providing a supply for peak transient response.
